Question about Philips MCD703/37 System
Broken DVD holder/spindle
I have a MCD703. Great system. However, the little black spring loaded DVD holder in the DVD/CD player broke...its the part that goes on the motor spindle. It has to be a $1.00 part, but Philips wants to replace the entire unit with a newer model (but not as nice). Where do I buy one of these little plastic round (approx 5/8" round) pieces?
  • renec232 Sep 16, 2009
    do you have the subwoofer cable ? i need
    New Friend:
I have the same issue! if you get a solution please let me know!! I have searched every where with no success.
Posted on Oct 27, 2014
SOURCE: philips hdmi dvd player
hook up playstation 2
Posted on Jan 02, 2008
  • 57 Answers
SOURCE: dvd player won't stay on
your unit sir or maam, it has a deffective parts you need to replace the parts the two channel of the power output ,because this parts is shorted,you need a good technician to fix it. and buy the parts to replace it
Posted on Jan 11, 2009
SOURCE: Dvd tray wont open or close
if the tray is not working, check the belt in the motor, maybe it is lose, or check the limit switches, maybe one of those is malfunctioning. actually they has 3 wires.
Posted on Feb 16, 2009
  • 144 Answers
SOURCE: I own an hts3450 system, dvd player part is destroyed.
You can check on ebay if maybe somebody else has damaged set. they seem to be sold a lot there. Otherwise contact philips vendor
Posted on Apr 17, 2009
SOURCE: philips home theatre dvd player loads and says no
did ya plug in those three colored plugs
Posted on Nov 07, 2009
My memorex dvd/cd player only plays black and white dvds
see this causes: and fix it . God bless you
  1. Disc loaded upside-down.
  2. Transportation lock engaged.
  3. Dirty, scratched, or defective disc.
  4. Dirty or damaged objective lens.
  5. Loading (mechanical) not completed reliably.
  6. Damaged lens suspension or damaged lens cover preventing free movement.
  7. Dirt, gummed up lubrication, or damage in sled drive mechanism.
  8. Dirty/defective limit switch or sensor.
  9. Defective spindle motor.
  10. Spindle table height incorrectly set.
  11. Bad component in optical pickup.
  12. Cracks in ribbon cable to optical pickup.
  13. Need to adjust servo (or less likely, optical) alignment.
  14. Faulty power supply, electronics, or control logic.
  15. Bad connections including missing/erratic optical deck shield.
  16. External interference.
Sep 23, 2012 | Memorex MVD2050-BLK DVD Player
Before you attempt to repair your DVD Player yourself, make sure that you have necessary tools and test instruments like philips screw drivers, multimeter, soldering iron, soldering lead, soldering pump, etc...
This is a DVD/MIDI Player with a "no disc error" upon loading any disc that played before...
Watch this VIDEO
First I've loaded it with disc and observe the movement of the optical lens and the spindle motor. First thing I've noticed that the spindle motor didn't oscillate upon spinning and it's spin slowly unlike the normal RPM...
I've suspected the spindle motor was already bad but still to be confirm...
Unscrew the disc holder plate from the assembly to keep away the magnet touching the spindle motor, this may affect the reading and spinning of the motor upon testing with the multimeter.
This is how it looks like after removing the disc plate holder in the assembly. Spindle motor is secured with 2 small screws in the lens assembly.
Pull-out the connectors from the main board to see the underside of the tray.
You may test the spindle motor with your multimeter set in resistance measurement (ohms X1) even connected to the small board.
Bad motor will read either less than 5ohms(shorted winding) or infinity (open winding) and will not spin.
Good motor will read more than 50 ohms(depends the size) and will spin upon testing. Watch this VIDEO.
Onced you've confirmed that the motor was already faulty, unscrew it from the lens assembly.
Replaced the spindle motor with new one. Before you install the new motor make sure that the clearance of the disc holder is the same as the old one. Compare first the clearance because if it is to high the optical lens will not read the disc same if it is to low....
After replacing the motor re-insert all the connectors to the main board.
I've load same disc which does not read a while ago and observe what will happen. Observe the disc and the sound oscillation from the spindle motor in this VIDEO.
Hope that the above information, pictures, and video will help you fixing your DVD player yourself.
Thanks for visiting Fixya.
