On this website (loink below) you find fuse box diagram for Fiat Scudo mk 2
Fiat Scudo mk2 2006 2016 fuse box diagram Auto Genius
SOURCE: fiat scudo van engine light
sound like a wiring problem check the starter and ignition switch could have a short to ground or short to power
SOURCE: the gauges on my fiat scudo ie temperature ,speedo ,,clock mileag
check fuse 5 and 12 behind glove box
SOURCE: fiat scudo starts and runs for 8 secs then cuts out
8 seconds and stall,..
Sounds like you're starting fine and there's no apparent problem with the engines electrical impulses in regards to wires, plugs, coil etc,..
Which it sounds like you're running off residual fuel but continuous fuel supply is being disrupted.
I'm all but certain if you pull a SP it'll have unburned fuel on it. Check your fuel pump, filter, pressure regulator and injectors
From those symptoms the pump could be faulty, filter clogged and only feeding seepage, the regulator could be flooding it out ot the injectors aren't opening { clogged }
What do you get when you try to press the accelerator when it's running or have you not tried that?
SOURCE: Fuse box layout for 1996 Fiat Cinquecento?
usually on the under side of the fuse box cover there is sticker with the layout of the different fuses. Look in the owners manual that's in the glove box, that should show the layout.
