Question about Pitney Bowes Office Equipment & Supplies
I need to run a purge print on our Pitney Bowes DM1000 to flush the heads and get ink flow re-established. All I can find is a ''clean print head'' but it doesn't put enough ink.
    Problem Solver:
  • 9 Answers
You maybe have a bad prtinhead or maintenance station or its can only be some dry ink somwhere inside the systems
Posted on Mar 18, 2010
    Scholar:
  • 87 Answers
You only have the option of getting a cleaning kit from pb or the like. There isn't a way to dump fluid as far as I know.
Posted on Mar 07, 2009
How do i need to purge the ink lines on an epson 3880
Purging Procedure - If you have just installed a new archival or Quadtone cartridge you must purge the Epson print head of all of the old, non-archival, ink before you can begin to print with the full archival effect. The print heads in the Epson 200/400/440/500/600/640/740/800/850/860/900/1160/1520/Photo/Photo 700/Photo EX/Photo 750/Photo 1200 printers hold about 3 to 5 pages worth of ink. Always run a Nozzle check before printing. Even if you get a perfect nozzle check on your first try after putting in a new cartridge, run at least one or two head cleaning cycles. This will prevent any excess ink from over filling the print head. After the cleaning cycles, use the purging test patterns below to purge your system of the old ink. After printing about 5 (8.5x11) pages of this pattern, 98% of the old ink will be gone. The rest will come out slowly and may take as many as 20 or more pages, but at the 98% point you will see good results. If you have an Epson 3000, 5000 or 9000. See below
Sep 11, 2015 | Epson Stylus Pro 3880 InkJet Plotter...
Tip
Horizontal Lines on your print out paper
Possible Cause:
Air in the print head: This is the most common cause of printing problems. When changing the cartridges, or for other reasons, air bubbles can enter the print head. This prevents the necessary pressure build up (through heating or vibration) as a result, no ink is sprayed onto the paper and you can see white lines. This effect is also called banding.
Solution:
To improve your print, most printers feature a print head cleaning cycle. Ink is flushed through the print head to re-establish the ink flow. It may be that you have to carry out this procedure several times to achieve the desired result.
Possible Cause:
Blocked nozzles: If the printer is not used for a long period, particles can build up and block the print head.
Solution:
To remove this blockage, run the cleaning cycle. If you cannot achieve a satisfactory result, use a nozzle cleaning fluid.
Possible Cause:
Defective print head: Print heads are exposed to high stress. The temperature variation in thermal print heads can vary by 100`s of degrees centigrade up to 10000 Hertz (10.000 times per second). Therefore print heads have a certain amount of wear and tear. Depending on the manufacturer and price, print heads have a limited life. Epson uses Piezo print heads, which guarantee a long life. However if they do become defective, compared to other printers, the repair can be costly.
Solution:
With printers that feature integrated print heads that are separate from the ink tank (that is for example, Epson and most Canon machines) all that remains is to change the print head. With HP Lexmark and Dell the print head is part of the cartridge, and is automatically replaced each time you replace the cartridge.
on Aug 29, 2010 | Office Equipment & Supplies
Pitney Bowes E700 doesn't print at all althougth the mechanism appears to be working fine. I've changed the cartridge and cleaned the print head and run maintenance several times but to no av
Addressing Original Question: Its essential that the PB E700 machine is linked to Pitney Bowes account to either a) add postage or, b) carry out an Inspection. within 90 days or machine will start flashing "Inspection Due" if this is ignored after a further 30 days the machine will start flashing "Inspection Required" and stop printing! Perhaps this is the solution required.
a) First Connect machine to telephone line as if you were going to top up with postage.
b) Press "Refill"
c) Press "0"
d) Press "Enter"
Machine should display your current balance with PB.
And the Inspection message will be cleared.
Hope that helps. I also misunderstood the "Inspection" message thinking it was referring to a maintenance requirement, when it is actually an antifraud/security requirement of the postal authorities to check location and usage of the machine.
