Question about Gateway GT4024 PC Desktop
Network ethernet prolem
Netork ethernet is not showing in the computer mangement if we normally log in the system.in safe mode it is showing but not working what to do even after formating the system network ethernet is not showing even installing the driver it is not working
  • abhis_42006 Mar 01, 2009
    Thanks yaar, for your solution but the PC has detected the network adapter,when i started the PC next day.
    Novelist:
  • 148 Answers
Access the BIOS and see if the ethernet device is enabled (do this only if the ethernet device is built in on the board). If its a card, its more than likely dmaged. Replace the card.
Posted on Feb 28, 2009
Ethernet connection died
This could be related to a lot of issues not enough ram causing memory dumps ,Virus or Malware , or Faulty ethernet lead.
Will it start without the ethernet lead connected ?
Does it start in safe mode ?
You might have a virus or malware or it could be a hardware issue
Reboot the computer As the computer is booting repeatadly press the F8 key as the computer is booting
If done properly the user should get to a screen similar to the below screen.
Select the option for Safe mode command prompt only
Windows Advanced Options Menu
Please select an option:
Safe Mode
Safe Mode with Networking
Safe Mode with Command Prompt
Enable Boot Logging
Enable VGA mode
Last Known Good Configuration (your most recent settings that worked)
Directory Services Restore Mode (Windows domain controllers only)
Debugging Mode
Start Windows Normally
Reboot
Return to OS Choices Menu
Use the up and down arrow keys to move the highlight to your choice
select the safe mode option
then run your antivirus if still cant get rid of the virus restart again
Use the up and down arrow keys to move the highlight to your choice.
select safe mode with networking download anti malware and microsoft security essentials
http://www.microsoft.com/en-us/download/virus-malware.aspx?q=virus
anti virus and malware
http://windows.microsoft.com/en-US/windows/products/security-essentials
if this fails you might have to go back into safe mode
you might use the system restore to restore your system to an earlier time click start all programs accessories system tools you should see your system restore option if it is a hardware issue the system restore might not work Manual restore points that you specify with the System
Configuration utility Installation restore points that occur before you install a program or a service you can use the system checkpoints or the installation restore points to restore your computer's settings to a date when it operated correctly. This may also help determine the cause of the configuration error.
To perform a system restore, follow these steps:
1.Click Start, click Run, type msconfig, and then click OK.
2.On the General tab, click Launch System Restore.
3.Select Restore my computer to an earlier time, and then click Next.
4.Calendar dates in bold are possible restore points. Click the most recent one to view system restore information.
5.Select a system checkpoint or an installation restore point, and then click Next.
6.Close all other programs.
7.To start the system restore, click Next.
8.Your computer restarts.
Repeat steps 1 through 8 until you fix your configuration issue.
other than that you might need to do a format and then re install your operating system
Jul 02, 2013 | Computers & Internet
Tip
Reboot and run in safe mode in windows 7,Vista,XP or 2000
Insert the CD then reboot. While the system is booting, hit the F12 key to access the boot menu (this could be a different key depending on your system.
1.) Click the "Start" button from the taskbar. Select the "Turn off computer" option if you are running a Windows OS Operating System before Windows Vista, or select the right arrow in Vista. Select the "Restart" option
2.) Press and hold the Ctrl+Alt+Del keys simultaneously. Do it again. This will reboot the computer
3.) Shut down the computer. Sometimes the computer will not respond to a reboot. Maybe the keys are temporarily disabled or the system has chosen to completely ignore you. In these rare cases, it may be better to shut the computer off using the power button. If you do shut off the computer, press and hold the power button for 3 to 5 seconds. Then be sure to wait a minimum of 45 seconds before turning it back on. This allows the capacitors in the computer time to discharge, which allows the memory (not the hard drive) to do a full dump of data. This allows a cleaner restart when you turn the computer back on.
4.)Disconnect the power cord. Do this as a last resort. Unsaved data may not be retrievable with this option, but sometimes it is the only option. Reconnect the power cord. Turn the computer on. else Insert the CD then reboot. While the system is booting, hit the F12 key to access the boot menu (this could be a different key depending on your system. If you have a problem with your hardware configuration or your computer's display drivers that prevents Windows from loading normally, you may be able to resolve the problem by booting into Safe Mode and changing the relevant settings. To enter Safe Mode in Windows 7, Vista, XP, or 2000:
Note: If you have more than one partition installed, you may need to select an operating system and press Enter before entering Safe Mode.
Turn on or restart your computer.
After the memory test, the words "Starting Windows" will appear on a black background. When this happens, press and hold the F8 key. This will present a screen with the following options to choose from. The exact moment that F8 is pressed will determine the contents of the list, and the list may vary from computer to computer. For example, your computer may not do a memory test or it may have a SCSI BIOS to load in addition to the motherboard's BIOS. If you have trouble getting the list below to appear, restart the computer and then press F8 repeatedly while the computer is starting.
Safe Mode: Boots Windows with only the basic drivers needed to load the operating system. Uses basic drivers for mouse, keyboard, display (VGA), mass storage, and default system services and drivers, with no network components. In Windows 2000, a log file will be created to track the progress of the system boot, which is located in the Windows 2000 folder.
Safe Mode with Networking: Loads the Safe Mode configuration, but also enables network devices and services. In Windows 2000, a log file will be created to track the progress of the system boot, which is located in the Windows 2000 folder.
Safe Mode with Command Prompt: Loads Windows in Safe Mode, and, after logging in, opens a command prompt instead of the normal desktop. In Windows 2000, a log file will be created to track the progress of the system boot, which is located in the Windows 2000 folder.Note: You should try booting to the command prompt only if you feel comfortable operating within the DOS environment.
