Question about Hitachi 53UDX10B 53" Rear Projection Television
Tv is dusty on the inside can the bulbs be cleaned.
I blew all the dust out but can i clean the bulbs.
  • 23 Answers
You can only wipe the exposed surfaces of the lamps. And i recommend a soft dry cloth. Do not go crazy here since in the end as long as there is no heavy coating it will not affect the image
Posted on Feb 27, 2009
I blew the fuse inside my KR,v6080 when I took off the cover the inside was very dirty(dusty) I cleaned it up do u think that is what caused the fuse to blow.
Could be. Dirty dusty could cause heat build up. Replace fuse and clean fuse contacts with spray electrical cleaner. If fuse blows again, figure out what runs off that circuit and test further for bad connections at bulbs, spade connectors, etc.
May 04, 2015 | Cars & Trucks
Luxor tv
Most probably there are some left overs inside the printer. Open and check again. Sometimes the sensor becomes dusty, just use a blower to clean away all dust in the printer. Try opening the covers and clean away...
Aug 30, 2014 | Indesit 18 in. D41 Slim-Line Free-standing...
How can I clean inside a rinnai convector 417 gas heater
Beside cleaning the filters with a vacuum, There are no instructions on how to clean the inside of the heater. The back and front panels would need to be removed. Unless you are confident to remove the panels, just blow it out as you ahve done and make sure the filters are clean.
May 03, 2014 | Heating & Cooling
How do I clean inside my rinnai convector 417?
The owner's manual at on page 10 says to vacuum both filters weekly. It also warns not to wait for the filter lamp to come on since overheating may occur.
May 03, 2014 | Rinnai Water Heaters
While replacing the lamp assembly is it better to replace the filter at the same time
Replacement might be a good idea, depending on the condition of the filter. The filter is there to keep dust out. Manny of the filters you can just clean with soap and water.
It is essential to keep the filter unclogged to allow air to circulate through the tv chassis to not only keep the electronics cooler, but also to keep your bulb running cooler and prolonging the life of the bulb.
That said, you should gently vacuum out the dust inside your tv that you can reach (tv unplugged) and make sure the fans are clean as well. I have used a soft paintbrush and vacuum to help clean out the insides of a TV filled with dust/dirt.
Feb 22, 2011 | JVC HD-56FN97 56" Television
The blue bulb is really dusty how can i clean the
That requires the fluid being replaced in the Blue tube. I suggest that you have a qualified technician service it.
Jan 19, 2010 | Philips Magnavox 9P6034C 60" Rear...
Haze on area that the bulb faces.
If you can clean it and it comes off I would do it. This haze is caused by the extra heat the bulb was putting out before it blew. Make sure you blow/clean out all the dust you can. These TV's have a air intake filter also I believe. The more you can keep the filter clean and the Light Engine the better.
A/V Media Tech Guy
Nov 25, 2009 | Sony Grand WEGA KF50WE620 Television
Toshiba model #37HL67
You can use a vacuum, a can of compressed air is also my best friend in these situations, I also use a clean paintbrush to get the stuck on dust. If it's really bad you may have to get inside the TV to clean it.
Jul 08, 2008 | Televison & Video
Sony kdf 50we655
heat and dust are two major problems with this type of set.These set can get very dusty inside the optics and cause this type of discoloration .Heat can cause deteriation on optics and or optics cabinet parts .It is possible to clean the optics block for dust issues only but unless you know what your doing and know what areas not to touch inside optics block .Otherwise the block would have to be replaced..
Nov 12, 2007 | Sony Grand WEGA KDF-50WE655 50" Rear...
Round shadows in picture
Sounds like the Bulb is almost out of life or a dustball or something is moving around inside the light compartment. Look in the instruction or user manual on replaceing bulb or opening bulb compartment or call Mits. for a service center in your area. Good Luck
Jun 24, 2006 | Mitsubishi WD-62525 62" Rear Projection...
Hitachi 53UDX10B 53" Rear Projection Television Logo
70 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
