Question about Whirlpool Ultimate Care II LSQ9564J Top Load Washer
Washer will fill up but then it wont go to next cycle it just makes a humming noise
  • Ed Burnett May 11, 2010
    Does the washer go through cycles manually, i.e., if you turn the knob will the motor run and turn the tub and or spin?
  • 25 Answers
Could bad coupler between motor and gearbox.
Posted on Mar 08, 2009
When i close lid it just makes humming noise and wont start
If washer hums but doesn't fill, water isn't getting to washer check screens where fill hoses connect to washer. Screens may be blocked. If washer fills then hums check to make sure belt is on. Tip machine up to view belt underneath.
Sep 26, 2013 | Maytag Ensignia MAV2757AWW Top Load Washer
Whirlpool dishwasher will fill with water but washer cycle wont kick in just makes a humming noise
Your pump could be jammed or plugged. Make sure the grate in the bottom of the washer is clean. If possible, pull it out and look under it to see if there is anything in the hole.
Jan 08, 2011 | Whirlpool Dishwashers
My washer fills with water then just makes a humming noise wont go into next cycle. model number 363.1556990
sounds like a lid switch jumper it and seeif that works you will have to take machine apart to get to switch
Jul 25, 2009 | Kenmore Dishwashers
My GE washing machine is stuck on agiation mode.
HUMMING NOISE MAYBE OVERLOAD ON MOTOR OR PUMP SO DEAL NOW WITH DRAIN PROBLEM 1ST IT MAYBE NEED TO DRAIN FILTER CLEAN
THANKS
Jul 15, 2009 | Washing Machines
Kenmore washing machine fills with water then stops
turn the motor to see if it moves it sound like the motor
May 02, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore front-load washer stops at rinse cycle
When the washer initially fills for the wash, is it only hot water entering the drum? Try switching the water temperature between hot and cold as it fills. If any of them show little or no water getting through, it sounds too easy but check to make sure water supply taps are on, and that the cold/hot fill hoses aren't reversed. Remove the fill hoses and check any of the screen filters for blockage (in the hoses and in the inlet water valve). When the machine stops and waits to fill but all you hear is a hum, it sounds like there is power going to the valve but water is not able to get through it.
Mar 03, 2009 | Kenmore 43142 Front Load Washer
Washer will fill fill with water but doesn't start wash cycle
it will fill but won,t spin, will throw out water as if it washed, then it take water to rinse but won,t spin ,then will throw out water as if it did , but clothes are soaked
Feb 21, 2009 | Roper RAS8445KQ Top Load Washer
Loud humming noise when dishwasher is filling up with water
your model is pretty new. just so you know your warrenty is 1 year parts and labor. 2 years on parts. it should not cost that much money.
there are two components that start before the circulation pump.(wash noise you hear)
first sounds you hear will be the drain pump. usually rattling noises if something is in it but it can make a hum noise if something is jamming the drain propeller up. which is accessible with a T20 torx driver. take the filters out and the mesh filter. and unscrew the screw in the base towards the left. pull out whatever is lodged.
the other humming sound can come from the next component that activates is the watervalve. make sure you dont have a kinked water intake line. otherwise its a bad valve. i have had to change a few of those water valves out already but not for a hum noise on your model. you have a new style water valve. when brands make new parts we get problems fast sometimes..
Feb 14, 2009 | Bosch 24 in. SHE44C02UC / SHE44C06UC /...
Clothes washer just makes a noise like a gear spinning ?
I was having the same problem with mine so I took it apart. There is a plastic coupler-like device that connects the drive motor to shaft which allows your "spin" cycle to commence. This coupler has posts in side it but they are under the little belt. My posts were all broken so the bottom piece of the coupler was spinning but the top was not, so it just made a humming noise. This part is available at
http://www.searspartsdirect.com
partNumber=3363664
Nov 24, 2008 | KitchenAid KAWS850L Top Load Washer
Rinse cycle doesnt work
the humming noise is probably the cold valve operating but no water. check tap not turned off. slowly loosen cold water feed and check if water present
May 02, 2007 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Whirlpool Ultimate Care II LSQ9564J Top Load Washer Logo
65 people viewed this question
Dan Webster
Dan Webster
Sal De GO PATS
