Question about Canon NP 6050 Copier
Scanner Glass Where can I find a scanner glass for A NP6050 canon copier, it seems hard to find here in Florida, is there a copier compatible for this particular copier?
  • keithking1 Mar 03, 2009
    you guys did a great job andf I appreciate it.
    Sergeant:
  • 199 Answers
Try with used copier dealer or you can also use an normal 3 mm glass (perfect size cuting and side finishing by mirror seller is required)
side guide sticker is available easily.
Posted on Feb 27, 2009
How to replace a broken scanner glass canon dr1210c
I don't know how the CANON DR 1210-C is assembled but I had an Artec and unscrewing it I could take off the glass.
Oct 12, 2014 | Canon DR-1210C Scanner
E000202 0001
this is error related to scanner home position. You need to remove the copy glass and pull the scanner rail in home position ( to the left, until the dadf copy glass ). If this doesn't helps the home position sensor is faulty or the scanner rail wire or scanner lamp.
Hope that helps!
Jun 10, 2011 | Canon imageRUNNER 2200
We have canon ir2000 Once when we switch on the machine, the scanner was below the reader glass but scanner was not moving while reader motor (scanner motor) was trying to move the scanner. After that we...
i cant get ur problem .it might be due to home sensor problem.try to use a air blower to blow the optics unit for dust . if that doesn't solve the prob then u have to call a tech as ur scanner may be out of home position and a tech will be needed to solve that
Jun 01, 2011 | Canon imageRUNNER 2000 Copier
My canon np6050 xerox machine doing darker copy . please tell me what can i do for it
just clean the optics mirror to clean those mirror remove the 2 screw in right portion of the machine the 2 screw is the lock of the metal plate in the right end portion of the platten glass the after you remove the screw remove the metal plate & platten glass then move the scanner assembly in the middle portion then you will see a mirrors wipe it with clean rugs then after you clean those mirror remove the 3 screw in the black cover inside the right portion of scanner after you nremove the 3 screw & the black cover you will see 2 mirror wipe it with clean rugs the after you clean the mirrors return all the cover you remove &the platten glass & metal plate then try to make a copy
Dec 08, 2010 | Canon Office Equipment & Supplies
Scanner malfunction
Scanner has a sense to observe ..
Try with normal 2.0 or 2.5 mm. glass (available on store of glass/mirror seller)
The same size cutting is necessary,
May 22, 2009 | Canon PIXMA MP210 Photo All-In-One Printer
Canon IR 2016J Scanner does not move and glows while copying
Call service it may be lamp pcb or broken belt or ...
Apr 08, 2009 | Canon CLC 1140 Copier
How do I clean the INSIDE glass/platen?
You mean the inside of the scanner glass? (The platten is a part of the print unit),
You'll have to remove the sides and read cover. Unplug the scanner wires and remove the scanner assembly. Separate the document feeder from the scanner bed. Open the covers of the scanner bed (usually there are screws holding it together). Remove the glass and clean it. Reverse the process to reassemble.
Be careful. Canon multipasses are built a little like a Chinese puzzle box. There are little snaps everywhere as well as screws. Watch out you don't force anything and cause the snaps to break.
Nov 05, 2008 | Canon PIXMA MP830 All-In-One InkJet...
How do you clean the INSIDE of the scanner GLASS???
The service manual is avalable free through Emule:
ed2k://|file|Canon%20PIXMA%20MP750%20MP780%20service%20manual.pdf|1416152|F054D74C11BE5EEAF2F6D203362303DE|/
Dec 19, 2007 | Canon PIXMA MP780 All-In-One InkJet...
COPY PROBLEM
You have a scanner problem.  You might try and make sure you're using the right plug for it.  If you can figure out how to take the glass off, you should try cleaning all the glass and mirrors.  You should also clean the area just above where the scanner rests when it's not being used (you'll see a white strip there).  If none of this works, you'll probably need a new scanner.  Junk the thing.
Oct 26, 2007 | Canon imageCLASS MF5550 All-In-One Laser...
Black Line printing on copies
Just clean the glass top of the scanner and the slit of glass on the left hand side of the scanner.
Dec 04, 2006 | Canon PIXMA MP780 All-In-One InkJet...
Canon NP 6050 Copier Logo
42 people viewed this question
old marine
old marine
Corne Viljoen
