Question about Toshiba Satellite Computers & Internet
Laptop cursor/pointer keeps going back to the beginning when i type
When i type using the keys on my laptop the flashing cursor/pointer just keeps going back to the beginning with every press of the keyboard and is very annoying. I am NOT brushing the Touchpad when i type, because it happens even when i type slowly, i have even tried Touchfreeze but no difference, and also tried using a wireless mouse and disabled the Touchpad but still no difference. So if anyone can help i would be grateful, thanks
SOURCE: Mouse cursor moving by itself
I have the same dell computer, you have to down load the newest synaptics driver and disable the touch point mouse in the middle of the keyboard.
Here is the link.
http://search.dell.com/results.aspx?c=us&l=en&s=gen&cat=sup&qmp=12&p=1&subcat=dyd%2f17&rf=all&nk=t&sort=-date&snpsd=A&ira=False&spf=Latitude&ssysid=LAT_PNT_P3C_C610&ssysn=C510+%2f+C610&~srd=False&ipsys=False&advsrch=False&~ck=anav
Hope this helps!
It worked for me.
Posted on Feb 09, 2008
  • 461 Answers
SOURCE: Dell Latitude D630 Touchpad/Pointer
Do not check the check box as leaving the touchpad enabled while using an external mouse will not cause any harm.
Posted on Dec 12, 2008
djhollewood
  • 54 Answers
SOURCE: Compaq Presario CQ50 - touchpad problems
A simple but temporary solution would be to use an external mouse. Logitech sells several affordable and very nice wireless mice. Then you could disable the touchpad. I find them more trouble then their worth anyway and by using an external mouse you'll most definitely increase your productivity. :)
Posted on Jan 16, 2009
  • 928 Answers
SOURCE: Acer laptop keyboard & touchpad not working
If you can log in by pressing the f8 key in safe mode, then try the system restore. If it doesn't work, it could be very well be a hardware failure.
Posted on Nov 09, 2009
Testimonial: "Thanks for the suggestion. I press F8 and nothing happens. Keyboard isnt recognized at all. But your info was helpful"
computerdeb
  • 323 Answers
SOURCE: my keyboard and touchpad cursor are both frozen.
Touch Pad can be disabled on two different ways. The first one is using FN+F9 key combination or using DISABLE option in mouse properties in control panel
Posted on Mar 18, 2010
Cursor not showing up
Well the touchpad driver could be erased or a virus may have damaged it.
You should go to Acers website and then support and download drivers and get the right touchpad driver.
Install it and see if it works.
Use TAB to navigate for now. or use mouse keys.
This means keep pressing shift really fast and accessibility option will show up.
Use tab and space bar to navigate to MOUSE TAB and select Mouse Keys and hit enter.
Done for now you can use the numpad to operate the cursor.
Second option is to go out and buy a USB mouse.
Worst case scenario: Touchpad is damaged and needs replacing.
Or simply a cable got disconnected and needs reconnecting by taking the laptop apart
Get Your Laptop Mouse to Show Up if It Disappears
Using a laptop is as efficient as a desktop computer to complete tasks, use the Internet and talk with friends on a daily basis.
If your laptop's mouse cursor disappears, there are various tricks and solutions available to help get your mouse pointer back to resume your work and current computer tasks within minutes.
And this can be accomplished without the use of software applications or advanced computer skills.
Press "Ctrl" + "Alt" + "Delete" and choose "Task Manager" if your mouse pointer becomes available, pressing the keys simultaneously.
This will allow you to close any open programs that may be causing issues with your mouse pointer.
Plug in an external mouse to allow the computer to attempt to find the device, prompting the mouse pointer to appear which may solve the problem or allow you to temporarily work with a mouse pointer.
Reboot your computer by pressing and holding the laptop's power button for a few seconds.
This will reset your laptop's current open settings and most often allow your computer's mouse pointer to reappear.
Upgrade your laptop's video and graphic card drivers (if available) to ensure the mouse pointer disappearing or flickering is not a hardware issue.
Select "Start" > "Control Panel" > "Hardware and Sound" > "Device Manager" to view your current graphic and video settings.
Visit your device manufacturer's official website to download the most current version of your drivers.
http://support.microsoft.com/kb/198614
Aug 05, 2013 | Acer Computers & Internet
Laptop touchpad cursor twitches uncontrollably
try and reduce the sensitivity of the cursor go to control panel then to mouse then on the tab select pointer options and reduce the speed if that dosent wotk get a usb mouse and uninstall the driver for the touchpad/synaptics and try to reinstall it.
Dec 19, 2012 | Acer Aspire 4930-6862 Laptop
What is wrong with an uncontrollable cursor?
When they put the palm rest back together it looks like they did not insert the ribbon cable end properly to the motherboard plug in, which would explain the erratic behavior. The laptop will need to be dismantled and checked.
Jun 15, 2012 | Sony VAIO P Series Pink Netbook Computer -...
The Cursor of my acer is stuck and it cant move any further. what can i do?
Hi
If the cursor is stuck/frozen when we use the touchpad it can be solved by the following method.
Switch off the laptop, disconnect it from power, remove the battery and keep pressing the Power switch for 30 seconds.
Then reconnect battery and the external power in that order and power on the laptop. the cursor will be moving again.
Please check this related discussion which is similar to your problem:-
http://www.computing.net/answers/hardware/my-laptop-cursor-wont-move/67689.html
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
May 03, 2011 | Computers & Internet
While typing on my laptop, my cursor jumps to other places on the page, then types where the cursor has moved to . I don't use a mouse.
I guess the 'other places of the pages' is mostly the beginning of the line? It usually happens when the key stroke is not proper while using combination keys. Or also it happens when if you dont release a key when you press the next in between your speedy typings.
Mar 28, 2010 | Dell Inspiron 1525 Notebook
Scrolling/cursor problmem on Sony Vaio VGN-C140G laptop
Im having a similar problem , have you got it fixed yet? I really need some help the scrolling feature on my Vaio VGN - FZ31S does not work at all and I have tried everything.
Feb 20, 2010 | Sony VAIO Notebook
Cursor bounces around, doesn't release when highlighting
Does your laptop have a touch pointer within the keypad? This can cause the problem you're experiencing. Did you try turning the track stick off in the touchpad settings?
May 19, 2009 | Computers & Internet
Cursure jumps while typing and I'm kicked out of PowerPoint slide show
Ah, the Vista mouse annoyance! Go into your control panel, and in the Mouse properties, set the pointer speed a bit slower until the cursor stops bouncing all over.
Jan 20, 2009 | Acer Aspire 5500 5570-2609 Laptop
Cursor(pointer) cannot be moved by using touchpad but possibe wit
This happens to me also. Check whether the touchpad is enabled (laptops do have an option of enabling / disabling the touchpad). Secondly, you can try reinstalling the touchpad driver. Uninstall and then re-install the driver. Re-boot the system. Try using the touchpad.
Hope this helps., if so, rate me.. thanks - billa
Dec 20, 2008 | Lenovo Thinkpad R61i Notebook PC
Computers & Internet Logo
75 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