Have a nice day!
on Apr 18, 2011 | Bose 3 2 1 GSX System
I have a DYNEX portable dvd player: DX-BPDVD-7.(New a month ago) Has only one problem: Its difficult when removing discs.You have to moderatly force/prise the disc off its spindle to remove it. Just...
This is due to the fact that the central spindle is having a rigid spring holder. Use a small tweezerr plier to press it into so that the aligment to the centre hole of the cd is just right. Be very CAREFUL not to damage the mechanism with great force but be gentle. Also if you can pull out the cd using the whole hand with the fingers clutching the sides, you will have this problem reduced.
May 26, 2010 | Audio Players & Recorders
I need to know the name/part number of the round central part that clamps a CD in place. This is a Philips MCD702 player which loads from the top. The part is a small plastic ring that goes around the...
Its just the CD tray holder, u usually can get one from another junk player (most are the same). I can tell you that you won't be able to order one from phillips (no aftermarket parts available). You would need to have a really expensive shelf system for the company to support a parts market. Most of these when they're broke they're tossed out as no parts are available. You can call Phillips and they can tell you yay or nay. But I would try an find a used on at maybe a thrift store or something for a few bucks
Jan 24, 2010 | Philips MCD702 Shelf System
A dvd is stuck in my Chrysler town and country multi disk dvd/ cd player. How do I remove it?
Look around the face plate for a very small hole...use a straightened paperclip or equivalent and press in a few inches...its a manuel door release and you should gain access to at least the loading tray.
Apr 24, 2009 | 2005 Chrysler Town & Country
Trouble playing dvds
I found that yes, the Pioneer DV-341 motor would not begin turning the DVD's at times without assistance (such as your finger as I found out when I disassembled the DVD player) to get it started.
Before buying any parts, I removed the DVD players housing (eight screws) and the top of the DVD housing that secures the DVD. This had the unpowered, spinning disc holder. Mine was secured by some plastic tabs and one screw.
I found the powered, bottom part of the disc holder had a rubber torroid (like a flat rubber band) glued to it that relies on friction to spin the disc. It was filthy, and needed manual cleaning. Having a Masters in Electrical Engineering, I used the appropriate tools to clean it, my finger and some spit.
I put everything back together and it works great. I'll keep an eye on the problem in the event that the motor is actually going bad, but I find that usually, things just need a cleaning to work as they are supposed to.
Mar 23, 2009 | Pioneer DV-333 DVD Player
Brand new acer,spindle is too large on multi drive for cds or dvds
There are three little spring loaded things that you have to push together to get the DVD or CD to fit, I had the same problem
Sep 15, 2008 | Acer Aspire 3680 Laptop
Vm9311TS jensen
did you get it fixed? i have the same problem
Aug 06, 2008 | Jensen VM9020TS Car DVD Player
Dvd stuck in the dvd / tv
I had this same problem and fixed it too. It was from a flat torsion spring on the loading mechanism that had moved position. It hits against the chassis of the DVD housing preventing the mechanism from seating the disk on the spindle. Result is a stuck disk and/or constantly running loading motor.
Remove the one black machine screw behind the DVD player. DVD player will slide out of TV with its black plastic trim fascia from bay.
Remove two screws that hold fascia panel, remove fascia and lift off top metal cover.
With CD loading slot facing you, the problem spring (in our situation) was at the left. Also identical spring on the right side too. These are the two torsion springs near the front on sides of chassis. The helical loop on the left should be towards the top. If it shifted to the bottom, it can hit the tab with screw used to secure DVD chassis. When this happens, CD loading mech can't complete loading disk onto the spindle. If spring flips when the CD is on the spindle.... disk can't eject.
I used a pair of tweezers to gently grab the spring and "flip" it upwards by pulling it upwards. Spring will work for mechanism in up or down position, but needs to be up to avoid interence.
Solved my problem and DVD has been great since. If it flips back for some reason, then I will try attaching a small piece of plastic to the side of the chassis to contain spring in upright position only.
Jan 18, 2008 | Polaroid 3211TLXB 32 in. LCD Television
Disc won't load and then shows weird symbol in right corner
Check the black spindle that holds the disk it may be cracked or broken or the little spring tabs are broken. If this is the problem when the disk spins it lifts up and the head doesn't read the disk, this is what has happened to mine. I am trying to locate the part but so far have not had luck finding it.
Sep 17, 2007 | Audiovox D1708 Portable DVD Player
Philips MCD703/37 System Logo
258 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
