Question about Indesit W 123 Front Load Washer
How easy is it to change the drum bearings on my indesit wil163s?
My machine is just out side the guarentee, i live alone and the machine must have done 150 washes i,m extremely diasapointed.
ive had the back off the machine and can clearly see the bearings in the centre of the drum, obviously i,d need to remove the security type screw and what i,d call the fly wheel, then how easy is it to remove the actual bearing? and is it just a matter of alligning the new bearing in place and gentley tapping it home.
thanks chris.
great site here i,l be sticking around for sure. :)
    New Friend:
  • 25 Answers
You need to completely remove the drum assembly from the machine, place a piece of wood through the rear spindle and undo the nut, wiggle spindle and it should come off, do not hit with hammer ! split the drum (if splitable type) give the spindle of drum a good sharp whack with a hammer, it should come out of bearing, next you need a longish cold chisel, quite slim, to knock bearings out, i always knock rear bearing out first, then inner,, to replace, use the old bearing to drive the new ones home, only knock outter edge,, if you hit the middle you will damage the bearings,, the seals depending on which type can be fiddily, but again, the same as putting bearing in, but you can tap directly on seal being gentle
Posted on Sep 10, 2013
I need to remove the Centre spindle screw in Indesit washing machine and I'm not sure which way to turn and it is very tight. Is it Clock wise or counter clock wise? Please help.
Posted on Mar 31, 2010
  • 100 Answers
You will need to remove the pulley first, the screw in the middle will need a knock to release the loctite.
you will then need to remove the spider assembly, that's the metal cross the bearings are sitting in. there are bolts set around the drum. spray the bearings shaft with oil to help removal, and you may need to hammer the spider as you remove it to loosen it. be careful of the heater.
then knock the bearings and seal out and do the reverse proceedure to put back together.
Posted on Feb 28, 2009
How do I program the module in an Indesit IWDC6125
indesit washing machines are only made to last just outside the guarentee period these days as the drums are sealed to stop you replacing the drum bearings. much better to buy a reconditioned Hotpoint wm62 they also wash much quicker than any new machine
Mar 27, 2013 | Indesit Washing Machines
My Indesit WIL163 is stuck washing - won't go on
I suspect that the logic board has developed a fault and probably needs replacing. 'Phone your Indesit Service Centre and get an engineer out. I believe a replacement board costs about £100 fitted, but a 12-month service plan paid monthly may be a bit cheaper, and will cover further breakdowns. Unfortunately, these boards are not the most robust or reliable examples of technology.
Turn off the power to the machine; preferably unplug it.
If you can open the door(?), bale out the drum by hand. I don't think there's a pump/filter access panel on this machine, so it's not easy to get the water out. You could try
disconnecting the discharge hose from the pipework, then lower the open end over a washing-up bowl so that the water drains from the drum by gravity. It depends how close to the floor you can get the open end. When enough water has drained, it should be possible to open the door to remove the laundry. Sorry, this may take a while.
Hope this has helped.
Jan 11, 2018 | Washing Machines
Indesit w1xe127 how to remove the drum ,so as to renew the bearings
on this machine u cannot change the bearings. the entire drum has to be replaced. if the machine is under 5 years go through the 5year parts warenty, will cost you aprox £100. otherwise the machine is not worth repair.
Jul 11, 2011 | Indesit Washing Machines
Remove bearing from indesit drum how to split drum
all of the newer indesit washing machines have whats called a welded drum meaning they cannot be split open.the thing about this is to change the bearings you have to buy a full drum. best option is to go through the indesit company themselves. aprox cost £100 if under 5 years and £140 if over 5years. hope this helps
Jun 19, 2011 | Washing Machines
Hi i have been away for few days washing machine was fine i dont use it very often as i live alone and takes a while to acumilate enough washing to use the machine. its a WIL163 Just loaded the washer...
Sorry but with such a major fault it is virtually impossible for anybody on this forum to remotely guess what is wrong with your washer. It could be internal wiring/plugs sockets, control panel switches, control PCB. I fear that your only real option is a service call as the engineer will have the right equipment to safely diagnose what is wrong.
Sorry again and good luck,
John C
Mar 20, 2011 | Indesit Washing Machines
Wil163 3 lights flash mid wash
My machine starts filling with water, then the power button and the two next to it start to flash, and the water starts to drain from the machine.
Apr 12, 2009 | Indesit WA 115 Front Load Washer
Bearings getting noisy
no need to remove the drum
u just unscrew the screws and spyder wil come and u can change the baring
Mar 07, 2009 | Indesit W 123 Front Load Washer
Bearing noise on Indesit WDG1295
you will have to open the machine lid to see if its a plastic drum or metal.
the metal drum is easier as it has a 'spider asssembly'. remove this after taking off the pulley by taking out the bolts that hold it and bang it off being carefull of the heater element. remove the bearings and seal and refit in reverse order you took it off.
i would not advise replacing plastic drum bearings as they are a pain, removal of the rear of a plastic drum easy but not putting it back !
Feb 01, 2009 | Washing Machines
Indesit wash machine drum bearing
depends on the model that you have some indesit machines you only have to undo the spider and others can be a bit of a pain because you have got too split the drum would recomend an engineer regards jason
Jun 13, 2008 | Indesit W 123 Front Load Washer
Indesit W 123 Front Load Washer Logo
602 people viewed this question
Top Indesit Washing Machines Experts
Gerry Harvey
Gerry Harvey
Darren Moxam
Darren Moxam
Are you an Indesit Washing Machine Expert? Answer questions, earn points and help others
