No sound device
Sound drivers working properly but there is no sound device installed or sound devices are not installed properly. Sound and audio devices properties-volume tab-no audio device-device volumes and speaker settings are grayed out. Recently I have moved some folders from disc C to dics D. Could this be the problem? Dont know what to do? I have tried to install new drivers but nothing...
  • Shabbir  Dole
    Shabbir Dole May 11, 2010
    Have you got the correct drivers....?
  • 262 Answers
SOURCE: No Sound from Acer Aspire 5100 : Volume tab is disabled
hi I am linda
trying going into add and remove the whole thing then shut your pc down and reboot it after is rebooted try going to systems files and make sure your aduio deivce is still connected if it is n't I am supposeing your audio card mite be bad or reinstalling it mite take care of the promblem .
Posted on Apr 24, 2008
Teh_shivers
  • 104 Answers
SOURCE: Radeon HD 4650 = NO audio
uninstall the ati sound utility, these video cards have a built in high def audio chip for sound thru hdmi
Posted on Dec 15, 2008
  • 2692 Answers
SOURCE: no sound
An audio device is a piece of software that came with the setup disk for you mother board/computer. Here si the website to download anything that you are missing. You will need the model number of your computer.
http://www.compaq.com/cpq-country/cpq_support.htm
Posted on Dec 21, 2008
chinmay_lp
  • 271 Answers
SOURCE: speaker showing No Audio Output device is installed
Try to uninstalled the audio driver.then restart the machine and again install the audio driver.hope this will work for you.
Thanks
Posted on Feb 28, 2009
SOURCE: K9VGM-V Mobo, AMD 6400+, Realtek ALC883 on-board sound, XP Service Pack 2
This board seems to have an issue after installing 4gb of ram after swapping out 1gb of transcend ram and installing 2x 2gb kingston the audio device disappears, swap the ram back and the problem goes away, to further complicate things it seems that kingston and transcend ram doesn't play nice together in this board having one of each results in no post and a ram related beep code as of yet I have not been able to produce the bios settings to allow the two sticks to play nice together maybe somebody else can help out on this one!
So either lose a stick of ram or install a sound card and have your system become considerably unstable
Posted on Mar 17, 2009
No sound
Go to CONTROL PANEL, HARDWARE & SOUND, MANAGE AUDIO DEVICES (Under SOUND). Click on PLAYBACK to see what audio device is installed if any. If necessary, select a device and/or test it.
If no device is present, you need to run a device driver search to find what driver was not installed - Slim Drivers from slimwareutilities.com is free and does a great job at identifying missing drivers. It will usually find the missing driver and help you install it to get sound working on your system.
If installing the proper driver does not help, you may have to use an external (USB) audio plug and only be able to access sounds through headphones or speakers.
Jan 15, 2014 | Pavilion g7-1219wm Notebook PC
I have no sound and i can not see the volume control
It's a possible problem with the driver or the sound card may be disabled. To check if the sound card is disabled or drivers not installed,
1. Right click on "My Computer" select "Properties"
2. Click "Device Manager"
3. From the list, you should see a "Sound Controller" and if you click on the drop down arrow beside it, you should see the audio driver installed(ex. High Definition Audio Device... audio driver name may vary depending on the brand of the laptop).
4. Right click on the sample "High Definition Audio Device" then select Properties. If it says device is working properly then there shouldn't be any problem with your audio.
** If the Sound Controller is NOT installed properly you need to download the Audio drivers from the support site of your Dell computer, http://support.dell.com , be sure to select the correct model of your laptop and operating system of your computer. Once you have downloaded and installed the drivers, Audio should work fine not unless it is the hardware itself that is damaged.
**Also don't forget to check if there are other external audio output devices connected to your computer, please do test if working properly.
Hope this helps. Glad to be of service.
Nov 23, 2011 | Dell Computers & Internet
MY DELL PC HAVE SOUND DRIVERS WHICH ARE NOT WORKING AND ONCE I INSTALL NEW SOUND DRIVER THEY SOUND AT A VERY LOW VOICE EVEN WHEN THE VOLUME IS ADJUSTE TO THE HIGHEST
Hi antonykionyo
DELL OPTIPLEX GX60 DESKTOP PC AUDIO/SOUND DRIVER
You don't say which Operating System you use, so my answer will be presented in general, Windows terms. If yours is a non-Windows Operating System, consider applying the logic and principles involved here to your own Operating System and, if in doubt, please feel free to add a Comment or Clarification to this Question, including information about your Operating System.
Check the status of the Audio Device and the Audio Driver in Device Manager.
Start > (My) Computer > (System Properties) View System Settings > Device Manager
This will tell you if the Audio/Sound Device is installed and functioning properly and if the Audio/Sound Driver is installed properly. If a red 'x' or a yellow question or exclamation mark appears next to the Audio/Sound Device, then there is probably a settings anomaly, fault, error or conflict with the Audio Device and/or its Driver.
