Question about Bissell 9500 ProHeat 2X CleanShot Upright Deep Cleaner, Red Berends Vacuum
Bissell 9500 2x deep clean (NO SUCTION)
Does anyone know why there is no suction on this model? thanks!
  • balancing_pt Mar 07, 2009
    I have had this machine for a while now. The first time I encountered the lack of suction issue I cleaned the machine and reset it into its cradle. Each time I use it, I take care to make sure it is cleaned before putting it away. However, this time I can establish suction only through the hand tool, not the base tool and it is minimum suction at best. Is this just poor quality? Or is there a built in design fault that only allows a short period of usage. At this point I am discouraged - I was told that Bissell products were dependable but this one has been nothing but frustration for the year and a half I have had it...
  • Anonymous Mar 11, 2009
    What a piece of ****. I used mine about 6 times and the last 2 times I used it, it kept making a popping noise and stop sucking. I'm looking for an answer to this problem and it seems the only solution is to throw it out and never buy another Bissel product.
  • 25 Answers
Like everyone else (!) your lint filter is probably clogged. It is located on the top clear palstic section (the one with the dial to switch from tool to floor use) and is on the underside. It is a small (1 inch square) red plastic filter with a little door on it. Flip the door open and you will probably find it is clogged with hair, carpet fibre., etc.. Clean it out and you should have suction again.
Posted on Sep 18, 2009
My pet wash bissell shampoor won't pick up the water
Hey Deanne!I know how frustrating it is not having suction when you need it.
Here's a quick link to troubleshooting steps to assist you with the suction.
http://www.bissell.com/FAQDetail.aspx?id=1117&cid=ccsocial
Feb 23, 2013 | Bissell ProHeat Turbo Deep Cleaner Upright...
What cause it to stop sucking up the water?
has anyone answered.you or figured it out yet I just bought one and the suction wont work at all not from bottom or the attachment part heat works solutions works no suction at all help!!!please email me at taraamcgavran20@gmail.com
Jan 17, 2012 | Bissell ProHeat Turbo Deep Cleaner Upright...
My attachments tool has no suction. I made sure I have selected tools and I cleaned the lint filter. There is definitely suction in the machine, but it does not come through the attachments hose.
Check the attachment hose for any hindrances like clogged with dirt or object. Also a big hole cracks in hoses will cause suction to divert it outside. Clean the machine to make sure it will provide suction powerfully. Regularly clean it and you will assure it's will perform better.
Thanks for asking.
Jul 17, 2011 | Bissell 9500 ProHeat 2X CleanShot Upright...
I have the bissell x2 12 amp carpet shampooer
The water should be picked up fairly rapidly into the area surrounding the clean water bladder. Try checking the lint filter to fix your suction problem. It is located in the top clear plastic section (the one with the dial to switch from tool to floor use). One the under side of it there is a small (1 inch square) red filter with a little door on it. Flip open the door and it is probably clogged with hair, carpet fibre. etc.. Clean it out and you should have suction.
Jul 09, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
No suction of liquid off floor.
This unit has to have some type of clogg in the hose or unde neath the unit. Check to make sure that you have suction in the hose first.
May 25, 2009 | Bissell ProHeat Turbo Deep Cleaner Upright...
Bissel model 3594 has weak suction
clean the filter abovethe dust cup... and any other filters
Feb 16, 2009 | Bissell 3594 CleanView PowerTrak Bagless...
MY BISSELL PROHEAT WONT SUCTION
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
ffuutr
Jan 28, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
Have used my Bissell Powerwash Deluxe 4 or 5 times now no suction
We found that the tool wand was blocked, although only used once. But when that was cleared suction was reinstated. Thanks anyway!!
Jan 04, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
Bissel Pro Heat Turbo attachment does not work.
Something is probably clogging up the suction.
Try to snake it out with a coat hanger or similar tool.
Often, especially with shedding pets hair will clog the suction pipes
Hope this is helpful.
Good Luck!
Jan 02, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
Bissell 9500 ProHeat 2X CleanShot Upright Deep Cleaner, Red Berends Vacuum Logo
245 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
