Question about Dell Inspiron 1420 Notebook
BSOD in Vista, then restarts itself in XP
I used to get a BSOD randomly whith Vista... Then, I eliminated Vista and installed XP and the installation worked OK, but when i begun to install some drivers that missed, my laptoip restarted itself (no BSOD)... Now It restarts itself randomly after about 2 minutes of work
Can you help me?... What can I do?
Thank you
  • 3 more comments
  • franklinrdl Mar 02, 2009
    The laptop keeps restarting and there aren't error messages in the event viewer... I reinstalled XP and everething was working ok. XP loaded several drivers by itself during the installation process but there were some drivers missing... Then, everything seemed to be working fine until I installed the first missing driver manually. In that moment I got the mysterious restart again... After that, I tried to complete the installation of all missing drivers while the computer kept restarting randomly... still can't find a solution
  • franklinrdl Mar 06, 2009
    So far, I've find out the BSOD appears even before the installation of the first driver... The BSOD I'm getting is Code 0x00000124 BlueScreen
  • ice48507
    ice48507 May 11, 2010
    Hmm... Will it boot in safe mode? Last known good?
  • ice48507
    The driver you installed before the BSOD. What was it for?
    Sergeant:
    Novelist:
  • 190 Answers
I checked the stop error and the stop error you are getting is a hardware failure error. I like the suggestions given by Geekman. The only problem you might have is that you may not be able to do a system restore if you cant get windows to load into any mode. If you run into a problem with getting into the system after one of your updates then there are ways to do a system restore manually. You can do it with the command prompt or a Windows Preinstall environment like Barts PE. Heres a site with the step by step instructions depending on how you want to do it:
http://www.icompute.info/System_restore_from_xp_cd.htm
http://www.icompute.info/restore_with_B_PE_disk.htm
Posted on Mar 07, 2009
  • Dell Master
  • 32,281 Answers
You have a driver problem, possible conflict.
Go to the Device Manager and see which devices that need installing and are not working.
You could disable the drivers you installed and enable one driver at a time and test for stability before you enable another driver.
OR
You could reinstall XP again or restore back to a date before you installed any drivers and then install one driver at a time and run your laptop for a while to see if it is stable before you install another driver.
Posted on Feb 27, 2009
  • Chris Hingee
    Chris Hingee Mar 07, 2009
    What was the 1st missing driver you installed?
    Have you installed the Windows Service Packs? For XP you need to install SP1 first and then install SP3 (SP3 includes SP2).
    This should be done before you install the drivers.
    This problem started after the driver was installed and this is the cause of your problem.
    I would go to the Restore point before the installation of this driver, and after the restore, check and the computer to see if it is functioning properly. If you haven't install the Windows Service Packs do this defore you Install the other drivers next. Suggest you download the latest drivers first.
    You may have to reinstall Windows again to get a clean install.
    If you do, create a Restore Point (give it a name Clean RstP + date) so you can go back to this in the event a driver install didn't work. You can create subsequent Restore Points as required.
    Also after you have installed the drivers and all your programs, I would create a new Restore Point.
    Check the Dell WEB site to download the new drivers (get the latest XP version) also use the Service tag number, this will ensure you will get the correct drivers for your model laptop.
    This is time consuming but it is worth the trouble to get a stable functioning computer, besides you have learnt something.
    Have fun.
BSOD AFTER CLEAN INSTALL 2X
Since you are getting the same result from the same actions I would say that you should change the hard drive. It may be defective.
Mar 16, 2014 | Gateway NV79C48u Laptop
My HP g62 INTEL core i3 laptop encountered some problem of hanging.The CPU usage will go 100%, surely that cause of Hanging..What will I do? do I have to reformat it? how will reformat it!
usually this is happening when the cpu temperature is getting to the max..(cause of forced to the max of capacity ..) and the blue screen with the memory dumping kicks in and restart ..
first check the BIOS settings not to have a temperature limit set for the cpu ...and to do that just get to bios by pressing F2 on start (or del ) and in there look for optimal factory defaults..and engage them ...If you look around it is a feature with this name ..the function key is different from a model to another..) after engaging it ..just press F10 to save the settings and confirm with enter to restart ..
If it still makes the issue ..than the operation system and one of the programs running on it ..have a compatibility issue and you have to either eliminate the program ...(usually is the usage of a free antivirus ..on a recent operation system ..like Vista or windows 7 ...and eliminating the antivirus and installing one from Microsoft may fix it ..o r...just roll back to an earlier operating system ..for example from windows 7 to Vista or XP ...cause it is not supported well by your system and makes it block itself.. I sow this problem a lot of times ..and I usually reinstall the operation system and install a windows XP ..and it is well tolerated with all the programs and such ..
