Question about E-Mu 1616M Sound Card
No internal wave signal
After emu1616 instalation external inputs work fine (like mic, guitar or external cd-player) but wave signal from computer (from hard disc or cd-drive via EDI cable) sounds too slow ( sampling- pitch problem) and distorted like overload.
    Scholar:
  • 87 Answers
Sample rate is wrong. You most likely have a bad codec installed or the wrong drivers for the audio card. install direct x if your on windows and install the manufactures site
Posted on Mar 07, 2009
External Mic does not work on my Netbook but works fine elsewhere
All sources of line-in provide a signal with at least 250mv of amplitude. The average pc microphone (condenser type) generates at most 2mV and needs to be powered by the entry in ord.er to work. So it is physically impossible to make a mic work on a line-in connection unless the connector can be configured act like a mike entry - almost all modern ones can.
Mar 14, 2010 | Computers & Internet
I get a quiet signal when using the mic.
You should use the mic input of your computer.
If it's not there, use a microphone pre-amplifier.
Regards,
Gerard
Feb 17, 2010 | Shure SM57-LC Professional Microphone
I cant make the onboard mic input work
Have you checked the settings in BIOS. That would be the first place I checked.
Dec 02, 2009 | MSI KM4M-L Motherboard
Digitech Vocalist Live 4 blead through
You need a directional microphone, and then it needs to be pointed away from the guitar. Another technique would be to provide some acoustic insulation between the mic and the guitar, like a wall or a partition like what is used to set up office cubicles.
Feb 23, 2009 | Digi-Tech Digitech Vocalist Live 4...
Vocal mic
You can plug a mic into the front H input on the 2488, but depending on the type of mic you may get a weak signal. The typical voice mic is low-Z (low impedence) and the instrument input (H) on the front of the 2488 is High-Z. A high-Z input is expecting the relatively higher voltage put out by a high-Z mic (or passive guitar pickup). On the other hand there are high-Z mics out there and most computer mics are high-Z. These produce the voltage that a high-Z input is expecting.
If however your mic is low-Z you will get a weak signal on the high-Z (front H) input on the 2488. You should in this case connect an impedance matching adapter between the mic and the input. It steps up the voltage of the mic, giving it a stronger signal.
To tell what impedence (Z) you mic is use the following to match the rated ohms on your mic with the impedence:
low-Z = 150-300 ohms
medium-Z = 600-2000 ohms
high-Z = 10,000 ohms or more
If you already have a high-Z mic you can plug it into the front H input directly. For a high-Z mic plugging it into any of the other low Z inputs on the back will produce a distorted signal.
Hope this helps.
bd.
Aug 19, 2008 | Tascam 2488 Portastudio Multitrack...
EMU 1616m (cardbus) not offerring its input sources to Reaper
While you probably solved this already here goes. I'm not familiar with reaper but most audio recording software can select between using windows wdm & ASIO. If you aren't set to ASIO you won't be able to see the Hi-Z (Dock A/Dock B) inputs. It looks like Reaper supports ASIO so that should be fine. If though you are using a program that doesn't support ASIO you need to use the EMU patchmix and 'patch' the input through to a 'wave' channel.
Mar 19, 2008 | E-Mu 1616M Sound Card
Low record level for guitar
first of all you want to have your guitar amp at a decent volume but too loud, just enough to be able to get a good signal. when you have done this turn up the gain on your mic channel so that your VU meter (level meter) on the recording software shows a reading of about half way up the meter. If you can not achieve this with the soundcard alone increase the gain on your channel in the software.
This sound guarantee a good signal but as with most recordings you will still have to boost the signal without it peaking. to do this use a compressor or a limiter and turn the gain up. if you use these dynamic effects correctly you will achieve the guitar level you want.
Jan 25, 2008 | M-Audio Fast Track USB (FASTTRACK) Audio...
Audio Inputs suddenly producing buzz/broken
The UA 25 needs a GOOD quality USB cable, the thicker the better. Cable loss means that by the time the 5V power supply from the computer reaches your Edirol, the voltage has dropped to about 4V, which then has to be boosted back up to 5 Volts and inverted to -5V.
Cheap cables will hamper performance or prevent it working at all ( I lost 2 hours once with this problme ) . Also avoid using the FRONT USB connectors on PCs, use the connectors that plug direct into the MOBO on the rear of the chasis.
Good luck
Dec 22, 2007 | Edirol UA-25 External Sound System
Problem with guitar
1.make sure the guitar/mic switch is pointed to the guitar side. increase the guitar/mic level. increase the output level. 2.another thing you can do is check the "sound and audio devices" to see if everything is set to Edirol UA-4FX. If everything isnt, fix it so that it does. and remember to disable your computers stock sound card. Edirol UA-4FX is your new sound card from now on. 3. if thats not the case, try reinstalling the drivers. 4. If all of the above fail, you probably have a loose connection/ bad wiring in the guitar/mic 1/4" input. you can choose to open up the device and solder that yourself and possibly lose your warranty or have the entire unit replaced. Hope I helped! good luck!
Apr 30, 2007 | Edirol UA-4FX External Sound System
Open Questions:
E-Mu 1616M Sound Card Logo
122 people viewed this question
Top E-Mu Computers & Internet Experts
David
David
Willem.
Willem.
Steve
Are you an E-Mu Computer and Internet Expert? Answer questions, earn points and help others
