Question about SanDisk Sansa m230 MP3 Player
My computer dont recognized my mp3 m-230 what can i do ???
When i put my Mp3 into the Usb the computer dont recognized my mp3
i tried in any computers and much compuert yes recognized and much computers dont recognized what can i do ? is a path to this mp3 or software or drives ????
    Problem Solver:
  • 10 Answers
Mostly, mp3 devices comes with a software.
if u have the software, and the usb dont recognize your mp3 device. most probably the problem is in you usb drive or usb connector.
Posted on Feb 27, 2009
Computers don't recognize mp3 player
It's hard to help very much without knowing what kind of MP3 player it is but for starters you should:
1. Fully charge the device and then try plugging it in again
2. If that doesn't work try a different USB cable and/or different USB port on your computer.
Some players also have a reset button you could try.
Nov 06, 2013 | Audio Players & Recorders
Dont recognize to my pc
Try plugging it into a different usb port on the computer. If it does not work, try using a usb adapter to plug in to the usb port. It may also help if you restart the computer and connect it again. If this does not solve the problem, then the usb of the walkman mp3 player got fried which is due to improper disconnecting procedure of the mp3 from the computer; so make sure when removing any mp3 device, do a "safely remove" procedure.
Mar 01, 2011 | Sony Walkman NWZ-B135 MP3 Player
USB Port Not Recognized
Here Two Reason for USB Port Not Recognized:
1. Check you USB cable properly connected to the you computer, If cable break or not connected properly, It will show your cable not recognized.
2. If again these problem shows. go to,
My Computer - right click - Properties - Hardware - Device Manager - and Unistall you USB drivers - then again scan new hardware.
Jan 29, 2010 | Emerson BAR900 MP3 Player
My computer doesnt recognize my sansa express and it used to
check usb cable and make sure that the cable is connected properly .
Try connect to other usb port .
Hope it helps
Jul 17, 2009 | SanDisk Sansa c250 (2 GB) MP3 Player...
Old songs dont show
If you mean that the songs don't show up on the computer screen, then you probably need to change the USB MODE setting on the Clip. To do this, disconnect the Clip from the computer, then scroll to SETTINGS. Select Settings, then scroll to USB Mode and select it.. (If your Clip is very old it might not have a USB Mode listed under SETTINGS. If this is the case you should update your Clip's Firmware from the sansa website). Older computers recognize the MSC Mode while newer ones should recognize either mode. (except XP Professional doesn't seem to recognize the MTP mode). Songs entered in one mode won't show up on the computer if you're in the other mode. If you mean that the songs aren't showing up on the Clip's own screen then this solution probably won't help. By the way, I've never had any luck with the "auto detect" mode.
Jun 03, 2009 | SanDisk Sansa Clip MP3 Player
Dont know how to download music onto the craig mo3 player 1gb, model:CMP1226D
What you need to do is to just connect the MP3 to your computer via USB port then wait for the computer to recognize the MP3 player then when its already recognize double click Mycomputer icon and you should see there the MP3 , just double click on it and copy and paste the MP3 songs that you like to put on it.........
Oct 21, 2008 | Audio Players & Recorders
My computer wont recognize my mp3
I know this is only part of the solution:
- turn off your sansa clip
- put the slide button on hold
- press the centered button while connecting the sansa clip to your pc
the sansa clip will now be visible as a removable disk under 'my computer' :-)
I don't yet know how to proceed from here on
Sep 20, 2008 | SanDisk Sansa Clip MP3 Player
Computer won't recognize device
Your probably using the extension cable that came with the unit, try plugging the device directly into one of the rear ports on your computer without the USB extension cable, it should recognize.
May 26, 2008 | Coby MPC895 MP3 Player
Mp3
My computer will not recognize my usb when i plug it in.
Mar 30, 2008 | MyMusix PD-6030 MP3 Player
SanDisk Sansa m230 MP3 Player Logo
753 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
