Question about Euro-Pro F1066 Deep Fryer
Door dosenot open on dvd player - Euro-Pro F1066 Deep Fryer
  • 137 Answers
Look on the front of the DVD player and you will see a small pin hole, straighten out a paper clip and insert it into the pin hole as straight as you can and push slowly but firmly the door will open enough so that you can pull it all the way open with your fingers.
Posted on Mar 02, 2009
The door of my dvd player will not open. It sound like it wants to, but nothing happens.
This sounds like a problem with the mechanism of your player,it is probably stuck.
What you should do is to open up the player and try to open the door with your hand by pulling it,check to see what is stopping it from opening and clear the object stopping the door from opening automatically
Please note that it might just require oiling the door wheel to make the door open and close automatically.
Aug 20, 2010 | Sanyo DVW-5000 DVD Player/VCR
Disc door will not open
hello,
the reason the disc door would not come out is because there is a problem withe the mechanism that opens the door.
to fix this,
1. you unscrew the dvd player,
2. take off the cover,
3. plug the dvd and press open to see if the door would open, then you will see where it is getting stuck,
4. replace the mechanism that is controlling the disc door, and press open to see if the door will open.
5. once it is able to open up, you can screw back the cover.
Jun 02, 2010 | Memorex MVD2040 DVD Player
Dvd player wont open
try a paper clip opened and put on dvd door hole (small hole), and push slowly the paperclip inside and realease the dvd door to open, normaly is a defective dvd laser mec. and needs to be replaced. send to repair
Jan 03, 2010 | Panasonic DVD-RV26 DVD Player
My passenger door dosenot open from inside
the connection between your inside door handle and latch has either broke or came loose you have to take your door panel off to inspect what is your problem
Nov 06, 2009 | 1993 Ford Escort 4 Door
The player will not work and I can't open the door?
Grab a screw driver , remove the case of the dvd player, remove teh DVD, then junk teh DVD player.
Aug 25, 2009 | Sanyo DWM400 DVD Player
2 dvd's are stuck in dvd player
This may need a trip to the shop.
I would try to bring the device to a worktable and using gentle probes, ease the door open when activated.
I assume that there is a noise when you activate the door open feature.
Mar 21, 2009 | Toshiba SD-V394 DVD Player/VCR
DVD player door won't open
took out the dvd player and inverted it and pushed the advance disk button . There was a disk stuck between the disk slots. The door opened and I removed the disk.
Sep 20, 2008 | GPX D2816 DVD Player
Dvd door will not open
My trutech DVD player door would not open.
Jul 08, 2008 | Panasonic DMR-ES40VS DVD Recorder/VCR
DVD player doesn't work
you can open the top cover and take the cd out.
Jun 04, 2008 | Sony SLV-D350P DVD Player/VCR
Euro-Pro F1066 Deep Fryer Logo
37 people viewed this question
Top Euro-Pro Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Gerry Harvey
Gerry Harvey
Clarice Bornschein
Level 1 Expert
Are you an Euro-Pro Kitchen Appliances - Other Expert? Answer questions, earn points and help others