AUDIO DEVICE SETTINGS
For your Audio/Sound Device to function properly, it must be set as the Default Device:
Start > Control Panel > (Hardware and Sound) Sounds Speech and Audio Devices > Sounds and Audio Devices > (Manage Audio Devices) Audio > click on the Drop Down Menu to the right of "Sound Playback - Default Device" (preferred Default Playback Device) > select "ADI 198x Integrated Audio" > Apply > OK > Restart computer.
AUDIO/SOUND DRIVER PROBLEMS
Re-install the correct Audio/Sound Driver that relates to both the Audio/Sound Device (ADI 198x Integrated Audio) and your Operating System, then restart the computer. Install the Audio/Sound Driver either from the Dell Drivers and Utilities CD or from the official Dell support website here:
http://support.dell.com/support/downloads/download.aspx?c=us&cs=19&l=en&s=dhs&releaseid=R71579&SystemID=PLX_PNT_CEL_GX60&servicetag=&os=WW1&osl=en&deviceid=2430&devlib=0&typecnt=0&vercnt=3&catid=-1&impid=-1&formatcnt=0&libid=3&typeid=-1&dateid=-1&formatid=-1&source=-1&fileid=92933
If your Operating System is not the original Windows 2000 or Windows XP for which this PC was designed, then it is highly probable that no Audio/Sound Driver exists for that Operating System.
If you are committed to both this PC and an unsupported Operating System but all the other Devices and their Drivers are functioning normally except the Audio Device or you are using Win 2000 or Win XP but the Audio/Sound Problem remains unsolvable (faulty Audio/Sound Chip), then consider buying and installing either an internal 5.1, 7.1 or 8.1 PCI Sound Card or an external USB Sound Card that is pre-confirmed as being compatible with your Operating System. They can all be inexpensive. See examples here:
http://www.amazon.com/s/ref=nb_sb_noss?url=search-alias%3Daps&field-keywords=5.1+7.1+8.1+pci+soundcard&x=5&y=17
I hope this helps.
If this Answer goes some way towards helping to resolve your Query, Problem or Fault, please take the time to Rate it. Doing so helps Solution Providers, like me, better understand the needs and the point of view of Askers, like you, and guides us in exploring the best ways to provide the most comprehensive, useful and high quality Responses and Solutions we can. If you need further help, please do not hesitate to post another Question or add a Comment to this Question.
Thanks for using FixYa.
Sep 24, 2011 | Dell Optiplex GX60 PC Desktop
Acer extensa 4620z sound problem
If you cant hear sound, go to Control Panel and make sure your audio device is installed correctly. If audio device has yellow mark, or some error, reinstall your audio device drivers. If you don't have Laptop CD, you can download your audio driver from here: ftp://ftp.work.acer-euro.com/notebook/extensa_4620/driver/Audio_Realtek_v5.10.0.5423_XP.zip
If your audio device has no problem in Control Panel, make sure your sound is at maximal level. Hope this helps.
Apr 01, 2011 | Acer Extensa 4620 Notebook
Hello i like to install speaker sound drivers ...
Speakers do not need any drivers!! Your sound card need drivers.
If your sound card is PCI, remove it and reinsert it to the PCI slot again and see whether your system detect the device and use the sound CD to install the drivers. (Change PCI slots if necessary and turn off the PC before changes the PCI sound card).
If your audio device is intergrated device, check the Bios to make sure the sound/audio is enable.
Note: Check the device manager first to see any audio device had been install properly.
May 20, 2010 | Computers & Internet
Cant get any sound out of my laptop
Check whether the sound card drivers are installed properly or not. If installed check in the device manager, go to device manager and navigate to sound and audio devices. Check if the drivers are installed correctly.
Oct 18, 2009 | Computers & Internet
No sound
Download Microsoft UAA drivers for your O/S
Uninstall any sound drivers installed or part installed through device manager.
Install UAA drivers and reboot
when rebooted go to device manager right click sound driver and update will go on net and find and install drivers
Olease give me a Fixya for this solution If done properly will work
Nov 22, 2008 | Compaq Audio card Sound Card
Sound problem
Hi thr,
If u r runnin Windows XP, Go to control panel. click on system->hardware->Device Manager n check to see if the sound drivers r installed properly. If the lists shows a yellow exclamation mark on PCI DEVICE, It means u need to install microsoft universal audio articeture drivers first. u can search for it on yahoo or any other searchengine to get the link. download and install microsoft uaa drivers, Uninstall the PCI device from device manager and re-install the audio drivers. I hope it works this way. Thank u
Nov 06, 2008 | Compaq Presario 700 470024-192 Notebook
No sound
after downloading drivers,open the setup and install it to your PC.Check the sound card.the installed drivers must be suitable for your sound card.not all drivers will operate on your sound card.if still problem persists try installing vista.
Sep 21, 2008 | HP Compaq Presario V2000 Notebook
Computers & Internet Logo
David Payne
David Payne
