Question about HP LaserJet 4650n Printer
Response given for card slot not initalized did not work. Any other suggestions
    New Friend:
  • 52 Answers
You have to initilize the hard drive, even though you don't have one. Go to google and type in "HP 4600 card slot not initalized" and I think you will find the procedure to clear message. Our printer worked for a month or more with this message.
Posted on Feb 27, 2009
Can a 4gb memory card be used in a vivicam 6324 and if so how do i formatt it it keeps saying memory full?
If it's actually a 4GB SD card and not an SDHC card then it can be used. However, the SD specifications actually only go to 2GB, so almost all cards larger than that are SDHC cards. While SDHC cards will fit into SD slots, they are electronically incompatible and will not work.
Given that the camera isn't formatting it, I'd say that the card is an SDHC card. I suggest using SD cards 2GB and smaller.
Oct 11, 2010 | Vivitar ViviCam 8018 Digital Camera
Card reader quit working all of a sudden
Try the car in another computer first.
May 07, 2017 | Gateway M-6846 Notebook
My Fuji A350 has given me good service. It has suddenly stopped working and displays "Card Not Initalized". I have not changed cards, this has just started out of the blue, no dropping it or anything.
This can happen if the battery door is opened while the camera is on. Formatting the card in the camera will probably solve the problem. Formatting will delete all images on the card.
Mar 24, 2010 | Fuji FinePix 2650 Digital Camera
Card not initalized
Is the card larger than 2GB.
If so its too big for the S7000.
The only solution to more capacity is 2GB xd card + 2GB compact flash card.
Or just use as many XD cards as you need.
Oct 10, 2009 | Fuji FinePix S7000 Digital Camera
Remote stuck in express card slot
Hi ,
Take a professionals help .
Mar 22, 2009 | HP Computers & Internet
System does not see new video card
Confirm the card works in another system to eliminate it as a suspect. Try a beefier power supply in the machine (sometimes these 300 to 350 watt supplies just cant hang when an addon card is installed). Check the BIOS settings and make sure that the PCI Express slot resources are active for the card. If the card uses a power connector, make sure it is connected. Keep us posted.
Mar 21, 2009 | Gateway GM4019E PC Desktop
PCI device.
An “Error allocating Mem Bar for PCI device” suggests that a card located in one of your PCI slots has a possible problem. Try removing the card, (or cards-one at a time) to eliminate the error. Here’s a link showing location of PCI slots: http://support.dell.com/support/edocs/systems/dim3000/en/SM/techov.htm#wp1061217
Your responses are intended to improve the level of service provided. Please show your appreciation by rating your experience.
Thank You.
Jan 14, 2009 | Dell Dimension 3000 PC Desktop
Inserting a sim card
try another sim card, the sim card slot maybe faulty is this a new phone? I would suggest to replace it at the dealer
Jan 03, 2009 | Giorgio Armani Samsung P520 Cellular Phone
No picture at all
Hi geminip3, you need to make a couple bios changes when using a PCI-E graphics card. Still have your manual? Go to page 36. Advanced Chipset Features. Onboard GPU (Enable If No Ext GPU). By adding a PCI-E card this should be set to Disable. Than go to page 44. Init Display First (PCI Slot), set this to [PCI-E]. Read each page.
Than save your bios & exit. The system will auto restart. If you do not see display, wait about a minute & remove the monitor cable to the second out put slot. Some PCI-E cards need more power than the PCI-E motherboard slot can provide. You may find a power port on the PCI-E card. Some look just like the power cord for a floppy, others look like the power cord for an IDE hard disk drive. The latest ones are black in color & one end connects to an opened 4-pin molex (IDE power cord). Let’s address the onboard video card. (No PCI-E card attached). Back to page 36. Onboard GPU should be set to [Enable]. Page 44. Set Init Display First to [VGA/PCI]. Page 45. PCI/VGA Palette Snoop, set to [Disable]. I was unable to find where in the bios one can set the amount of system memory to run the onboard VGA. ECS manual is not the easiest to work with. Note: Ihave worked on other ECS MB's & though the above information has worked out ok for some, its not worked out for others. If the above suggestions do not work out, suggest you call ECS tech. I have emailed ECS stating their manual is confusing & asked for them to explain bios settings for VGA & PCI-E. Correct bios settings for your MB & user jrl1261's MB GeForce6199PM-M2. If the above settings do not work out. Don't fret. ECS wil get back to me & I'll post their email here.
Mike
Aug 10, 2008 | EliteGroup ECS GeForce6100SM-M (1.0)...
Motherboards' video card slot was damaged,
If you don't use your pc for gameing, assumeing the motherboard still works!
you could buy a PCI video card
http://www.si87.com/Products/Videocards/agpvspci/agp-or-pci-or-isa.jpg
Here is a example card you could buy
http://cgi.ebay.com/NEW-ATI-Radeon-64MB-DDR-Dual-Head-VGA-PCI-Video-Card_W0QQitemZ230237362135QQihZ013QQcategoryZ3762QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
Before you buy, make sure the motherboard works! becouse if the motherboard is too damaged it wont work at all and you would waste your money on a pci card.
Apr 02, 2008 | Intel D845GVSR Motherboard
HP LaserJet 4650n Printer Logo
69 people viewed this question
Ben Johnson
