Question about Samsung TSJ2799 27" TV
Samsung TSJ 2799 No sound
Tv worked great then next morning no sound .Speakers are work and have a hum to them .Mute is not on .
  • plankster11 Feb 27, 2009
    Hi thanks for the respond but I don't even have a remote any more and use the cable box to control volume. Dvd player still no sound and the both work on a different tv
    I check all the audio stuff in menu its all good .DVD player appears on screen but no sound .
  • 280 Answers
Check the audio menu and make sure it is in the stereo mode and that the alt sound is not on. some times the remote button gets pushed by mistake when turning it off. If everything in the menu looks ok it may be the cable converter box. If you can hear anything from the speakers the output is working. Try a DVD to see if you get sound from it.
Posted on Feb 27, 2009
  • coyotedave Feb 27, 2009
    You may be able to use a universal remote that has a menu button. If you get one from Wallmart or other store. I dont think you can get to all the menu functions from the front controlls.But you can try.
Morning problem
Your TV is not worth fixing im afraid.
Mar 01, 2014 | Samsung Televison & Video
Last night youtube videos sounded great but today there is no sound anymore although the videos are playing fine. Now the speaker icon has a cross next to it on the right hand side. How can I uncross this...
it's muted in youtube, usually click the icon with the cross, or on the tab of the browser next to the close button if there's a mute icon there. if that does not work, close all your browser tabs and reopen youtube. Also try with another browser, Firefox or Chrome.
Dec 24, 2017 | Samsung Computers & Internet
I have a Samsung LE40B650T2 - no sound direct from the TV
It sounds that the sound processing section [digital circuts] are working well, and the fault must be either to the speakers, settings or to analogue audio amplifier section. Make sure that the Mute function is OFF. If it is OFF, and still you do not get audio output by tV speakers, surely the fault must be to audio amplifier circuits, provided speakers are OK. If your TV has a headphone out socket, this socket should also checked for proper interconnection.
Jun 24, 2012 | Samsung LE40B650T2 40 in. Full HD Crystal...
No sound 72 inch samsung
Some simple things you may already have tried but I will list:
Unplug set for a while and then plug back and see if sound--when unplugged the set may reset.
In main menu make sure speakers are not switched off.
I doubt it is mute but if also using some type of box check that its volume is not all the way down.
If internal speakers put your ear right to them---hear low sound or a buzz or hum?
If using external speakers of any kind look at the hookup and switch to make sure internal/external is correctly selected
If NONE of these help you have an audio problem and should first contact Samsung (yes it takes time on the phone) to inquire if some common issue or a possible software upgrade is available for this.
Last: Some failure has occurred either in the audio circuit or something that feeds it.
Mar 21, 2012 | Samsung Televison & Video
The volume has went off on my tv. its a samsung le26b450c4w
First verify that the mute is disengaged (toggle the mute button). Second, check the sound configuration to make sure the internal speakers are on, or check the sound output to make sure it is going to the inputs of an external audio amplifier (stereo receiver) and that the external amplifier is working. Try a different input source - perhaps the problem is your cable feed or DVD player.
If the internal speakers are on, the volume is up, and you still don't get any sound from a known-good source (TV channel, DVD player, etc.), then try running the sound to a stereo system as described above.
If that works, you may have a shorted speaker amplifier (depending on the set's design, this may blow a fuse supplying power to both left and right amplifiers or a speaker protection circuit will keep the speakers disconnected). These aren't usually hard to repair, but if you find a blown fuse, fix the amplifier before replacing the fuse or you'll just waste another fuse.
Jan 09, 2012 | Samsung Televison & Video
I have no audio
Hello sir, Hi, No Audio on your TV can be user error or Hardware error, for the user error, make sure that the TV is not set to low volume or the setup is on MUTE, for the hardware error, Place your ear close to the speakers, then set the volume up and down several times, you should hear a soft hum that goes up or down, (make sure that the room is quiet.) The soft hum means that the power amplifier is working properly. so the problem may be on the main board where the sound is being produce before amplification, usually the sound IF section. NOW if you did not hear the soft hum, problem with the amplifier and speakers, A physical checking for open wire contact or loose connection is needed.
Aug 20, 2010 | Sharp LC46SB54U 46 in. LCD TV
Constant hum from speakers
It sounds like you might have a grounding issue. Try connecting to the wall outlet with a ground prong lifting adapter. Not just the speakers but the source plugged into the speakers also. Good luck.
Oct 09, 2009 | Logitech Z-10 Computer Speakers
1987 RCA TV
most like the amp on speakers wwent bad best u can do add seprate samsng sterio suround system or ect form dish cable box to sterio direct for tv sound or rca outs on tv if those sstill work
Oct 06, 2008 | RCA E13309 13-Inch Diagonal XL-100 Color...
Televison & Video Logo
249 people viewed this question
Jerry Greenberg
Jerry Greenberg
