Question about Intel D945GCL Motherboard
Turn off power and reinstall the jumper in normal mode position
D945gcnl mother board, directly it opens cmos setup page, give save & exit it appers (turn off power and reinstall the jumper in normal mode position) what can be done? Even after placing the jumper in normal mode the same error message continues.I think Bios may be corrupted.Will try for reinstall or update the Bios.
  • 45 Answers
Try to clean the pins on the board, check the connection inside th jumper. (with multimeter or else). Try to clear the bios .
Posted on Mar 22, 2009
Though i hve put jumper to normal posirion it shows Trun off & reinstall the jumper to normal position
I can't read those words that you flash around or see what you are trying to show me. Put it on the wrong side nothing will happen but it will clear your BIOS SETTINGS TO DEFAULT. PUT THE JUMPER BACK ON , START UP AND THEN GO INTO THE BIOS IMMEDIATLYAND CHECK YOUR SETTINGS ARE CORRECT.
Now reboot and you should go straight intto your OS if not corrupt.
Good luck and if it don't work be a little more clear on your fault.
Nov 09, 2014 | Intel Computers & Internet
When i start PC; BIOS seting opens and says clear
  1. pls read the user manual first to identify which pinds of password jumper to normal position
  2. Reinstall the jumper in a different position. For example, if you removed the jumper from pins 2 and 3, reinstall the jumper over pins 1 and 2.
  3. Replace the computer cover and reconnect the power cable and monitor.
You can now assign a new system and/or setup password. For more password information, refer to the Passwords section of your computer'sservice manual.
Aug 23, 2017 | Intel D102GGC2 Motherboard
When i start my computer boot screen appears every time.
may be you cmos battery is weak just remove the battery and install new battery and also make sure jumper position is proper.
Hope this helps. Please rate my response.
Thanks.
Have a good day.
Mar 26, 2010 | Intel D945GCCR Motherboard
How to install the jumper in normal mode?
If i am correct, the computer starts up and you see the setup page. It then says that you are supposed to place the jumper in the normal position and It happens every time.
If this is correct, it is telling you that there is a jumper on the motherboard (probably labeled "clear CMOS) and it's set in the incorrect position. There will be three pins. The jumper is installed across two of them. Move the jumper (the little plastic thing) to the other setting: for example, if it's installed on pins 1 and 2, move it to 2 and 3. Give that a try.
The jumper should look something like this: http://tinyurl.com/l8hvqr
Jun 09, 2009 | Intel DG31PR Motherboard
If I understand what you are asking: The computer starts up and you see the setup page. It then says that you are supposed to place the jumper in the normal position. It happens every time.
If this is correct, it is telling you that there is a jumper on the motherboard (probably labeled "clear CMOS) and it's set in the incorrect position. There will be three pins. The jumper is installed across two of them. Move the jumper (the little plastic thing) to the other setting: for example, if it's installed on pins 1 and 2, move it to 2 and 3. Give that a try. Will probably work for you.
Feb 11, 2009 | Intel D945GCCR Motherboard
Some MB's have a second jumper setting on the board to allow a technician to jump to a faster "trouble shooter" configuration. After any or no changes are made to the BIOS's configuration the BIOS wants the The tech to reset the jumper back to "Normal Mode" so the customer doesn't have an overclocked or "hyper"machine voiding it's warrantee. I have seen this on some mostly older boards including Intel's who are known for down speeding their MB's. Check the websit for the MB's manual and see if it tells you where the jumper is located. If not, Also try to update the BIOS to the latest version and this may resolve your problem. Hope so.
Nov 20, 2008 | Intel DG31PR Motherboard
Intel D945GCL Motherboard Logo
722 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
