So my LCD TV is ghosting and has horizontal lines. i tried hitting it and the problem fixed itself, then went back to orginal problem. I worked out that if i held the top right corner and bottom left corner forwards, the problem would go away. this isnt practical as i am watching the tv about 10cm away from a 40inch screen any suggestions on fixing this issue?
SOURCE: Sony Bravia 40inch LCD Digital TV
Its very easy, pick TV original remote and press " i " (info) button on remote and on-screen display will disappear.
Have a great day.
SOURCE: white horizontal, zig-zagging lines
Sounds like the flyback transformer is bad. couple of 100 dollars if it is that
SOURCE: LCD TV SCREEN PROBLEM RED HORIZONTAL LINES OF DOTS ALL OVER SCREEN PLEASE HELP
This should be repairable. It may be the LVDS Cable or the Main board problem. The only other problem is the T-Con Board.
SOURCE: LG LCD TV - Buzzing Sound and Faint Horizontal Lines
From your description, the sound you are hearing is the inverter(s) that drive the back light for the LCD screen/module.
The inverters mounted on the back side (one lower right and one left side) of the LCD screen/module. They are under the sheet metal cover/shields.
The inverters are going out and or the LCD screen/module is going bad too.
That LG TV has only a 1 year on parts and labor from the date of purchase, but you could call LG and ask for their help for such a new TV. They might do it under a warranty, for little or no cost to you.
I hope this information has helped you.
Good Luck.
SOURCE: I have a Samsung LN46A650 LCD TV and recently I
Yes, it's the t-con board, a well know problem in this tv. Here it is
http://www.partstore.com/Part/Samsung/Samsung/LN46A650/Samsung/Samsung/BN8101697A/New.aspx
