Question about Panasonic Televison & Video
Panasonic pt53wx53g wheres pico fuse
I was wondering if someone could tell me in relation on the board like r7011 u know to find the pico fuse thank u
  • 3 more comments
  • unclemoe8646 Feb 27, 2009
    cant seem to find the r7080 or r7086 please help r these pico fuses sorry im a beginner i put 2 new ics in and check the resisters all good hooked everything back up 3 blinks turns off please help again
  • unclemoe8646 Feb 28, 2009
    do i use an ohm meter to check those resisters what do i set it to and thank u very much welcomejee for takeing some time out to help me
    do mean cut one end off of the resister to check and thank u very much welcome jee and if its good it will read 0 ohms is this the way i should check all the resisters i didnt check the other ones like that
  • unclemoe8646 Mar 02, 2009
    i think rated u hit the blue diamonds 2 times i cant thank u enough but one more question please did u mean cut one of the legs off of the resister to make it an open circuit
  • Shahid Electronics
    Shahid Electronics May 11, 2010
    Please check R7080 and R7086 on D Board of PT-53WX53G
  • 10,594 Answers
R7080 is mounted parallel with Transistor Q7060 (base-emitter) supplying +20 volts to STKs
R7086 is mounted parallel with Transistor Q7061 (base-emitter) supplying -20 volts to STKs
Posted on Feb 27, 2009
  • 3 more comments
    Shahid Electronics Feb 27, 2009
    Both are fuse-able resistors.
    Shahid Electronics Feb 28, 2009
    set multimeter on resistor check (ohm set) or continuity and put both leads of meter to both ends of resistors, please note that one pin of resistor should be out of circuit for correct measurement.
    multimeter should show approx 0 ohm reading for correct resistor.
    Hi again,
    Please rate solution as 4 blue diamonds because I provided you complete info.
    Shahid Electronics Mar 03, 2009
    I did not said to Cut a leg or pin of resistor. Just use solder iron and unsold one pin of resistor and take it out from board. This will isolate resistor from circuit and DVM will give you correct reading about resistor.
    In-Circuit component test required much technical experience.
    Thanks for rating solution.
    every resistor mounted on PCB has its won value and R7980 & R7086 are 0.27 Ohms (near to zero)
I found the location of the fuses...but no numbers on them...where would i go to purchase something like this for the PANASONIC TH-42PX60U
The Amp rating is usually stamped on the board very close to the fuses. If they are white in color then they are called ceramic fuses, but still have an amp rating. If they are Pico fuses they also have ratings that are close to their location on the board. DO NOT go above the amp size it calls for. If the new one blows then you have a related short to that particular rail. Have it serviced.
Nov 10, 2010 | Panasonic TH-42PX60U Television
I Have a mitsubishi WS-65857 and after doing the diagnostic i get teh 2,2 that some of the gurus have mentioned it is to resolve. I was wondering if you can tell me how to resolve this? Thank you very...
Check the two green pico fuses F9A04 and F9A05 on the "Center Board" if either of those two fuses are blown then convergence ICs are the reason its shutting down with a 22 error code.The pico fuses look just like resistors but dont have color bands and they will be bright green.
Sep 11, 2010 | Mitsubishi WS-55511 55" Rear Projection...
Source for pico fuses for the Mitsubishi WD-62525 Power Board
Tries Websites Tv repair World.com,Tvrepairkits.com and Ebay.com look for the pico fuses.
Mar 17, 2010 | Mitsubishi WD-52525 52" Rear Projection...
Kp-46wt500
the pico fuse are the two little yellow resistor looking things under the heat fins of the convergence chips
Jan 03, 2009 | Sony KP-46WT500 46" Rear Projection...
I need to identify the parameters (rating) of a resistor for a Panasonic PT53WX53G projector big screen tv. It got hot so I can not see the color codes on it. This resistor glows red when TV is turned...
The resistor you see is a 2.2 ohm 2 watt resistor and is part of the convergence circuitry. I would replace R7011. 7012, 7013, 7014, 7015 & 7016 (all the same value) and the 2 STK392-110 Convergence ICs. This should fix your problem. You can find kits on-line for around $45 with the IC's and resistors together.
Nov 26, 2008 | Panasonic PT-53WX53 53" Rear Projection...
Mitsuibishi WS65809
The only items on your set that should need replacement would be both convergence IC IC801 and IC802 which are both STK392-570 and you will also need to change the two 5 Amp pico fuses which are F9A04 and F9A05 they are both % amp pico fuses. All parts are located on the center Board
Oct 23, 2008 | Televison & Video
Pico fuse
It's on the T-con board itself at location Cp1 which you will find printed on the board itself.. The fuse is a tiny s/m (surface mount fuse but you can use a pico fuse of same value. According to schematics it's a 1.5a fuse. Simply solder one across the s/m fuse and if it opens then change the board. Samsung p/n# Bn81-01286a
To test the fuse use a VU meter set to continuity.
Pico fuses are readily available at almost any electronics supply outlet. I get mine from ACME Sales in Florida (least expensive) but even your local Radio Shack might sell them...
Bill
Sep 04, 2008 | Samsung LN-S4692D 46 in. LCD HDTV
KP-57WS500
If you look at the Convergence ICs you will notice a row of resistors under the fins of the heat sink. Those are the 4.7 ohm resistors. Also in that same row of resistors you will notice the 6 yellow picos they are all lined up the picos have 4 grouped together then 1 more on each end of that row or resistors.
Jun 21, 2008 | Sony KP-57WS500 57" Rear Projection...
Parts for panasonic pt-53tw53g
r7011 = 2.2 ohm 2 w...
r7015 = being researched....
Partstore.com ...........................................T.
Apr 09, 2008 | Panasonic PT-53TW53 53" Rear Projection...
Where to find discontinued board
go to this link and on the lower left side click on the contact link and leave the board number and they will respond right away that have access to rebuilt as well as new boards for all models and all boards rebuilt are guaranteed.
http://servicemanuals.vstore.ca/
Apr 07, 2008 | Panasonic PT-53WX53 53" Rear Projection...
Televison & Video Logo
260 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
