Question about Nokia 6111 Cellular Phone
"no voice tags saved"
The phone sad: "no voice tags saved" and needs to be restarted.
it happens when a phone is in use ( when I'm speaking), and often it needs to be restarted the next time after restart. It is reducing volume level by itself.
Thank you in advance!
SOURCE: The phone has no voice tags. Long press on upper
went 4 new software
Posted on Mar 15, 2010
SOURCE: phone is restarting
Thanks dude!the prob is fixed now after replacing the mother chip in the mobile!battery was good!
Posted on Feb 16, 2007
  • 7 Answers
SOURCE: My Nokia 5300 Restart Automaticly
try to wpdate your software, download from www.nokiausa.com and download the latest software, and it will ask you to connect the phone so it will do it i takes like 30 min to do it, sorry for my english
Posted on Jul 20, 2008
Fame_Guru
  • 483 Answers
SOURCE: The signal on my phone does not work, and my phone restarts itsel
Try disabling 3G to see if thats the cause, if so request a new sim card. Menu> Settings > Connectivity > Network > Network mode - set to GSM.
If that doesn't help try the following reset codes, if the first one doesn't solve the problem try the second. The first code will just reset your settings. The second will reset everything and wipe all of your data. Be sure to backup before using either of them.
Enter these like dialing a number:
Reset to factory defaults (*#7780#) : Restores settings but preserves user data (photos, 3rd party apps etc).
Reset (*#7370#) : This reformats completely the C: drive. All applications and files stored on this drive will be lost and clean default files will be rewritten.
If after these codes you still have the problem you will need to contact vodafone as it may be a sim card or hardware fault.
Posted on Jun 19, 2009
  • 30 Answers
SOURCE: Nokia 5630 restarts when attending calls+Voice recorder to memory cards not works
connect ur mobile using data cable and make a full format and then u restart ur mobile.
Posted on Jul 06, 2009
How to activate voice dial phone feature
Touchscreen phones simplify the wireless world, especially when combined with voice activation. Although making calls using voice commands was an option before touchscreens became available, the method used to set up this feature is different than it is for non-touchscreen units. It can take time to master the set of procedures that will get the feature working.
Step 1
Create a voice tag. Touch "Contacts" on the today screen. This opens the list of contacts on your phone. From here, do one of three things: you can hold your finger on the desired contact and then tap the "Add Voice Tag," you can select the desired contact, tap on "Menu" and then "Add Voice Tag," or you can tap the desired contact to open their personal screen and then hit "Menu" followed by "Add Voice Tag."
Step 2
Record the voice tag on your phone. Touch the phone number to which you wish to add a voice tag then touch the "Record" button. Record your voice tag for that contact. An icon will be displayed to the right of the number when the voice tag is complete. You can listen to your voice tag by touching the "Play" button on the screen or you can delete it to record a new one.
Step 3
Make a voice tag for a program. Tap the "Start" button on the phone. Go to "Settings" and then the "Personal" tab followed by "Voice Speed Dial." Choose the program for the voice tag and record the voice tag in the same manner as you did for the contact. To open the program with the voice tag, tap "Start," "Programs" and then "Voice Speed Dial."
Step 4
Launch a program or make a call. Make a call by tapping "Start" followed by "Programs" and then "Voice Speed Dial." You will hear a beep. Say the voice tag you recorded for the person you wish to call. You can open a program via the same procedure (by speaking the voice tag created for the program).
Step 5
Check the voice tags you created. Tap on "Start," "Settings," "Personal" tab and then "Voice Speed Dial." A voice tag tab appears and displays a list of your voice tags.
Jun 20, 2016 | Cell Phones
Cannot store voice tags
Delete some SMS and you will have more free memory to add a tag to a contact that you must save on the telephone and not on the SIM
May 20, 2014 | Nokia 6275i 6101 6102 6102i 6103 6133 6126...
I am having problem on finding and setting voice tag for contacts.
GOTO CONTACTS
EDIT CONTACTS
EITHER IT WILL BE THERE AS IN OPTIONS
OR IT WILL BE THERE IN SETTINGS
Feb 05, 2011 | Nokia 6720 Classic Cell Phone
How do I turn off voice my on virgin mobile phones
I'm unsure if you are speaking of voice recognition or voice services. The "call options" menu will customize settings.
To remove voice tags/commands from the phone select: menu>settings>call options>erase voice dial>yes.
To disable voice answer select: Menu>settings>call options>voice answer>disable.
To utilize only messaging services you need to contact Virgin Mobile, 1-888-322-1122, about text and data only plans.
Aug 07, 2010 | Kyocera wild card Cellular Phone
Need to find out how to set up caller id on supertooth 3
Hi Kazgear,
Voice Dial:
Important: Be sure your phone supports the voice dialing function and that it is activated. Record at least one voice tag. (Please refer to the instructions in your phone’s user manual.) Note: Voice dialing entries must be stored in the phone’s memory, not on the SIM card!
1. Press the Accept Button (1) for 1 second.
2. A voice dial beep will be heard on the kit to prompt the user to say the voice
tag of the contact to call.
3. Say the voice tag exactly as how you recorded it.
4. The voice will be played back to you, and then the phone will dial the number automatically.
Her's a .pdf file of the user manual, which you can save to your computer:
http://www.blueantwireless.com/downloads/supertooth_light/supertooth_light_manual.pdf
Hope this helps :)
Season's Greetings!
Chris (ziraffa)
Nov 29, 2008 | Blueant Supertooth Light Bluetooth Speaker...
How to activate the name caller id on supertooth?
Hi Kazgear,
Voice Dial:
Hope this helps :)
Season's Greetings!
Chris (ziraffa)
What is voice tag of H350 headset?
Voice tag is what enables you to call by speaking. So say you have a contact named Bob on your phone. You press the button and the phone beeps and you say "Bob" to call him. If you say it clearly, the phone will display Bob (and possibly any other contact that is close in name to Bob). If you don't do anything within a few seconds, it will start dialing Bob. That is the voice tag. My guess is your phone does not support voice tag or you dont have any voice tags assigned to your contacts. You will have to call from the handset, not the headset.
Dec 26, 2007 | Motorola Mobility Bluetooth Hands Free...
Nokia N95 Voice tags
i need to say u should save the voice tags in a silent place with keepin the phone at a smalll distance from mouth . say the words cleraly as u are u can repeat the word in the same clarity
Dec 04, 2007 | Nokia N95 Cellular Phone
Voice Dialing Issues
I am sad to say that the voice recognition failure is permanent on most of the E815 phones. Your phone will likely never support voice dialing again, even though the cause remains unknown.
I too had the peculiar problem of pressing the voice button and hearing a beep, but no voice prompt ("Say a command"). When I researched the issue, I found a plethera of similar problem reports. Very few reported recovery after simply restarting the phone. I even found one report of Motorola tech support giving up and instructing the owner of the phone to have it replaced.
Feb 14, 2007 | Motorola Mobility E815
Nokia 6111 Cellular Phone Logo
767 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
