Question about Acer Aspire 6930-6771 Laptop
My aspiire 6930 wireless touch on/off isn't working
My aspiire 6930 wireless touch on/off isn;t working i have used driver detective and it says i dont have the driver anymore i tried to download it and it still doesn't work help please
  • Anonymous Mar 07, 2009
    We have the same problem. We have two Acer 6930 laptops that all the sudden drop wireless. Pressing the button will say that Wireless LAN is enabled but Network connections says that it is not.
  • kozinsilicon Mar 07, 2009
    We have the same problem, two Acer Aspire 6930s that drop the wireless connection. Pressing the button says the Wireless LAN is enabled, but it is not. Network connections says that wireless is not enabled. I took one of them to Fry's, they took out the battery and plugged it in and then it was working again. Just doing that at home is not working.
    Problem Solver:
  • 11 Answers
Well your first mistake was buying an acer and your second mistake was buying a cheap one
get a computer expert to open and check that the wireless switch is acctually connected to something it might have got loose to the cpu so it says it is on but it actually isn't
Posted on Mar 10, 2009
    Problem Solver:
  • 10 Answers
You mention the battery being taken out by they guy in the shop and then the laptop working. I don't know if it's anything to do with your problem but the batteries can cause all kinds of problems when they go wrong ( they have programmed IC circuitry which can interfere with functioning of laptop). Taking the battery out and plugging into the mains would prove this. It seems that you may have tried this already though.
Posted on Mar 07, 2009
  • 102 Answers
You have to try another operating system or reinstalling your current one. Or you can try updating your BIOS form the company's website
Posted on Mar 06, 2009
My acer aspire 4738 laptop cannot detect wireless connection and tells me that the wireless adapter is broken. . .what is the problem ?
Check if you are connected to network like Home. Also whether wireless router is close by. Join network and try.
Aug 22, 2013 | Acer Aspire 6930-6771 Laptop
I have Acer aspire 6930 its touch pad not working i installed the drivers also. I am using windows7 OS
Go into your BIOS on the laptop when you first turn it on. Go in there and see if there is a setting for the touchpad. If there is then go ahead and make sure its enabled. If there isn't then you'll need to take apart the laptop and reseat the connector that goes from the touchpad to the motherboard.
If that doesn't do it then you'll need to get the touchpad replaced.
May 27, 2011 | Acer Aspire 6930-6771 Laptop
I hav acer aspire 6930 laptop.when i use to run the laptop with battry it works properly but as i plug in charger and try move the cursor it move frequnty anewhere just i touch the touch pad........and...
That's very odd. My 6930 touchpad was too sensitive so I went to Synaptics and downloaded the driver which includes a lot of settings and adjustments you can try.
Apr 23, 2011 | Acer Aspire 6930-6771 Laptop
Acer 6930 wireless adapter failure conflict
Most Acers use a form of Intel IPN2220 Wireless card. If yours does, you use XP and your router is using WPA or WPA2 (TKIP or AES) security then you'll need to update the driver by searching for it manually using the Custom button (Hardware) in Windows update (instead of Express). This driver is not part of XP service pack 2 or 3. Like me you've fallen foul of thinking that keeping your computer up to date using Automated Windows Update will keep everything in good order when in fact it can generate more problems than it solves
Oct 03, 2009 | Acer Aspire 6930-6771 Laptop
Aspire 6930 wireless button not working
Without any wireless networks available, using your computer wirelessly is most pointless. If you want to set up a wireless access point in your home you need a wireless router, connected to Internet.
Sep 18, 2009 | Acer Aspire 6930-6771 Laptop
Acer Aspire 6930 Touch pad not found
Please reinstall your Touch Pad Synaptics Pointing Device Driver then restart your machine.
Thanks
Aug 26, 2009 | Acer Aspire One PC Notebook
Cannot connect to a wireless net work
manually jst switch on wont serve the purpose, please do go to control panel. internet options and check out for the problem. there is setting error in your pc..
Jun 23, 2009 | Acer Aspire 6930-6771 Laptop
Acer 6930 wireless won't connect anymore.
Hi acording your describle, you need do
1) please check the bios first, to set wireless to enable
2) check windows right buttom bar is there a wireless icon show there and click to see any detect wireless signal, if nothing to detect
3) check or compare to other laptop wireless configuration, check any incorrect setting.
4) if all sense ok, you need check the wireless card and wireless antenna wire connection, open a samll cover at back of laptop, there is a MINI PCI slot with a wireless card, take out and clean the card pins then put back.
5) still trouble please change another wireless card (same model)
it should be fix.
hope help you to fix it, please take a rating le me know how much helped you, thanks. for any question in any time please !
May 17, 2009 | Acer Aspire 6930-6455 Notebook PC
Acer Aspire 6930-6771 Laptop Logo
335 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