Enable Boot Logging: Boots Windows with all of the normal files and drivers, but writes their status to a log file at each step. In Windows 2000, this log file is located in the Windows 2000 folder and is named ntbtlog.txt.
Enable VGA Mode: Boots Windows using a plain VGA 16-color 640x480 display driver for the highest level of compatibility with video cards. In Windows 7 and Vista, this mode is called Enable Low-Resolution Video. It is otherwise identical.
Last Known Good Configuration: Boots Windows using the last registry configuration that is known to work. This is a way of undoing problems created by installing incorrect drivers or possibly by registry corruption. It will not, however, fix problems caused by corrupted or missing files.
Use the arrow keys to move up or down this menu to make your selection, and then press Enter. If you need to update software or access the Internet while in Safe Mode, select "Safe Mode with Networking".
on Sep 15, 2010 | Computers & Internet
WHERE DO I FIND SAFE MODE IN LAPTOP OF HP 6735s
Enter Safe Mode at startup Follow the steps below to start Windows Vista in Safe Mode.
  1. Remove all CDs and DVDs from the computer.
  2. Restart the computer.
  3. At the first screen on restart, before the HP or Windows logo appears, press the f8 key repeatedly.
  4. When prompted, select the Safe Mode with Networking option.
  5. Log onto the computer with a user account that has administrator rights.
Enter Safe Mode when PC is operating If the computer can boot into the Vista operating system, follow the steps below to enter Safe Mode.
  1. Click Start , type msconfig in the search field, and then press the enter to open the System Configuration window.
  2. On the General tab of the System Configuration window, select Diagnostic startup .
  3. On the Boot tab, select Safe boot and click OK .
  4. When prompted, click Restart to start the computer in Safe Mode. If the computer does not restart automatically, press the Power button to turn the power on.
  5. On the Tools tab of the System Configuration window, select and launch the desired diagnostic tool.
The computer is now operating in Safe Mode. Exit the Safe Mode After completing the required troubleshooting and repair, follow the steps below to exit Safe Mode and return to normal operation.
  1. Click Start , type msconfig in the search field, and then press enter to open the System Configuration window.
  2. On the General tab of the System Configuration window, select Normal startup and click OK .
The computer restarts in the normal mode.
May 18, 2012 | HP Compaq 6735s Notebook
My laptop starts properly with the normal starting procedures when when started (with windows vista home premium 1) The mouse gets hanged and keep circling 2) The internet display that is network when...
Good Moring,
I have seen this behaviour in computers with virus (maleware) you can try the following
1)start your antivirus while log in safe mode and run a full scan
if virus is found remove it and start windows normally run a full scan afterwards
2) if no antivirus is install, i would recomend you to reinstall the OS
Nov 15, 2010 | Dell Inspiron 1525 Notebook
Bonjour, I am philips laptop X57 EAA-89. I will : repair your computer. I tap F8. I am Advanced Boot Options. And I am not Repair your computer. I am : Safe mode Safe mode with...
Do F8 on bootup. Boot up in safe mode. Start removing all devices, one at a time. Then boot normal. Keep doing till you find the problem.
Mar 18, 2017 | Computers & Internet
Actually when i log on the computer then show the normal mode,safe mode etc.But when we press normal mode then donot open operating system. so whats the problem?
i think your os files may have been corrupted. first try to boot in safe mode. if it works then reboot and the next time if menu comes select normal mode.
normaly if safe mode boot succeed, then in next boot it will not ask for anything, the windows boots normaly.
Feb 19, 2010 | Microsoft Windows XP Professional for PC
Pxe-e63 and pxe-m0f errors
enter to boot up in safe mode, then disable the atheros network drivers in my computers properties > hardware or drivers, then leave the originals that it came with should be the first two, ok, remove all others that say atheros, This error is of a group of driver programs being installed in computers through networking, yes hackers, I've fixed about 10 computers this month, but this software seems to log in to a network that can monitor your activity. Made by Atheros, & probably hacked to do this, cause Im sure the company did not modify this to log in to other private networks, if networks or drivers are disabled it will not even but up so best thing is to go into safe mode & disable these atheros drivers that dont belong in the computers in the first place. I had to re-install the bios in pcs because it modifies bios, registry files, and once t does that, its hell for the not so tech savy normal person.
Nov 27, 2009 | Acer Computers & Internet
My mouse/touchpad is unresponsive when LAN cable is connected
try booting in safe mode. restart laptop keep tapping f8 then boot safe mode with networking. once you booted to safe mode with networking try plugging in the ethernet cable to the lan port check if it still freezes the touchpad mouse pointer. if not then try to ran full system scan antivirus and check running programs on startup that might cause the conflict. if the problem exist in safe mode with networking download the latest bios for your system.
Oct 15, 2009 | Dell Latitude D600 Notebook
XP wont load in safe mode
MAY BE DUE TO LOT OF VIRUSES. DISMOUNT YOUR HARDDISK FROM YOUR SYSTEM AND SCAN IT FOR VIRUSES IN ANOTHER SYSTEM WHICH HAS THE LATEST UPDATE OF A POWERFULL ANTIVIRUS SUCH AS KASPERSKY....
Sep 23, 2009 | Microsoft Windows XP Professional With...
Having Trouble Starting
Enter Safe Mode with Networking.
Update Video drivers.
Restart the system in normal mode and if still no go then you have to reinstall Vista from CD's.
Sep 25, 2008 | Toshiba Satellite A305-S6834 Notebook
Gateway GT4024 PC Desktop Logo
52 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
