Question about RCA P52926 52" Rear Projection Television
Contrast blooming/breathing. R-G-B bias and drive pot values
I own a GE 31GT656 ( CTC169AS2 chassis) manufactured 1/1993.
Problem One: It exhibits geometric "bending" as the contrast level changes in the program material (even with the contrast turned down). I purchased a new flyback transformer in an attempt to correct this. I also wish to replace the "HORIZONTAL DEFLECTION CAPACITOR " while replacing the flyback. I can't locate or identify this part. Do you know the value / voltage rating / part # of this capacitor ?
Problem Two. I wish to replace the TWO "micro" green and red/blue "DRIVE" pots. Also the THREE red, green and blue "BIAS" pots. These are worn out (with "dead spots") and too course in their actions to provide sufficient accuracy in setting the grey scale. Do you know the value of these pots? I hope to substitute a "resistor string" for finer control and accuracy if I know the original values of these micro pots.
Thanks,.....Gerry
  • 2 more comments
  • vitalvision Mar 06, 2009
    The picture shown was taken with a cell phone after the flyback was replaced . What's displayed is a Colorfacts test pattern called " adjust contrast " fed from my computer into the S-video input of the TV. Notice the deflection of the picture. Certain portions are "wavy" (especially at the top).The less white level present,the less geometric bending. When viewing regular program material containing little or no white level, there is no bending at all.(The two horizontal "white bars" are artifacts of the cell phone used to take the picture. They are not visible when viewing the actual set in real time).
    It's also a "warm up" problem. Turned off overnight, there is no color for about 5 minutes when turn on again.During "warm up", there is no geometric "bending". After 5 minutes, color intermittently disappears/reappear as I change channels. When warm up is completed (15-30 minutes), color is fully restored. But so is the "breathing" as white level changes from scene to scene.
    With the new flyback, using the Nokia "high voltage" alternating full black/ full white test pattern as a signal source, the "breathing" or "bending" issue is vastly improved over the old flyback. But it is not completely eliminated, even after full warm up. It's been suggested that I replace Horizontal Output Transistor Q 4401 /RCA part # 200167 (attached to the heat sink). I'm not sure replacing this part will solve the problem, but it makes intuitive sense to do so.
    Using the "Sound and Vision Home Theater Tune Up" DVD and displaying the "coarse focus" pattern from the "advanced test pattern" menu, the multiple "cross hairs" placed symetrically at various points on the screen are VERY distorted. Thanks for all your suggestions. It seems that there are a lot of capacitors to replace. The downloaded service manual is helpful but a pain to "read" on a computer. Here's the cell phone picture of "my problem".
  • vitalvision Mar 11, 2009
    Regarding download schematic for GE 31GT656 , chassis # CTC169AS2. It has discrepencies (errors ?) I can't figure out.
    According to service manual version 13 (page 12-68 &12-69) three BIAS & one G DRIVE are identical (part # 190533). The R/B DRIVE is part # 190531. And all three "bias" pots ALSO decribed as " DRIVE" ).
    Schematic (pg 9-10) contradicts this: says 3 bias pots = 4500 ohms, drive pots = 100 ohms.Schematic cordinates for these pots as follows.
    R 2926 (R/B DRIVE) : 89C - Part # 190531
    R 2928 ( G DRIVE) : 89E - Part # 190533
    R 2913 ( R bias) : 92C - Part # 190533
    R 2921 (G bias) : 92E - Part # 190533
    R 2917 (B bias) : 92F - part # 190533
    Who knows the correct part # and / or values for these 5 adjustment pots ?
    And I haven't even solved the contrast "breathing" yet. The snapshot picture shows "slanting" to the left. This "bending" is consistent with all normal programs (not just test patterns).
  • Henry McKelvey
    Henry McKelvey May 11, 2010
    Hello vitalvision,
    Are you in need of a schematic? I ask this question because you obvisouly know what you are doing, but you can not find the component values on the board, this is a sign that what you are asking for are the values of parts, and not how to go about doing the actual repair job.
