Question about Gateway GT4024 PC Desktop
Network adapter prolem
Network adapter is not showing in device manager,after installing the driver also it is not showing neither working
  • abhis_42006 Mar 01, 2009
    Thanks for giving solutions but computer has detected the network adapter the next day when i started the pc.
  • Jay Glendenning
    Jay Glendenning May 11, 2010
    Have you checked in the computers BIOS to be sure that the network adapter is enabled?
    Novelist:
  • 79 Answers
I need more info before I can help much. Try this if possible.
is the network adapter park of the motherboard or is a separate PCI card?
If you can remove the card, I would remove it and restart the pc. Then turn off the computer and reinsert the card. Power the PC back up and see if windows even detects a device added. If it does not, then the card may be toast.
Posted on Feb 28, 2009
The network adapters dont even show up in the device manager, where can i download the drivers?
  1. If the network adapter isn't showing up in the Device Manager, even as an Unknown Device, then the Network adapter may be faulty.
  2. Try removing the Network adapter, restart the computer, then shut down the computer after the restart.
  3. Now reinstall the adapter with the computer off.
  4. Once the Network card is reinstalled, turn the computer on. Check the Device Manager for your Network Adapter.
  5. The computer should detect the card and ask you for drivers. If it doesn't, that means it either automatically found the drivers and installed them, or your network adapter has died.
Feb 15, 2011 | Computers & Internet
Network Adapter Connector does not work.
It is a driver issue... especially if your Device Manager has a question mark, and you recently re-installed windows.
This could be hardware failure as well, but looks a lot more like a simple driver problem. Find the latest driver, install it, restart, you should be good.
Sep 08, 2009 | Dell Ethernet Card Network Adapter
Network adapter not working
your network adapter driver is not installed. Install it and then have a look . open device manager and in that look for network adapters if u can see there then ur driver is installed successfully..
Aug 26, 2009 | Compaq Network adapter
My computer shows new hardware found but there's no light on the usb adapter and i can't connect to the internet
Make sure that you have installed the necessary drivers needed for it to work. it usually comes with a CD installer that you can use.
If you're done with the driver installation you may check if the device was properly installed under the device manager.
How to go to Device Manager:
1. right click on My Computer
2. select properties
3. go to hardware tab and click Device Manager
You will see all devices installed on your computers and under the Adapter is where the name of your wireless adapter should be listed if it was properly installed.
Hope this helps...
Jul 13, 2009 | NetGear : WG111 54 Mbps Wireless USB 2.0...
Network Adapter/Ethernet Controller
Nothing wrong with having two network adapters installed on your computer. If you have this DWA-552 wireless adapter installed as well as an onboard NIC, the correct thing to do is have both drivers installed so you see them both in your Control Panel->Network Connections window.
If you really want the onboard nic to go away, go into device manager and disable it - not uninstall it.
Mar 08, 2009 | Computers & Internet
Compaq presario broadcom adapter not showing
Hi!
I will assume that your broadcom adapter is not showing up under Device Manager > Network Adapters. It will happen if the driver is not properly installed.
Look for "Other Devices" under Device Manager. Usually, it will show as Network Controller or Ethernet Controller. Right click that and select update driver. Make sure that you have the driver or file for that adapter. Once the driver is properly installed, it will be under Network Adapter with the correct name.
I hope that helps.
Good luck and have a nice day!
Nov 27, 2008 | HP Computers & Internet
New issue
If you right-click the "unknown" device and select Update Driver, you can force windows to search for the correct driver, and then put in the CD or floppy that came with the network adapter, and tell Windows to look on that CD or floppy. If the installation process didn't work, this might.
Jun 11, 2008 | Gateway GT4024 PC Desktop
Network adapter not showing up in device manager
The tech was incorrect - your network adapter is just not recognized by the system. If you install the correct drivers for your particular network adapter it should be recognized, which should then solve your problem. Search the Gateway website for network drivers for your particular desktop, and if the network adapter was added (not built into the computer) then determine the manufacturer and model of your network adapter, then search the manufacturer's website for the correct drivers.
Even easier, if you still have the original disks that came with your computer and/or network adapter, they should include the correct drivers.
Hope this helps!
Jun 07, 2008 | Gateway GT4024 PC Desktop
Gateway GT4024 PC Desktop Logo
64 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
