Question about Microsoft Windows XP Home Edition
Mouse problem i accidentaly uninstalled my mouse driver when i attach my mouse to pc this hangs my computer what will i do?  {using xp sp 2}
  • 27 Answers
Go to start > control panel> mouse> (If you dont see this option change your setting in the top left to classic view) > hardware> properties> drivers> and click reinstall this should do the trick. please rate me. thanks
Posted on Feb 27, 2009
My mouse scroller is not working
The above symptom is associated with, but not limited to, the following systems:
  • ThinkCentre M70e, M70z, M71e, M76, M77, M80, M81, M90, M90p, M90z, M91, M91p, Edge 71z, Edge 91z
Applies to:
  • Microsoft Windows 7 in XP Mode
The system is configured with the following:
Windows XP Mode in Windows Virtual PC on a computer that is running Windows 7
http://www.microsoft.com/windows/virtual-pc/download.aspx
Lenovo USB mouse driver for Windows 7 (Lenovo Mouse Suite)
Additional Information:
As of writing this tip, Lenovo Mouse Suite Version 6.48 can be downloaded.
http://support.lenovo.com/en_US/downloads/detail.page?DocID=DS014888
Lenovo USB mouse driver for Windows 7 (32-bit and 64-bit), Vista (32-bit and 64-bit), and XP.Uninstall Lenovo Mouse Suite.
  1. Click Start, then click Control Panel, View By: Category.
  2. Under Programs, click Uninstall a program.
  3. Right-click Lenovo Mouse Suite, then click Uninstall/Change. You may see a dialog stating, "Windows needs your permission to continue." If you see this dialog, click Continue.
  4. Follow the instruction on the screen to complete the uninstall process.
Other steps.
If you still need some Lenovo Mouse Suite function under Windows 7, the following steps may effective.
  1. Mouse Properties
  2. Select "Lenovo" Tab > Advanced Properties.
  3. Select "Wheel" Tab
  4. Change Wheel setting to "Use Microsoft Office 97 Scrolling Emulation Only" from "Enable Universal Scrolling."
Feb 26, 2013 | Lenovo Computers & Internet
Tip
USB devices not recognised or not working properly?
Try these steps to reinitialize your usb ports on your pc
1. Unplug ALL USB devices connected to the computer. If you are using a USB mouse and keyboard, temporarily use the older type PS/2 devices if you have them, if you don't then just leave them connected.
2. Hold down the windows key and press r
3. Type devmgmt.msc into the run menu and press ok
4. Click on the + sign next to the Universal Serial Bus Controllers
5. You might need another mouse to do this if you have a usb mouse.. I recommend you get a ps2 connector mouse which goes into the green round connector in the back of your pc.
6. Right click and uninstall first the usb root hubs. all of them then uninstall the rest of the devices you see under Universal serial bus controllers
7. Ones you have uninstalled everything you should see the Universal serial bus controllers there at all.
8. Now go ahead and restart your pc.
9. Ones you have restarted the pc your usb ports will reinstall in a moment stand by while it installs all of them. If you get warning messages click ok or continue installation.
10. Now go ahead and plug the usb devices back in. Install software if required, all usb devices if not faulty or broken should work now. Also note the error code if you get one?
This solution doesn't fix all usb problems so if you have a yellow ! mark there and device status reports a error code. Then it might not be a problem with your usb ports.
Thank you for reading, do leave suggestions, comments, feedback below.
Ekse
usb mouse drivers for windows xp mouse trackball mouse drivers bluetooth mouse computer problems 2.0 usb driver microsoft windows scanner driver usb 2.0 air mouse computer service usb hubs update drivers fix windows computer services computers hub usb usb drivers usb 2.0 hub laptop mouse usb switch 4 port usb 2.0 hub wireless mouse usb driver fix computer windows xp pro usb optical mouse computer support computer repairs update driver 4 port usb hub usb security usb cable windows xp microsoft windows xp computer repair windows xp professional upgrade windows
on May 04, 2008 | Microsoft Windows XP Home Edition
I have a systemax syx-ms-7309 ser#106603641 i need to know the specs im having issues keyboard or mouse wont work and monitor yurns on says no signal and no picture but the toer has powe to it but th
first the monitor
Test all power and data leads that attach to your hard drive IDE,SATA
the leads from your (motherboard to your hard drive) make sure they have secure dust free connections and are not faulty or just replace them they might be faulty
if its a 40 pin flat ribbon type it will be the first to fail
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty
even something as small as a faulty electrical fan and its lead can cause you problems
computers need all power and data to continue through every working device and to have an end so any faulty leads will end up with a computer error
make sure your graphics card is securely seated with no dust built up or in the socket
if you remove your graphics check the socket to make sure its dust free
restart your computer then reinstall it this should activate found new hardware wizard
try blowing out all of the dust from your keyboard using a fine air blower from an air compressor making VERY sure there is no MOISTURE in the lines.