    Here two sites I use to get schematics:
    http://www.manualsparadise.com
    http://www.servicemanuals.net
    the cost of the schematic is aroung 16.99 for a downloadable version.
    I hope this helps
    Shuttle83
    http://www.electron-age-technologies-llc...
    Scholar:
  • 133 Answers
The three bias pots are 4500 ohms part # 190533 each are the same. The two drive pots are 100 ohms part # 190531 each are the same . On your other problems your headline states contrast blooming / breathing , this could be a sign of a weak picture tube or the screen control could be set too low . Now as far as the bending as the contrast changes , i would need more info . for example if the screen changes from a dark screen to a bright screen and the sides pull in suspect C4401 , C4402 or C4403 . Sometimes these tend to bulge at the sides . Now if C4402 is your problem also replace CR4402 . These would be the capictors in your horizontal section that give this chassis the most problems . Also a capictor in the power supply also is commonly bad in these sets . C4102 which is a 2.2mfd @ 100v . Now if your picture is not stable as far as the picture is full but everything slants alittle suspect the PIP module . Sometimes there are capacitors that are weak and won't let the picture stay stable . Hope i haven't confused you much but without seeing the picture its kind of hard to tell for sure . If you need any more info or part #'s let me know . TeamTech P.S. good luck in your repairs
Posted on Mar 06, 2009
  • 42 Answers
If the picture is only bending in on the sides the problem is in the pincushion circuit. If it is the entire picture there is a voltage regulation problem either in the power supply circuit or the power supply off the flyback transformer which is usually a diode and capacitor combination. If you want to go with the odds, replace CR4118 with part number 164590. You may want to put the original flyback in as there are many problems with aftermarkets and even if it is an RCA part it is still aftermatket. As far as the bias pots a little cleaning spray usually does the trick. I wouldn't worry about trying to get a perfect grey scale out of a 16 year old tube, the original pots are plenty accurate.
Where can i buy extra pot for ge 3 combo crockpot
In the manufacturing world most times they don't bother trying to stock parts like that. You just have to buy another used or new unit or buy another model
Dec 02, 2013 | GE 106851 6-Quart
Is not opening
Yellow Hibiscus, Mothers Day gift. My son brought it home last night.
2 blooms lots of buds. Blooms closed last night, today still not open. Transfered to larger pot. Added water and a little extra soil.
Nov 26, 2013 | Spooky House Studios UG Bubble Explode
Flower
Looks like a Asiatic Lily
May 28, 2013 | Home
What makes Whites appear so bright almost blooming that hurt the eyes
In the model listed here having contrast way too high can cause that--contrast should not exceed 70 percent and brightness should be a bit lower or equal--note as contrast is lowered the white smearing should lessen.
Jun 13, 2012 | Hitachi 50GX20B 50" Rear Projection...
I have a tube tv. the picture as lines and is blur that goes in and out.
If the lines are colored DIAGONAL lines, they are referred to as "retrace lines," which indicates either that the picture tube bias is set too high, or the brightness level is set too high.. If the blur occurs when the image is particularly bright or a particular color is bright, it is referred to as "blooming." This is caused by either a weak high voltage circuit or because the picture tube bias is set too high.
Is the picture set very bright? Try reducing the brightness control to a level where the retrace lines disappear, and reducing the contrast control below the level where the blooming occurs.
If the television is more than ten years old or has many hours of use, the picture tube may simply be deteriorating normally. By nature, they have a limited life span. Before you decide to throw the set out, if you are technically-inclined, try adjusting the bias and screen drive controls for the television as recommended by the set manufacturer (you didn't specify what make or model the set is), and you may get a few months or years of additional life out of the set.
Jul 05, 2011 | Televison & Video
Acer model AT3201W no picture?? Sound is great, everything is connected tightly. Checked the manual ...no help..
There are several things that could be the problem, as usual. However I did manage to get a set working with the following characteristics:
- Set powered on ok and displayed the Acer logo fine.
- All of the inputs had very low brightness and poor colour.
