Question about Polaroid i830 Digital Camera
Blurred images when taken at night or someone moves while phot is taken my images are blurred/fuzzy, what could be the cause?
  • 28 Answers
Any number of things.
Low ISO. No Flash. No tripod. Too little light. No "shake" correction on the camera.
Depending on the goal of the photo, you may wish to use a tripod. Or use the flash. Or use a higher ISO (400+). Or any combination of these.
The easiest thing to do would be to make sure you use a flash. If you're trying to take a photo of something without the flash, you'll have to use a tripod. And even then, if something is moving fast through the frame, it'll likely be blurry. You simply need more light.
If you're new to digital cameras, I recommend the automatic settings. There's an "action" mode which usually has a man running as an icon. Or someone in motion. Some cameras even have settings for use at night or in darker rooms. Try those.
If you feel comfortable, you could manually bump the ISO up to 400 and try again. Your photo may be a little "grainer" and will probably look a bit ugly blown up much over a 5x7, but for 4x6 or anything online, it should be fine.
Posted on Mar 06, 2009
Cannot view camcorder slides on television taking film of holiday but cannot watch on television as all fuzzy
Unless you have an HD (High Definition) camcorder, the resolution of the video (or pictures) taken may be too low for it to show well on a (large) TV screen. Hence, you'll see the videos/pictures as blurred/fuzzy
Jun 22, 2010 | Samsung Video Cameras
Fuzzy background on tv picture
This is probably a combination of 2 things. In both causes 1 and 2 below, I would suggest checking the TV with a BluRay Player with BluRay disc connected using an HDMI Cable. If you complain about this, then the TV is probably not that great. Expect a $200 jump to a better model at the least (but this depends on what you have now). Honestly, this is fairly normal and wont change much with the next TV.
CAUSE 1: Motion BLUR
Motion blur occurs when fast moving objects are displayed on LCD TVs. Basically, it takes time for the LED lights that make up the picture to turn ON and OFF, when and object shown on the TV is moving faster than the LCD TV can turn these lights ON and OFF, you see the trail left behind as the lights dim to OFF. This look like blur because you see the current image and the trail of the old images. 120HZ and 240HZ LCD TV are supposed to improve this but honestly, they are at times 300+ dollars more and not really worth it. Very little difference except in some few cases.
CAUSE 2: Digital TV
Digital signals are hit or miss. Good or BAD. If you are watching Cable, Satelite or Antenna; it is likely you are seeing some BLOCK NOISE. This block noise is caused by missing information or Noise in the video signal. This will cause the picture to Pixilate (you see blocks and things start looking blurry too). This happens with poor signals. This also happens with the HD channels when they have more information than bandwidth (more data than that have space to send it...image shoving an elephant into a VolksWagon Beetle)
May 27, 2009 | Televison & Video
Blurred images
i beleave on auto, the a75 has auto focus, there is a 1/2 second focus time before the picture is taken, enough to blurr the picture
Jan 03, 2009 | Canon PowerShot A75 Digital Camera
Fuzzy Images
There is insufficient light indoors, so the camera is selecting a slow shutter speed, which is causing camera shake, hence the 'fuzziness'.
Apr 02, 2017 | Nikon COOLPIX S7 Digital Camera
Extremely blurred pictures
try using a different setting on the camera for these pictures, use the scene selection and choose night scene.
Oct 24, 2008 | Sony Cyber-shot DSC-W80 Digital Camera
Nikon D40 will not focus
on the right side of the view finder there is a little bar. Make sure it is all the way down. If it is in the up position then it will make the viewfinder, shouldn't make the images blurry though. Also make sure it is in AF not MF (auto focus and manual focus).
Oct 21, 2008 | Nikon D40 Digital Camera with G-II 18-55mm...
Fujifine pix A330 produce blurred image on all picture taken
continuous blurred images? or only occasionally (say in low light)?
Mar 30, 2008 | Fuji FinePix A330 Digital Camera
Blurry internet phot's
kindly brief your question again as i cant understand your question
Dec 03, 2007 | Computers & Internet
Backwards Image on LCD
The manual for this camera is very well documented. I can see where poor lighting can cause out of focus and the aperture not set right and the camera moving during the shot but not the image being backwards if I understand you correctly. Sounds like she simply shot into a mirror. Did the camera get dropped by accident? That could knock an "internal connector" slightly off causing the electrical signals to cross. The connectors in these cameras have extremely small traces and it doesn't take too much to misalign a trace with the connector. I'd explore that possibility first. Then call Olympus on this one you might need to service the camera. PS: I use to test my tech's trouble shooting ability by reversing connectors to get the same effect.
Sep 15, 2007 | Olympus Camedia C-2100 Ultra Zoom Digital...
Exposure control options
The following exposure options are available: P (Program auto), A (Aperture priority), S (Shutter priority), and M (Manual). There are five scene programs modes available in which the camera will choose the optimal settings for the picture: - Landscape + Portrait: Suitable for taking photos of both you subject and background. The picture is taken with the background as well as the subject in the foreground in focus. - Landscape: Suitable for taking photos of landscapes and other outdoor scenes. Both the foreground and the background are in focus. Since blues and greens are reproduced vividly in this mode, the landscape mode is excellent for shooting natural scenery. - Portrait: Suitable for shooting a portrait-style image of a person. This mode features an in-focus subject against a blurred background. - Sports: Suitable for capturing fast-moving action such as sports scene or moving vehicles without blurring. - Night scene: Suitable for taking night scene photos with a slower shutter speed.
Sep 04, 2005 | Olympus Camedia C-5060 Wide Zoom Digital...
Polaroid i830 Digital Camera Logo
88 people viewed this question
Top Polaroid Cameras Experts
Greg Cann
Greg Cann
Steven Wander
Steven Wander
Are you a Polaroid Camera Expert? Answer questions, earn points and help others
