Question about Epson CX8400 All-In-One InkJet Printer
Epson cx8400 wants me to replace colored inks
When i set the printer to print in only black, it still wants me to replace the cyan, magenta, and yellow. why doesn't it just print with only a full black cartridge? how can it require you to have all the colors when you only need black?
  • Stephen Siasico May 11, 2010
    Epson printer's when printing on black it needs all inks even you are printing on black ONLY. It is the design of their printer.
  • 1,049 Answers
Yep
Posted on Mar 10, 2009
3 Suggested Answers
SOURCE:
svenby
  • 66 Answers
SOURCE: Epson C82 & C84 Printers will not laydown any ink!
your printer is clogged and i think it is impossible to unclog. you can try to use the flllowing link( unclog solution) cost 10 usd!!
good luck http://www.fixyourownprinter.com/kits/epson/K89
Posted on May 09, 2008
aicaxz
  • 511 Answers
SOURCE: Am getting an error message that the printer
Insert all ink tank. Turn on printer. Check status. Replace ink tank using "how to" procedure at status monitor. But you do'nt need to unplug ink tank, just follow, next... next... ok. Last, procedure is ink charging. When chip recognized, ink cahrging will done. But if not, the screen "doesn't recognize the ink " will appear. Don't close it. Push ink button minimum 3 times. 1 to move head to checking empty (error) ink tank, 2 to move head to gap. 3 to move head to parking position. It's methode to force epprom.
Posted on Jun 24, 2009
How can i use epson stylus c45 without black ink its urgent plz
If this is a color printer, then you cannot use it without the "Black" cartridge.
Most printer manufacturers will pull from the "Black" ink to print black on color images. They do this to save on creating a "processed black" from the color inks.
Just curious, are you using a "CMYK" system? (Cyan, Magenta,Yellow and Black inks)
Don
Nov 02, 2009 | Epson Stylus C46 InkJet Printer
My printer wont print black and white only
My Epson Stylus cx8400 uses ink so fast. I would like to turn this into a black and white printer only. The problem is, I am out of one of the color ink cartridges and it won't let me proceed until I replace it. Is there a way, in the mode it's in now, to get this to print with the black and white only? I am nearly out of ink on all color cartridges now and do not want to purchase more at the high cost they are.
Thank you!
Oct 14, 2009 | Epson Stylus Multifunction Inkjet Printer/...
Colour Ink Jet Cartridges emptying during a black ink print run
If you go to your printer properties, there should be a setting whereby you have to select the option to "PRINT USING BLACK CARTRIDGE ONLY". Make sure this option is selected, otherwise your printer will use ALL colors even if you only print black.
Let me know if you need any further assistance.
Best wishes,
Graemevm
May 07, 2009 | Epson Stylus DX6050 All-In-One InkJet...
Very Faint Printouts
I find the best way to clean the heads is buy some cleaning cartridges as they have cleaning fluid in them and use them to clean it will take about 10 or more times to clean the heads then put the color ones back in and try again.
Just keep putting it on clean the head don't do a print out till at lest you have cleaned 10 or more times.
Rgs
The StickMan
Dec 08, 2008 | Epson RX620 All-In-One InkJet Photo...
Blue tint suddenly appearing on all my photos
you may need to run a clean on ur nozzles and check if you are low on ink.
Jun 13, 2008 | Epson Stylus Photo R300 InkJet Printer
C88 / T060 cartridge refilling problem
sounds lke your yellow nozzle not working properly...had same issue on lexmark printer, ended up geting this epson...learnt from my mistakes...perhaps it ran dry? or you left the yellow cartridge out longer than the rest....only you might know what happened
Mar 22, 2008 | Epson Stylus C88 InkJet Photo Printer
Epson cx5000 Ink Cartridge shows ink is running out after 2 8 x 10 prints.
IT IS POSSABLE THAT THE PRINT HEAD ARE DIRTY THEY HAHVE MATCHING BOARDS TO THE TONER CARTRIDGE BOARDS UNPLUG THE MACHINE AND CLEAN THE PRINT HEAD WITH ALCOHOL IF IT DOESN'T WORK THE BOARDS HAVE FAILED
JP
Dec 31, 2007 | Epson Stylus CX5000 InkJet Photo Printer
Epson CX8400 All-In-One InkJet Printer Logo
251 people viewed this question
Top Epson Office Equipment & Supplies Experts
Inky Fingers
Inky Fingers
Clive
Clive
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
