Question about Poulan/Weed Eater #Wt200 711724 24cc Gas Blower/Vac
Installing return spring and rope on wild thing? How?
  • 10,865 Answers
Http://www.poulanpro.com/poulanpro/manualSearchPrepare.do
there u go.. please mark this answer as a fixya
Posted on Feb 27, 2009
I need to change the starting rope
Its a simple process.. But you haven't stated the make and model.!?
Apr 24, 2016 | Garden
What is an easy way to wind the spring for the pull start rope. mine always ends up not pulling all the rope back in
Be careful to much pretension can break the recoil spring. Just one additional turn at a time is what I recommend. HTH
Lou
Nov 06, 2009 | Poulan Wild Thing 2375 18" Gas Chain Saw...
This is my second wild thing. I wore the first
Hello Ms Weem:
Will the starter cover from your first Wild Thing fit?
Have you looked at the starter cover on a different new Wild Thing (demo)? Is it like yours?
Are you releasing the starter rope with it extended?
Yours is the first problem of this type I've heard for your saw. There is no pulley guide or starter rope thimble I'm aware of. I'd think a small nylon or teflon bushing for the starter rope could be fabricated by a machine shop but it would be at your expense. HTH
Lou
Oct 19, 2009 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Pull rope does not return
Unless the rope has broken, you dont need to replace it. The problem is probably the rewind spring. It is located under the starter pulley (the one the rope is in). The best thing to do is pull the unit apart and see if you can see if maybe there is something holding the rope up. The spring is a little dangerous to replace. If you go for it, be careful....Lee
Sep 03, 2009 | Garden
Starter rope will not retract.
inside the rope pull housing is a flat spring,it may have come loose from its anchor, its an easy fix...unscrew the 3 screws on housing, lift off housing, and the rope pull is inside the casing, you will then see if its broken, or just come off anchor, 10 minute job if its just loose......
Jul 21, 2009 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Recoil spring on homelite chain saw doesn't retract pull rope
Easy suggestion would be to get new spring coil. Is it older saw? Have had to change mine on poulan saws before.
Jul 04, 2009 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Pull start on my wild thing keeps jamming
you can not pull the starter rope out to full length. Just short rapid jerks. everyone has this problem
Jan 26, 2009 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Broken Pull String
Yes, it is possible that the spring needs to be pre-tensioned. its also possible that something was put together a little out of alignment, or some part is too tight and its too hard for the spring to wind in the chord. try to reassemble the chainsaw with a couple more turns on the spring and see if that helps.
paul
Oct 30, 2008 | Poulan Wild Thing 2375 18" Gas Chain Saw...
WILD THING PULL STRING ASSEMBLY
It looks like a design flaw because I figured out how to get the recoil assembly back together but
it failed again, twice. I can't remember what the warranty term was.
Oct 08, 2008 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Poulan/Weed Eater #Wt200 711724 24cc Gas Blower/Vac Logo
191 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
