Question about HP LaserJet 1200 Printer
Hp laserjet 1200 series printer prints partially.It prints only the left and right side of the paper but not the middle part. give me a solution
  • tahir144 Feb 27, 2009
    Hi msm, both left & right side are printing vertically but the middle part of the paper is not printing vertically.. can u help me... And also when toner well shaked i can print only one paper clearly....
  • 31 Answers
Unfortunately your printer drum has gone bad... you might see if this is cost effective to replace the drum or go ahead and get a new printer.. all together... I would expect to spend about $100 dollars for the drum. Hopefully they have made it easily customer repairable. Any case good luck
CDixon18
Posted on May 11, 2009
You can chek the cadage and then viprate it & try again
if this proplem still
you will need an ink
What is the problem actually printing left side or right side or upper down. First check tonner cartridge, if its of then check printer leser unit just clean it again.
Posted on Feb 27, 2009
My HP laser printer 1300 had a paper jam
When printing or copying, paper will not pick up or feed into the HP LaserJet 1000, 1200 or 1300 series product causing paper jams or wrinkled output. Symptoms are as follows:
  • The pickup roller will spin and try to pick paper.
  • The paper will partially feed into the product accompanied by a crackling, crunching noise then jamming.
  • The paper may feed all the way through the paper path accompanied by a crackling, crunching noise. The output will be skewed and wrinkled.
SOLUTION: Reposition the black Mylar light shields back into the proper position.
  1. Unplug the power cord from the product.
  2. Remove the paper and paper input tray.
  3. Slide hands, palms side up, into the paper input tray cavity (see Figure 1) until the fingertips reach the end of the cavity. Figure 1: Paper input tray cavityc00068598.jpg
  4. Bend fingers up to push the black Mylar light shields back into place. The proper position of the black Mylar light shield will be flat.
  5. Reconnect the power cord.
  6. Print a self-test/configuration page to verify product is functioning correctly.
Feb 24, 2011 | HP LaserJet 1300 Printer
Hp laserjet 1200
If you want the printer driver for your HP printer then -
You can download the HP printer drivers from their supportWEB site. Please click on this link and select your model printer to download:- http://welcome.hp.com/country/us/en/support.html
Dec 09, 2010 | Office Equipment & Supplies
Paper printing and get stuck n when i print only 1 page, it grab until lot of paper n suddenly jammed.. what is the actual problem what should i do? hp laserjet 1200 series
sir
I guess you maust replace your Suser Assembly, or at least regrease the fuser roll.
try to go to service center , or download the service manual from the internet
regards
walid sayed
Egypt
Mar 16, 2010 | HP LaserJet 1200 Printer
Hp laserjet 1200 series printer with high pitch nose when in printing process. During this loud noise, the roller turns but the paper is not picked up therefore printing does not occur.
noise is caused by the toner cartridge and paper is not going trough because there is a plastic milar clse to the feed roller that is bent,find it and push it towards the inside of printer (is a black or dark brown plastic mylar)
Aug 24, 2009 | HP LaserJet 1200 Printer
Printing problem
That is usually an indication the fuser sleeve is worn out or is torn on that side. Start to print a full page and then open the front when the paper is halfway printed, remove the print cartridge and look at the print on the page. If it is good before going into the fuser then you will need to replace the fuser, which is expensive for that model. It is not available from HP any longer, but some places still sell it.
Part Number is:
RG9-1493-060CN
Jan 15, 2009 | HP LaserJet 1200 Printer
Hp laserjet 1200 paper jam
Please Follow the instructions in an attempt to resolve the issue you are facing:
  • Turn off the printer and remove all paper from the paper tray & disconnect it from the computer.
  • With the printer off, check for any obstructions such as torn paper or foreign objects.
  • Turn on the printer (still disconnected from the computer) and check the lights / lcd screen.
Still getting the same error ? Go for Warranty or Service.
Else,
  • Place 20-30 sheets of paper in the printer, ensuring none of the paper is torn or creased.
  • Make sure that the paper is flush with the far right edge of paper tray, move the left edge paper guide over so that it touches the left side of the paper.
  • Try to feed paper manually (using the paper feed button).
If you still get the error let me know for further troubleshooting,
Dont vote till you find it is Helpful or FixYa.
Thanks,
Scott
Nov 14, 2008 | HP LaserJet 1200n Printer
Remove the DIMM and reseat it.
If the printer still has an error, replace the DIMM.
Unplug the power, reseat the paper tray, and reattach the power cable.
Oct 20, 2008 | HP LaserJet 1200 Printer
HP Laserjet 3330 with Windows Vista
no you cannot print on both sides automatically.you have to give the prints 2 times.at first the paper will print on 1 side then insert the same paper in the printer and give the remaining printout and it will print on the back side of the same paper.as you can do it manually but the automatic printing on both side facility is not in HP Laserjet 3330 printers.
Sep 29, 2008 | HP LaserJet 3330 All-In-One Printer
HP Laserject Printer/Copier
first u must diagnostic the problem to see if the problem from the drum unit or the fusser unit by stop the printer in the middle of print and remove the paper then u can see if the smudge appear it well be from the toner if not then the fusser faulty
Mar 26, 2008 | HP LaserJet 1200 Printer
HP LaserJet 1200 Printer Logo
191 people viewed this question
Ben Johnson
