Question about Whirlpool ED5SHAXM Side by Side Refrigerator
Whirlpool Refridgerator - Damper Control Noisy
Whirlpool Bottom-Mount Refrigerator Model # GB9SHDXPS01
Control, Damper Part# 8208195
Shortly after we purchased our refrigerator we noticed that it was gradually getting noisier. With 1 month before the warranty expired we had a service call to replace the Damper Control. That solved the problem for about 8 - 10 weeks but now it is noisy again and the warranty is expired.
I'm positive that I can replace the part myself but how can I be sure that the replacement part doesn't become noisy as well? Does Whirlpool have a bulletin or superseded part that is more reliable?
Bruce
  • bcarmich Mar 09, 2009
    Nicesuit,
    I'm in Canada and they say that the part is not covered after the warranty period even if it was recently replaced within warranty.
    I bought a new part and installed it myself but the part I replaced looked like plastic components of the housing were deteriorating after only 4 months.
    If the new part fails in 4 months and no improvements are made to the replacement parts then it will cost me $150.00/year just to own this POS.
    I'm very dissappointed with Whirlpool.
    Bruce
  • Nicesuit
    Nicesuit May 11, 2010
    You are in the UK? if so any fault that was reported and repaired within the warranty period is covered for a further 12 months after the repair. They will hit you with it may cost you X amount for the repair but if it is the same thing they can not charge you.
  • 198 Answers
SOURCE: Water Dispensor leak on Whirlpool Refridgerator
The solenoid valve needs replacing, located at the back of the refrigerator. If you have well water you will need to install a filter on the supply line.
Posted on Jan 05, 2009
  • 7 Answers
SOURCE: Whirlpool Refrigerator Internal Liner Cracks
If it is a Kitchenaid brand, the liner is covered under full factory warranty for up to 5 years. (See your warranty guide page). I am the Svc Mgr of an Authorized service center and relayed to one of my customers this morning, that if they took photos after the repair was made and call customer service, they will tell you where to send them. If...and they will agree the repair is un-sightly, you get an exchange. I am not sure it will work with the Whirlpool brand even though they are in the same family ** all made by same company, Kitchenaid cost more and comes with a longer warranty.... hope this helps. Florida
Posted on May 05, 2009
buddymcl777
  • 67 Answers
SOURCE: Whirlpool ED5PHAXSB side by side refrigerator not cooling...
There are a lot of possibilitys. You'll have to use the process of elimination.
But it could be the thermostat (make sure your setting is midway) The milk spoiling indicates it is too warm so bacteria is breeding
Get a refrigerator / freezer stand alone thermostat (about $5) That will give you accurate readings. The fridge shoud be between 35 and 40 F and the freezer 0 plus or minus 3 when set correctly
It could be your condensor fan is clogged or just that your coils need cleaning (underneath or behind) Use a vacuum with the brush end or chisel point. Dust can cut you efficiency by 20 or 30% by itself.
Assuming this is frost free model the defrost timer may be acting up in the freezer.
Forgive me for not knowing where the coils are and if it is frost free but I can't find a manual for this particular model. However the principles apply in any case.
Posted on May 09, 2009
jumptrout51
  • 3361 Answers
SOURCE: turns off won't turn back on unless you move thermostat
Sounds like a defective cold control ( off/on thermostat).
They will tend to stick in the off position. Your moving the knod unsticks it.
Posted on May 24, 2009
EllaWatson25
  • 725 Answers
SOURCE: Whirlpool Gold refrigerator water leaking
If it's flooding, it's NOT the drain pan. It's probably the water valve has gotten stuck in the open position. Hope this helps!
Posted on Aug 21, 2009
Repair flashing light in refrigerator model frs6hr5hsb6 flashing number4
A flashing four (4) is indicative of a damper circuit issue. It is either the damper or control. Unplug the unit and open the fresh food door when you plug the unit back in you should hear the damper move If it is really loud it is bad. You can drop the control, it is held in place with 1/4" screws and observe the movement or lack of. If the damper is operational and not noisy replace the control with the flashing four(4).
Feb 18, 2015 | Frigidaire FRS6HR5HB Side by Side...
I have a Whirlpool Refrig. model GX5FHDXVY04. The freezer is working properly but the refrigerator is not cooling. I noticed frost on the inside back panel of the freezer. I turned the temp down in the...
Many of frost-free fridges use fans to move a controlled amount of air into the upper or side cooling chamber, check for non-working fan or a stuck or malfunctioning damper control. Keith L.
Mar 02, 2012 | Whirlpool 24.8 Cu. Ft. Side-by-Side...
The Whirlpool Gold refrigerator is not cooling and the bottom freezer has ice formed on the back of the freezer. I purchased the refrigerator in February 2009.
If you can hear the fan running in the freezer you have a defrost issue. Depending on the Model number it can be a timer, adaptive defrost board, a bi-metal themostat, or heater.
May 26, 2011 | Whirlpool 24.8 Cu. Ft. Side-by-Side...
I have an Amana ARB2217C bottom freezer with working lights, fan, and freezer. But the refrigerator doesn't seem to want to cool. I think it stopped a couple of days ago.I've turned the thermostat from...
The problem has to be in the damper control inside the refrigerator section.
Disconnect the refrigerator from power and remove the food from the top shelf. The damper control is in the box near the top of the refrigerator section behind the temperature control knob.
Remove the knob and cover until you can access the damper control. You can prop the damper control open with a pencil or something to make the refrigerator work until you get a part if you need to. Here is the part you need.
Feb 19, 2011 | Amana ARB2217C Bottom Freezer Refrigerator
Freezer working but refridgerator at room temp. Door seal hot.
either the evaporator coil is iced up which means the defrost heater is bad,the defrost control is bad or the damper vent door which throttles cold air in isn't opening fully from the freezer to refrige,the evaporator fan isn't running or if electronically operated the main board behind the unit can be bad on these as this board controls all electrical issues
Jun 20, 2010 | KitchenAid 19.7 Cu. Ft. Side-By-Side...
Freezer has ice in it
Sounds like your refrigerator is not defrosting or there is some other air flow problem with your unit Melanie. Could be a problem with either your defrost heater, defrost bi metal thermostat, defrost control, evaporator fan, air damper, air damper control, or some other air flow issue. I would recommend you have a qualified refrigerator repair service inspect and diagnose your unit.
Apr 07, 2010 | Maytag 18.6 Cu. Ft. Bottom-Mount...
I have a Maytag RSD 22a refrigerator that has ice built up in bottom 1/2 while the top and refridgerator it's self is not cold, I just got it. It blows air but never has been very cold.
Whirlpool refrigerator and freezer problem. a cup was place in the refrigerator to catch the percipitation coming from an inlet from the freezer. Which they are two inlets located in the center back of the refrigerator from the ceiling adjacent to the floor of the top freezer. the Freezer back t-shape vent goes down to these inlets where the percipitation is coming from. What is this the damper
Mar 17, 2010 | Refrigerators
Whirlpool ED5SHAXM Side by Side Refrigerator Logo
370 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