dust causes static which causes lots of problems with a computer and its parts
if by now you gan get a screen
you might have to uninstall your keyboard restart your computer then reinstall it
make sure the lead connection is secure and dust free (if applicable)
make sure the usb device is inserted correctly into the Ps2 or usb port (if applicable)
click start control panel administration tools computer management device manager scroll to keyboards also mouse you might see a yellow exclamation or question mark ! ? or red x you will need to update driver right click to update driver
if your computer came with a motherboard disk the drivers could be on it
this will apply to your mouse
you might have to uninstall the mouse and its drivers then restart your computer then reinstall the mouse and its drivers
click start right click on my computer select properties device manager control scroll to mice and pointing devices you might see a yellow question mark? right update driver
click start control panel mouse you should see 4 tabs buttons pointers pointer options and hardware under hardware you have options to troubleshoot also you can select properties under driver you will have the options update driver rollback driver or uninstall in xp
in windows 7 click start control panel hardware and sound mouse you will see the same tabs and options as with xp
hope this helps
Jul 16, 2012 | Systemax Ascent PC Desktop
I cannot use the mouse /touch pad at all.it happened suddenly?
If you are using vista than
Use a usb mouse to do this.
Right click 'my computer'
select ' device manager'
locate you touchpad and select it and right click and choose 'update driver software'.
If you are using xp than follow steps 1 and 2 and the third step is 'uninstall' than click scan for new hardware. XP should see the touchpad and update the drivers for i
Jun 10, 2011 | Acer Computers & Internet
I just bought one used ibm t23 laptop but I cann't find the cursor/mouse on the laptop
make sure you have the correct mouse selected click start control panel mouse hardware
make sure the lead from the mouse has a secure seating and the lead is not bad/faulty
(if applicable) or you
might have to uninstall the drivers then restart your computer then reinstall the drivers
click start control panel administrive tools computer management device manager scroll to mouse and pointing devices you could see a yellow question mark? Right click to update driver also
click start control panel mouse you should see 4 tabs buttons,pointers,pointer options and hardware under hardware you can troubleshoot or select properties under driver you will have options to update driver,rollback driver or uninstall and under hardware you can troubleshoot
in xp
hope this helps
Feb 24, 2011 | Computers & Internet
Windows XP loads up but when prompted to click user, mouse will not work, I have tried 2 different mice confirmed to work on another PC, keyboard then locks up when press any key, tried to repair with xp...
try blowing out all of the dust from your laptop keyboard using a fine air blower from an air compressor making VERY sure there is no MOISTURE in the lines.
or if this does not fix the problem
click start control panel keyboard you can change your settings there
or you might have uninstall the keyboard restart your computer then reinstall it and its drivers
click start control panel keyboard hardware then properties you should see driver details,you will have options to update driver,roll back driver,uninstall
make sure you have the driver for the keyboard before uninstalling the driver
make sure the lead is good and has a secure connection diconnect the keyboard then reconnect it then reinstall the driver
as for the mouse
click start control panel mouse you should see 4 tabs buttons,pointers,pointer options also hardware under hardware you can troubleshoot or
select properties under driver you will have the options to update driver,rollback driver or uninstall and under hardware you can troubleshoot
in xp
hope this helps
Jan 22, 2011 | MSI K9N6SGM-V (7309-020(K9N6SGM-V))...
There is no sound in my eeepc 900 after reinstalling linux, can anyone help? the sound is not mute and i assume it has something to do with the sound on motherboard that i might need to do something about...
if we get problem in xp or sp-2. there sp-3 can work it is my experince. sound depend on mother bord driver not in operating system.righr mouse click on my computer .then cllick on property. hardware . then clickon on device manager. then click sound ( on speaker sound ) if there is yellow sign keep bord cd / driver right mouse click and up date driver .
Nov 03, 2009 | ASUS Eee PC 900 Notebook
My logitech ps2 mouse gets hanged while working
Sounds like the driver has become corrupted. You will have to uninstall then reinstall the drivers. Lets start with that, let me know how it goes and we can take it further.
Please remember to rate me.
Feb 02, 2009 | Logitech PS2 BLACK OPTICAL WHEEL MOUSE...
Mouse Problem in Project IGI
Sounds like to me you need a new mouse. Or if it is wirless you must have the infrared receiver closer to your mouse.2) check your device manager and see if your mouse has a Yellow ? or ! mark next to it.If so right click on the mouse listing and click repair or update and or uninstall then reinstall your mouse last. This will fix it if it is not gone!!!
Great Luck!!!
Jan 06, 2009 | Computers & Internet
Usb mouse on laptop
go to start>>control panel>>add and remove porgrams.
uninstall all of the Logitech software related to the optical mouse.
restart the computer, plug in the mouse usb, the windows OS should automatically detected the mouse.
Windows OS has logitech mouse driver buldin. you don't need additiona; software.
Nov 04, 2008 | Computers & Internet
Microsoft Windows XP Home Edition Logo
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
