Question about Combi Centre DX - Mango
Bxi combe 80e - should the screw on the autmatic
Bxi combe 80e - should the screw on the autmatic air vent be unscrewed i.e., open?
According to observation of similar boiler, the screw on the relief valve is shut.
Posted on Mar 01, 2009
How do I retrieve ring dropped down dryer vent?
unscrew the 2 top screw under the screen assembly then take the back panel off and unscrew the air dock and move it to the side to reach in
Feb 20, 2015 | Kenmore 6.7 cu. ft. Electric Dryer
No air flow vents
1. if you look under the console you will see rectangle slot pry open and unscrew the phillips screw "blue color". pull out hdd and reinsert (front of console under the disc slot) put blue screw back in place. attach power cable and switch on.
2. if your'e handy open the whole console clean with compressed air put it back and switch on. thats what i did with the ps3 i found in the dumpster this was even worse than yours because the disc player is not working, fixed it and now watching bd movies on it and play gran turismo 5. good luck on yours.
Nov 23, 2013 | Sony PlayStation Video Game Consoles &...
My radiator has a leak on the top how can I fix it without having to replace it just yet
does it leak from air vent if so you can unscrew return valve cover and close it of with adjustable spanner, turn the flow to off. using a vent key remove vent screw, should not be too much water but have mop bucket and old cloths at the ready.wrap some PTFE tape (got in most diy shops) around vent in anti clockwise direction and screw it back in open valves and bleed rad to vent the air... alternatively there is some good plumbing videos on you tube covering a lot of plumbing problems..
Aug 17, 2012 | Toyota Corolla Cars & Trucks
Ice build up on the coils
To much condensation in the air .. Use a dehumidifier in the room ...
Jul 12, 2011 | Frigidaire FAH106N1 Wall/Window Air...
CP-X260 PROJECTOR SHOWN A MASSAGE "CHECK AIR FLOW
If you have the user manual,read it first.It will show the reasons why those messages are poping up.Temperature sensors are located on the vents which gives you the problem messages. Usual problem is that the vents cooling your system is blocked preventing the air to cool your heating lamp.If you want to do service on your own(try your warranty first,opening the unit voids the warranty) you can unscrew the covers yourself.Unplug the unit first.Get a clear tape and as you remove the screws,tape the screws near the holes you got them from to prevent confusion upon rescrewing the covers back.Locate the vents filters,usually found on near exhaust fans and locate another one with a foam and screen near a smaller fan.Blow or get a smaller powered vacuum to **** dirts out.Re-install the foam and screen filter the way you removed it,be sure to observe the connector for the fans.
Nov 25, 2010 | Hitachi CP-X260 LCD Projector
Dryer is not heating up
LG DRYER NOT HEATING ????? ****PLEASE READ THIS LG DRYER UPDATE!!!!! ****
I READ AND FOLLOWED THE SUGGESTIONS ABOVE AND IT WORKED!!!!! AND I SAVED HUNDREDS! LET ME WALK YOU THRU.
(UNPLUG THE ELECTRICAL CORD BEFORE FOLLOWING THESE STEPS)
1.ON TOP OF DRYER THERE ARE SCREWS ON BACK, UNSCREWING THESE WILL ALLOW YOU TO PULL TOP OFF (IT SLIDES AWAY FROM DRYER)
2. NOW THAT TOP IS OFF, UNSCREW SCREWS OFF OF TOP FRONT PANEL (SCREWS ARE ON BACK OF FRONT PANEL BUT CAN ONLY BE SCREWED OFF IF TOP IS OFF)
3. NOW OPEN DRYER FRONT DOOR AND UNSCREW 2 SCREWS UNDER LINT CATCHER AREA, SCREWS FACE THE FRONT - NOW THE WHOLE BOTTOM FRONT PANEL WITH DOOR WILL CAN COME OFF TO ACCESS THE BOTTOM OF DRYER
4. ON LOWER RIGHT HAND CORNER OF DRYER THERE'S AN AREA WITH WIRES AND PARTS - LOOK TOWARDS BACK ALONG RIGHT SIDE OF BOTTOM OF DRYER (ABOUT 6 - 7 INCHES TOWARDS BACK)
(FLASHLIGHT MAKES EASY TO SEE)
5.LOCATE THE FLAME TUBE WHICH LOOKS LIKE AN OPEN CYLINDER (THIS IS A FEW INCHES FROM RIGHT SIDE TOWARDS CENTER OF DRYER) - ON THE LEFT BOTTOM SIDE OF THIS FLAME TUBE THERE ARE 2 SETS OF WIRES (1 IN THE INSIDE OF THIS FLAME TUBE AND 1 ON THE OUTSIDE OF THE FLAME TUBE) THE 1 SET OF TWO WIRES THATS INSIDE OF FLAME TUBE IS WHERE YOU WILL BE LOCATING A "BUTTON OR PIN SWITCH" - THIS WILL BE RIGHT BETWEEN BOTH WIRES (MINE WAS BLACK COLOR BUTTON ON A METAL PIN).
