Question about Apple iPod shuffle Second Gen. Silver (1 GB) MP3 Player (MA564LL/A)
How to remove foto`s from my ipod shuffle
Accidently copied foto`s from a usb-stick to ipod. how to remove them?
    Problem Solver:
  • 10 Answers
Well, a common problem. Generally, you can not delete the songs on your iPod directly even with the help of iTunes. Because when you sync with the iPod, it will be deleted when the sync is finished. Find a third party to help you is a wise choice! Many such applications on the Internet when you Google for it. 4Media iPod to PC Transfer is one of the most popular and recommendable software. It can can efficiently manage your iPod contents to help you do the iTunes can not do things!
Posted on Feb 27, 2009
How do you charge an ipod shuffle
Connect the included USB cable to your iPod Shuffle.
Plug the opposite end of the iPod Shuffle cable into an open USB port on your computer, which must be turned on.
Check the light on the iPod Shuffle. If the light has turned on, the iPod Shuffle is properly charging.
Using iPod charger
Plug the iPod charger into a working electrical outlet.
Plug the opposite end of the iPod Shuffle cable into the USB port on the iPod charger.
The iPod Shuffle should begin charging immediately.
hope this helps
Sep 18, 2012 | Audio Players & Recorders
NEED INSTRUCTION FOR Apple iPod shuffle 3rd Generation Silver
Connect the iPod shuffle USB cable connector into a high-power USB port on your computer.
Note: To charge an iPod shuffle battery, connect the device to a high-power USB port.
Please be aware that USB keyboards and non-powered USB hubs generally do not have high-power USB ports.
If you connect to a low or non-powered port, iPod shuffle will not charge.
The computer must be turned on and set to not go to sleep.
Plug the other end of the iPod shuffle USB Cable into the headphone port on the iPod shuffle.
Verify the iPod shuffle is connected securely.
Once the iPod shuffle is plugged in, it will take about 2 hours to charge the battery to 80% capacity and about 3 hours to charge it to 100%.
Find out how to check the battery charge here
hope this helps
Sep 18, 2012 | Apple iPod shuffle 3rd Generation MP3...
How di I transfer pictures from my computer to a memory card?
open the picture folder where pics are plug in your usb stick left click on the foto in folder then right click on the pic menu will come on screen select copy then navigate to your usb stick(it will be removable disc in my computer) open it then in the window right click then select paste it will copy to usb stick then....bonnell
Sep 16, 2011 | HP Computers & Internet
How to recharge the Apple iPod Shuffle Silver MP3 Player
According to the manual found here: http://manuals.info.apple.com/en/ipodshuffleuserguide.pdf
"Remove the USB cap and connect iPod shuffle to a high-power USB port on your
computer. The battery status light on the back of iPod shuffle turns on.
The iPod shuffle battery is 80-percent charged in about two hours, and fully charged in
about four hours.
When the battery is charging, the iPod shuffle status light is amber. When the battery is
fully charged, the light is green until you disconnect iPod shuffle. If you don't see the
status light, try another USB port on your computer"
Batteries also wear out from time to time, so if you find that it's not charging no matter what you do, it's likely that you need a new battery. Here's a link to more info on iPod batteries: http://www.apple.com/batteries/ipods.html
May 10, 2011 | Apple iPod shuffle MP3 Player
How to delete videos from an IPOD NANO
1. Connect the dock end of the USB cable to your iPod.
2. Connect the USB end of the USB cable to an available USB port.
3. Open iTunes.
4. Click on your iPod in the source pane. iPod.
5. Click the subcategory Videos.
6. Delete the video from your iPod.
a. Right click the video.
i. Command+Click on single button Apple Mouse.
7. Select "delete" or "remove".
8. Confirm the action.
Oct 28, 2009 | Apple iPod shuffle MP3 Player
How can i unfreez my ipod with out loosing my music
  1. Remove your iPod Shuffle from iTunes and also remove your shuffle from the USB dock.
  2. Turn off the iPod Shuffle by moving the off/on button to the left (when off you shouldn’t see green). Wait a couple of seconds and then turn the Shuffle back on by moving the off/on button to the right (you should see green again).
  3. Your iPod Shuffle should be reset.
Hope this works for you
Sep 27, 2009 | Apple iPod shuffle MP3 Player
Usb driver for ipod shuffle
Make sure you followed the installation instructions to the letter.
Then try the 5 R's
See manual for details
Sep 05, 2008 | Apple iPod shuffle Second Gen. Silver (1...
IPod Shuffle and compatibility with USB ports
yes it's a common problem, it might be a usb 2.0 or high speed usb port but the motherboard is unable to supply enough ampage to supply the port. Assuming you have tried removing other usb connected peripherals and tried a different port, the only way you may get the ipod to connect is to purchase a mains powered usb hub as the power supplied is sufficient to connect to ipods and pda's etc.
Sep 10, 2007 | Apple iPod shuffle MP3 Player
My ipod shuffle usb is not being read by any computers
Never discount the possibility of a simple poor electrical connection (or a busted usb plug on the shuffle - you didnt yank at it, did you?)
Try to swab out the inside of the usb plug on the shuffle.. 99% rubbing alchohol is best. A qtip might fit, if squashed a bit
Mar 14, 2007 | Apple iPod shuffle MP3 Player
Apple iPod  shuffle Second Gen. Silver (1 GB) MP3 Player (MA564LL/A) Logo
54 people viewed this question
Top Apple Audio Players & Recorders Experts
TO Lady
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