- The backlight was working and appeared bright.
- The picture was barely usable with brightness/contrast set maximum.
I figured the issue here was a loss of the picture settings in the eeprom in the unit. So I set about to find how to get to the factory menu to set these things. This assumes you can get a menu to display on the set.
To enter factory mode on the remote control press menu/menu/234/menu. You will see the menu displayed with some info in the top bar that is normally not shown.
Then on the front of the TV press Volume- and Channel+ at the same time and hold until the factory menu appears.
You may see that the RGB gain and bias values are low or 0.
If that is the case set the colour temperature mode to Standard and then adjust the RGB gain and bias values to the following:
R gain: 434
G gain: 482
B gain: 484
R bias: 270
G bias: 270
B bias: 264
Then set the colour temperature to Cold and enter the following values:
R gain: 434
G gain: 482
B gain: 484
R bias: 270
G bias: 300
B bias: 310
Similarly, for Warm adjust the values to:
R gain: 434
G gain: 482
B gain: 484
R bias: 300
G bias: 280
B bias: 264
Then, if this was the problem, the picture should be fairly adequate.
Hope this works for you...
BTW I must give some credit here to another poster who provided a similar solution to a different problem here:
http://www.fixya.com/support/t154524-tv_losing_its_channel_memory
May 07, 2010 | Acer AL2671W 26 in. LCD Television
Ziener diode
Yes, Zener diodes can work both on forward and reverse biasing. The primary difference between a zener diode and the ordinary junction diode is it is designed specifically to operate with a reverse bias voltage that is high enough to cause the the device to breakdown and conduct a high reverse current. Hope this answers your question and provides you with some help. If you need further assistance please let me know.
If you do not mind, would you please rate my help. I would very much appreciate it. Thanks
Dec 08, 2008 | HP Pavilion dv6000z Notebook
Amp : sansui au11000 blown transistors on driver board
may i ask you did you put silicone grease in your transistor and apply a good mica insulator in all of your transistor---------look for any burnt resistor or explosive capacitor -----check for scew tie your supply voltage to earth by wrong.
Aug 03, 2008 | NAD C320 2-Channel Amplifier
Color Problem after replaced Circut Board
When you replace the entire board in a Zenith TV, you must make the adjustments to align the new chassis with the old picture tube. You must adjust the CRT bias and drives as well as the horizontal and vertical parameters. On the older boards there were controls on the main and CRT boards but on the newer boards the adjustments are made with the remote control after entering the service mode. Tune in the shopping channel QVC, set the color and contrast to minimum and lower the brightness until the picture is just visible. Set the CRT bias settings for a pure black and white image, then increase the brightness and contrast to get a very bright picture and if necessary adjust the drive settings so that the bright picture is pure black and white. Return the video settings to normal and then adjust the vertical and horizontal settings so that the info boxes on QVC are centered top, left and bottom. If you are not sure that you can do that right then have a qualified tech handle it for you.
Jul 23, 2007 | Zenith SY3572DT TV
TV losing its channel memory
I had the same problem. I replaced the EEPROM marked U33 (it's a 24C32 in a smd package) and the TV worked fine.
BEFORE replacing the EEPROM you have to go into the Service Menu (hold down VOL- and CH+ on the local command) and take a note of all the values, specially the R,G,B gain and R,G,B bias, in the "standard" picture mode as well as in the "Cold" picture as well as in the "Warm" picture mode.
(if you forgot to do this, here are my default values:
R gain: 434
G gain: 482
B gain: 484
R bias: 270
G bias: 270
B bias: 264
then you put the "Cold" image mode and set again those values, increasing the G bias to about 300 and the B bias to about 310.
then put the "Warm" image mode and set again those values, increasing the R bias to about 300 and the G bias to about 280)
The other values such as brightness, contrast etc, have to be left at 50.
I hope this solution will FixYa!
Jun 16, 2007 | Acer AL2671W 26 in. LCD Television
RCA P52926 52" Rear Projection Television Logo
622 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