"PUSH / CLICK" THIS BUTTON BUT MAKE SURE THERE IS NO NOISE AROUND YOU BECAUSE YOU NEED TO HEAR TO MAKE SURE YOU HEAR A "CLICK" SOUND - I MISSED IT BUT ONCE CLICKED IT WONT CLICK AGAIN BUT ITS OK CUZ IT WILL WORK).
6. BEFORE PUTTING EVERTHING BACK TOGETHER I HIGHLY SUGGEST YOU VACUUM OUT ALL LINT/ DUST BUNNIES FROM THE INSIDE OF THE AREA YOU WERE JUST IN (AROUND THE FLAME TUBE). i EVEN UNSCREWED THE OUTSIDE OF LINT CATCHER TOOK IT OFF (EASY) AND CLEANED IT. I ALSO VACUUMED THE BACK OF DRYER WHERE EXHAUST COMES OUT AND VACUUMED THE VENT THAT GOES TO WALL AND THE VENT GOING UP TO MY ATTIC AND MADE SURE THE AIR FLOW WAS GOOD THROUGHT THAT WHOLE AREA (SHOP VAC WORKED GOOD CUZ YOU CAN USE IT TO VACUUM BOTH BY SUCKING AND BLOWING AIR INTO THE AREAS WHERE VENTING / EXHAUST OCCUR).
7. PUT ALL PARTS AND SCREWS BACK, PLUG IN AND TURN DRYER ON WITH WET CLOTHES IN IT ...
May 25, 2010 | LG DLG2532 Gas Dryer
I have a Pusar infloor system newly installed with 5 separate circuits, each controlled by its own thermostat. One circuit heats up intermittantly and currently is cold. How do I troubleshoot to resolve...
Try closing off the other zones, run this zone and see if you
can get the air out of the line, you should have an autmatic vent
installed somewhere.
It sounds like air in the system. If it gets warm but not hot
open up another valve so you can mix the two return zones
to get the water warmer faster. If the zone does not get warmer and you have all the air out, is it possible the unit is
bnot big enough?
Jan 09, 2010 | Heating & Cooling
How do I change out the air filter for the 2200 model? Not sure where to open it up in order to check the air filter and if needed change it out. Thank you.
After you pull out the filter case. There is a tab on the bottom and on the top that holds the ends in undo these.lift out the combs and the filter. Open the new filter and hook it onto the tabs of the filter case and close the ends back up. Get one of the combs in all the cracks of the new filter then slide the next comb in right next to the one that is installed and slide it down to the furthest slot where the combs go. and do this for the rest of the combs until they are all inserted. once they are all in replace the filter case into the cavity be sure to line the slots up on the case and the cabinet and put the door back on.
Jan 03, 2010 | Aprilaire 2200 Air Purifier
I cannot open my compaq evo d51s, any ideas?
if you look at the back of the workstation you will find a hidden screw next to the air vents, locate and unscrew, the casing should slide back away from the front and lift off to access the optial drive and ram
Apr 27, 2009 | Compaq Evo D500 PC Desktop
I need a protherm 80e manual, any idea where I can download one from? The baxi site does not do support manual downloads. :(
This is the manual for 80E. It isn't a manual for the 80e, it's a manual for the 80E, dunno if they are the same or not.
http://www.protherm.cz/upload/1117176168.pdf
If that's is not it, you can browse here =>
http://www.protherm.cz/component.php?cocode=download&dcid=4
Dec 30, 2008 | Protech Systems FasNSeal FSWMKE4 4" Vent...
Combi Centre DX - Mango Logo
82 people viewed this question
Top Combi Baby Gear Experts
paulcarew
ray gallant
Are you a Combi Baby Gear Expert? Answer questions, earn points and help others
