Question about GE Profile Harmony WPGT9360E 4.0 Cu. Ft. Washer
Ge harmony washer detect motor not operating proplerly
Can I just replace the motor?
  • 10,865 Answers
Yes.
Posted on Feb 27, 2009
Ge harmony washer says there is a problem been detected how do I clear it
The Ge washer claims it has detected a problem. How do I clear it? There doesnt seem to be anything wrong with the unit.
Aug 26, 2010 | GE Profile Harmony WPGT9360E 4.0 Cu. Ft....
GE Harmony washer will not move from problem notification screen.
Press and hold the my cycles button and the back button simultaneously for 3 seconds. This will reset the control panel and allow you to see any stored errors.
Feb 28, 2009 | GE Profile Harmony WPGT9360E 4.0 Cu. Ft....
A problem has been detected with this unit i need know how to enter my Service Mode Diagnostics
I'll email you a few pages out of a service manual for a WPGT9360 (closest I could find to your model number) hope this helps.
Nov 12, 2008 | GE Profile Harmony WPGT9360E 4.0 Cu. Ft....
GE Profile Harmony Clutch probs./Invertert PCB history
Your inverter board is operating 7 degrees over the max temp...
Clear this error be exiting the service mode and run set up ...
if it comes back you will need to replace inverter board....
let me know if you need more help...
Jul 30, 2008 | GE Profile Harmony WPGT9360E 4.0 Cu. Ft....
GE Profile Harmony 4.0 -Broken Clutch Coupling
if your under warrenty always call for service repairing it yourself voids your warrenty
Jan 15, 2008 | GE Profile Harmony WPGT9360E 4.0 Cu. Ft....
NOTICE A PROBLEM HAS BEEN DETECTED WITH THIS UNIT- GE HAR WASHER
There are 5 solutions for this problem
1) house voltage (voltage to low)
2) Inverter
3) Motor (if motor only turns in one direction)
4) wire connection to the low voltage
5) Hall sensor at rotor (only turns a 20% of speed)
let me know if I can help you more...
Dec 12, 2007 | GE Profile Harmony WPGT9360E 4.0 Cu. Ft....
GE Harmony Washer- Error code- The motor is not rotating properly??
filter*** circuit = house circuit breaker or ???
2) Inverter
HELP, GE profile harmony washer wont drain properly
If you remove the tub to pump hose from the pump and try to turn the pump impeller by hand, it should turn freely. If it does not turn freely, then the motor could be seized and you will need to replace the pump.
Oct 15, 2007 | GE WPGT9360EPL Top Load Washer
Hi: Replace motor asm w/clutch part no. wh20x10024
 If you can put the washer to its side on the floor, check if the small white motor turns when you press start cicle.
Oct 01, 2007 | GE Profile Harmony WPGT9360E 4.0 Cu. Ft....
GE Profile Harmony WPGT9360E 4.0 Cu. Ft. Washer Logo
219 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