To do so you will need a CD with a boot-able OS ..and the drivers for it ..for the devices..(at least the lan card driver to connect it to the net and seek the others after ) ..
here are some guidance for the installing process...
http://www.wikihow.com/Install-Windows-XP it has a video too on the bottom and it is very accurate ..
installation for Vista is much simpler and all you have to do is to get yourself a dvd with the operation system (boot-able 0 and start the computer with the dvd in ...and also confirm by pressing any key the boot from cd ..and follow the tips ...It will almost install itself ..
Jul 14, 2011 | HP G62144DX Laptop
I am having numerous problems.... (1) Laptop will not turn on straight away, it takes several attempts (2) "Blue screen of death" appears very often, particulary when I move the laptop (3) Laptop restarts...
With the information you provided me, yo ucan try using check disk to see if there are bad sectors on the hard drive itself. usually the BSOD indicates where the main problem is. try searching the coe online, sample 0x0000007E . try looking for any inromation about the error.
Sep 05, 2010 | Acer Aspire 5920-6335 Laptop
I hav an acer 5230e ,i want to install window xp but on window setup it shows blue screen error nd appear plz remove newly installed drive nd chkdsk on run /////////////tell me wht i do?
heeey dude ! I had the same problem.. and I just solved out how to fix the problem !.. the only thing you have to do is: Go to your Bios, and switch from SATA to IDE, and then it will be fine :-)
Apr 05, 2010 | Acer Computers & Internet
I cant install vista on presario cq61 105sa??
Hi
Sometimes getting around these virus problems can be a little tricky. I've found, in my own business that when reinstalling VISTA it will give problems. To eliminate those I use a Linux program called Gpartition. Its free and down loadable. You can use this to completely eliminate anything on that partition (wiped). Then restart VISTA and it should see a blank disk and want to format it. Goodluck
Mar 10, 2010 | Computers & Internet
Down graded from vista to xp pro with sp3& sata but on boot up it blue screens. run bart cd the same thing xp screen then the bsod, help
Did you previously have XP on it ? The 2 OS are not compatible with each other and you may have to install XP fresh. Save your docs by reverting back to Vista first and setting up a partition or a dual boot situation.
Mar 01, 2010 | Compaq Computers & Internet
I want to install XP in lenovo y510
okie! a question? i have installed windows Xp with Sp3 on my Y510. Now whenever I try switching back to AHCI mode i end up with a BSOD. would it make any difference if i leave it in the compatibility mode? or how can i get it back to AHCI mode
Feb 17, 2009 | Lenovo IdeaPad Y510 Notebook
R3000 Compacq laptop wont boot up
Hi.
Can you please give me full details on what the problem is, the BSOD, does it appear after the boot is finished and loading the OS?
Does the OS start and then get the BSOD, ETC.
If You have the original install cd, enter your bios and at BOOT DEVICES [OR BOOT SETTINGS] make sure that the first device to boot from is your cd/dvd etc, Put The Cd of the OS in the cd/rom and restart the machine, it will hopefully start the instalation of windows do not tell the program to install a fresh copy, but rather use the R for repair.
If that does not work or you still have problems it sounds like it's time for a new instal of windows, the BSOD [Blue Screen Of Death] pops up when files get damaged, if you overclock without checking everything voltages, fans, TEMPERATURE of CPU etc.
Also can you please tell me how long ago the system was activated, and what if anything did you do or were working on when you got this BSOD.
What the OS you are using is can help also, and is it sp1? sp2? sp3? for win XP even vista is up to SP1 already for a supposed new os from ms.
HTH
Zues
Dec 21, 2008 | Computers & Internet
Acer Aspire 5630
Seems like your VISTA upgrade didn't sucessfully upgrade itself from XP to VISTA. Seems like M$ update program detects your OS as XP and tries to install the SP3 for XP. VISTA only has SP1 released. Its currently stuck in a loop that it doesn't know what to do. Restart your laptop into safe mode by pressing F8 before the VISTA loading page comes up and go to Safe mode and backup your data and use the ACER RESTORE CD OR ACER RESTORE METHOD to help you reload your system back to factory defaults then upgrade back to vista without install any updates or connecting it to the internet.
This is my best solution to get you out of this weird and unusual situation.
Jun 30, 2008 | Acer Ferrari 4000 Notebook
Dell Inspiron 1420 Notebook Logo
Brian Sullivan
Brian Sullivan
mukhtar21 shaikh
mukhtar21 shaikh