Mar 07, 2012 | Office Equipment & Supplies
My black ink is not working please tell me how to clean it
Hi
To clean it, remove the ink cartridge and rub the print head into a plain paper with rubbing alcohol until ink flows. Then run the print nozzle for 2 time for further cleaning the print head. Then try to print again.
Another way is to soak the print head only into a how water for 5 minutes until ink loose up and ink flows, rub the print head into a plain paper with rubbing alcohol until ink flows. Run the print nozzle and then try to print again
Post comment for more help
Mar 18, 2011 | Office Equipment & Supplies
I have white paper lable refill in my DYMO, and when I try to make a lable, it looks like there is no ink to print the words. What can I do?
or the purge unit needs replacement.
Incidentally, the 6A00 error pertains to all Canon printers made in the last several years, its not just used in one model.
And it’s always a paper path error or purge unit.
The purge unit, called a spittoon assembly in an HP, Lexmark, and other inkjet printers, is where the print head assembly parks when not in use, also its other job is to clean and make sure the print head is clean and open for printing.
That is where you'll find the print head assembly parked on top of it.
It also has an electrical pump to milk the print heads and test for ink flow.
So clean all under where the heads are parked and on IP6600D models you can take out the heads just by clipping them out, and then clean well.
Also clean the purge unit out make sure all is clean.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Apr 28, 2010 | Dymo LetraTAG Thermal Label Printer
When turning on my Cannon mp610 I get error 6A00 - telling me to turn power on and off - if not consult manuel -- the print heads do not appear to be tracking as I cannot get them to come to the middle as...
Apr 28, 2010 | Canon MP610 Photo All-In-One Printer
Pixma 830 error code 6A00 on printer screen. Error 5C10 on computer screen when trying to print from computer. Tried moving ink tanks back and forth, shut off computer. Moved white thing to unsick ink...
Hi there
This answers with a titch more detail.
The 6A00 is a Canon generic code for paper path jam.
Some where in the paper path a sensor is activated indicating paper jam so the printer will give off a 6A00 code.
As a Canon tech, I usually find the code, almost 90% of the time, is related to the purge unit being jammed with something and not being able to move.
Moving the print head assembly will not clear a purge unit if its jammed with paper, paper clips, push pins, screws, cookie crisp, flower bud pods or the like.
And yes I have found all those things in a purge unit.
The offending item needs to be removed or the purge unit needs replacement.
Mar 08, 2010 | Canon PIXMA MP830 All-In-One InkJet...
I need a Pitney Bowes DM200L postage meter repair manual
I found someone with the same problem at the following website.
http://forums.pb.com/t5/Equipment-Hardware-and-Supplies/DM100i-WASTE-INK-TANK-FULL-NEEDS-REPLACEMENT-MESSAGE/m-p/2589
Dec 21, 2009 | Office Equipment & Supplies
Pitney Bowes 8000, when I go to Copy it prints BLACK
your thermal print head is bad. This is a very old machine and I do not know where you can get parts. This machine is no longer supported by field repair
Aug 20, 2009 | Pitney Bowes Office Equipment & Supplies
I refilled the black ink for my printer. I cleaned the printer .
I know this is something that you may not want to hear... I used to work for Pitney Bowes fixing postage machines.. these machines have inkjet printers in them. If you use refills other words ink not from the manufacturer it will cause you problems. I know that it might work a few times without problems... but I have seen it first hand at Pitney Bowes... If you don't use the manufacters ink it will destroy your printers. In your case go back to using the Brother cartridge... see if that solves the problem. Which it very well could work off the Brother again. Printer manufactures do this on purpose you have to buy their ink! In any case good luck.
cdixon18
The Man Inside the Machine
May 11, 2009 | Brother MFC-3240C All-In-One InkJet...
141 people viewed this question
Top Pitney Bowes Office Equipment & Supplies Experts
Adorjani Laszlo
Victorman
Victorman
Are you a Pitney Bowes Office Equipment and Supply Expert? Answer questions, earn points and help others
