Washing Machines Logo
troy marshall Posted on Feb 27, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Washer will not drain water out of drum
Dial nob gose through each cycle but water will not drain from drum
  • Affordable Appliance Parts
    Please Supply Model Number so I can see your unit as you do....
Anonymous
Level 2:
  • Expert 52 Answers
  • Posted on Feb 28, 2009
Anonymous
Expert
Level 2:
Answers
52
Questions
Helped
11924
Points
134
Your drain pump is bad. If you give me the Model # of your Machine, I can help you find the part.
Washing machine spins to slow to drain all water
Your drain hose might be clogged. Disconnect it and try to run water through it.
How to trouble shoot maytag timer nob
There is still water in the machine , the pressure sensor my not be operating there is a loose contact in the motor spin winding or the timer no supply voltage is going to the motor check the votlage at the motor at spin cycle
3helpful
3answers
Samsung vrt washer not draining
I've had so much issue with this washer since I've own it and it hasn't even been a year..I just finished fixing the same issue you have with your washer. I had to drain the washer which you were right very messy. My problem was one of the wire came lose. Of course it was from the water pump that was attached to the tub...Who would design something like that.
2answers
No error codes-washes but does not spin- water stuck in bottom
If your machine is a FAV6800A to FAV9800A here is the Service Manual.
If you lift the washer lid and rotate the wash basket CCW which is the Spin Cycle direction will it turn with very little resistance? It should not rotate CW.
With no error codes I would go to Service Mode page 14 of the Service Manual and read the current recorded Daig codes and write them down then clear the list.
Now start a Spin Only cycle with no clothes in the wash basket let it in that mode for about 5 minutes. Hit the off button to end the Spin Onlly cycle then check the Diag code block and see if an error event was logged if so please let us know.
If there is no error code generation by the Control Board in the Diag code blocks I would suspect a Control Board issue with your no Spin issue..
Without a known good Control Board and Motor Controller to swap out and no error code generation by the Control Board this would be a hard problem to troubleshoot.
The Control Board is under warranty for 5 yrs you could try Maytag Customer Service the number is in the SM and see if they will send you one even if the warranty is up…..Rich
High speed drum rinse ..drum not spinning during rinse cycle
Clean out coin collector thoroughly. Replace drain pump if necessary. Water will drain if you can place drain hose on floor and let water siphon out.
1helpful
2answers
Lower washing machine function inoperative in Maytag stackable
rclasky check this one
http://www.fixya.com/support/t827165-maytag_model_lsg7806aae
3helpful
Kenmore front-load washer stops at rinse cycle
When the washer initially fills for the wash, is it only hot water entering the drum? Try switching the water temperature between hot and cold as it fills. If any of them show little or no water getting through, it sounds too easy but check to make sure water supply taps are on, and that the cold/hot fill hoses aren't reversed. Remove the fill hoses and check any of the screen filters for blockage (in the hoses and in the inlet water valve). When the machine stops and waits to fill but all you hear is a hum, it sounds like there is power going to the valve but water is not able to get through it.
33helpful
2answers
Bosch classixx 1000 washing machine - stops on spin
Washing machine stops at the spin cycle - light flashes. Have to drain water out manually. Happened last week and was then able to run an empty rinse cycle. Machine worked normally for another week. Same problem today but have had to drain water manually from the drum after trying an empty 90 wash and rinse cycle (both stopped on the Spin and flashed). Any ideas? Thanks. x
2answers
Kenmore heavy duty 70 series washer
The washer starts on a fill cycle. If it's not getting any water check the screens in the valve where the water line hooks to the back. If it is getting water but not filling up pull up on the drain hose. If it is to far down the drain it can **** the water right out of the unit.
Top Washing Machines Experts
john h
