Question about LG 42PX4DV 42 in. EDTV-Ready Plasma Television
Thin line down the screen
Perfect picture all exept a very tnin line running down the screen about 2/3 the way across. any ideas.
Thanks
  • Anonymous Feb 27, 2009
    LG 50PY3D has verticle line only noticable viewing close or from side.
  • LG Master
  • 458 Answers
This will be a fault within the screen, the only way to repair it is by having a replacement screen fitted which can be costly if it is not still under warranty.
Posted on Apr 01, 2009
Very thin black vertical line moving across tv screen left to right on tv
The screen voltage to the picture tube is more than normal. Adjust it by the help of screen pot-meter integrated with Line Output Transformer. Visit the site named 'Electro-help' for more details. Check this link and select the site named above. View it in 'Flip card' option, which can be selected from the drop down box menu at the left top corner or the display window. It will make search easy.
Aug 05, 2012 | Panasonic CT-20SL14 20" TV
Thin blue lines across the screen.6or 8 of them 3 or 4 inches apart. everything else works great still perfect picture
You need to turn down the Blue Screen Drive control a notch, Blue tube has built up higher then R/G over Driving.
Sep 27, 2010 | Sony Grand WEGA KDP-65WS550 65" Rear...
I have thin white lines that run across the top of my picture. They are only visible when picture is full screen. The wide screen picture (with the black areas at the top and bottom) do not show this. The...
sounds like bad capacitor in vertical circuit. It's not a hard fix if you know where to look. Repair shop should not have hard time repairing it.
Aug 10, 2009 | Televison & Video
A strait line across the screenpicture is perfect exept a dark line across the screen
If it is absolutely straight, your LCD Panel is probably defective. This is not repairable.
May 16, 2009 | Televison & Video
SanyoTV-blk screen w/thin line of light across screen great sound
Your Vertical Amp is probably Blown (bad) , but before you change that check all capacitors around the vertical amp IC and / or resolder resistors and diodes around vertical amplifier.
And NO it is NOT the Picture Tube
Good Luck
JG
Apr 18, 2009 | Sanyo DS27820 27" TV
Insignia 32" Tube TV NS-RTV32
The vertical output IC LA7847 is failing. It will likely fail permanately and you will have just the horizontal line. The set will require service. Just do not run the set very long in this state. That thin white line can likely burn into the crt phospher and will show all the time thus ruining the glass picture tube...
Jun 05, 2008 | Televison & Video
Thin red horizontal lines across screen
replace the focus block or try to adjust the screen control on the focus block for red only. this will affect the white balance of the set so adjust it carefully. the focus block is located on the front inside the set. remove the speaker cover then the 4 screws on the front plate. the focus block is 3" x 2" black box with 6 adjustment posts three for focus and three for screen. adjust only the affected screen (R).
Mar 13, 2008 | Sony Grand WEGA KDP-57XBR2 57" Rear...
TV Picture Reduced to Line across the Middle
This is called field-collapse. Either
1. The problem lies in the vertical deflection voltage-doubler circuit. The usual fault is a single capacitor of 100uF/35V that has failed. It is normally connected to a rectifier diode right at the vertical IC. Replacing the capacitor usually gets it working perfectly again.
or
2. The vertical drive IC has failed.
If you are finicky around technical work, then a reputable local repair shop in your locality should do it quickly for you and charge only labour.
Jan 13, 2008 | Symphonic ST419E TV
HD61W66YX60
this is a convergence issue. it is caused by one of three things
1. a bad convergence board
2. a bad fuse feeding the convergence circut
3. a bad relay feeding the convergence circut
whatever the one it is they all have the same result, an inoperative convergence curcut. needs service .
if it is still under warranty, great. If not the parts can cost up to $300 and labor can be the same
Nov 15, 2007 | RCA HD56W58 56" TV
LCD monitor problem
what is the solution for this? my husband just turned his pc on when we got home and there are line blue lines running up n down in the black
Oct 11, 2007 | Computers & Internet
LG 42PX4DV 42 in. EDTV-Ready Plasma Television Logo
169 people viewed this question
Computer Repairing
Computer Repairing
