Question about Western Digital Raptor X WD1500AHFD 150 GB SATA Hard Drive (Retail Version)
HARD DRIVE INCOMPATABILITY ISSUES
HI. I HAD TWO WD VELOCIRAPTORES INSTALLED IN MY PC AND CONTROLLED VIA AN ADD-IN 3WARE RAID CONTROLLER AND SET AS RAID 0. I RECENTLY PULLED ONE HARD DRIVE OUT AND THE 3WARE RAID CONTROLLER CARD OUT AND RELOADED MY VISTA/64 BIT OPERATING SYSTEM. EVERYTHING WORKS FINE, BUT I KEEP GETTING '' SECONDARY SLAVE DRIVE ADAPI INCOMPATABLE ' EVERY TIME MY PC BOOTS UP. MY MOTHERBOARD IS THE ASUS P5E3 DELUXE WIFI APP. NEITHER OF MY VELOCIRAPTORS CAME WITH ANY ' JUMPER ' ON THE BACK OF THEM. I ONLY HAVE THE ONE HARD DRIVE AND MY DVD PLAYER INSTALLED. CAN YOU HELP ME?? Thank you.
    Problem Solver:
I evidently figured this problem out on my own. Because I pulled these two drives apart and they were part of a two disc array, the 3Ware Raid controller assigned one as "master" and one as "slave". So, even though they will appear as perfectly good hard drives to ANY pc and you can load an O S on them, they will read as either a slave or master upon hard boot-up. There are two ways around this. One--you can leave them in your pc and "delete" the array in the BIOS and then re-format them, or Two--before or after you reload your O S, power down and unplug your pc. Then pull the COSMOS battery out and reset the "clear cosmos pins" on the motherboard. Leave the battery out for 3 to 5 minutes and then re-install the battery and re-set the "jumper pins" back to their original position. Ofcourse, if you had any overclocking settings previously set in the BIOS, you will have to set the parameters of your choice once you re-boot. It actually takes longer to write this explanation than to do the deed. Problem solved.
Posted on Feb 28, 2009
I recently upgraded my school server computer from 32 bit window xp to 64 bit window7. After that my raid drives were not detected. My raid drives are AMCC 9650SE-8LPML model, though. I think I need to...
Supposedly, there are no additional drivers required. Windows 7 should be able to use it by default:
http://www.microsoft.com/windows/compatibility/Windows-7/en-us/Details.aspx?type=Hardware&p=3ware%209650SE-8LPML%20RAID%20Controller&v=3ware&uid=&pf=2&pi=8&c=Graphics%20Cards%20%26%20Components&sc=Other%20Components&os=32-bit
Jul 30, 2010 | Computers & Internet
Tip
Problem Using Windows Install Disc with RAID? Some Tips:
After going through some issues installing Windows onto a RAID partition using this Motherboard, I found some things that were helpful.<br /><br /><span style="font-weight: bold;">#1 Install hangs, or I get an error after Installing RAID Driver.</span> Nowhere in the manual does it tell you this (or at least I didn't see it) but when you install the RAID driver during the windows install, the Motherboard automatically sets SATA connectors 1, 2, 3, and 4 to be RAID. That means if the DVD/CD Rom you are using is plugged in to any of those connections, the minute you install the RAID Driver, the Optical Drive will no longer work. You have to use SATA 5 connector on the motherboard for your optical drive<br /><br /><span style="font-weight: bold;">#2 Multiple Optical Drives with RAID</span>. Because of the issue in #1, there is really only 1 internal SATA Port you can plug an Optical drive into when you have RAID configured. There are some solutions if you want more than 1 Optical Drive alongside your RAID configurations. <br /><br />You can use the ESATA port on the back of the Motherboard with an extra-long SATA cable. If your case has grommets on the back for water-cooling lines, you can run the cable through there, or just in an unused PCI slot on the back.<br /><br />You can use an old-school PATA DVDrom. If you are installing 2 Optical drives, and one is a DVD burner or reader, you could get a PATA DVD Burner or reader instead. This Motherboard does have a good old fashioned ribbon connection, so it's possible. Typically DVDs or CDs don't move enough data to see a difference between PATA and SATA, but when you start getting into any DVD reading/Writing above 8X or so, you will be throttled.<br /><br />Get a PCIe controller card. I think of this as the last resort for this board because of it's possibility with graphics cards. Hooking up anything unnecessary to any of the PCI slots would be defeating the purpose of having 2 full 16X PCIe slots. You might be able to squeeze one in on one of the 1X connections, or maybe the bottom full slot, but it could get cramped if you have 2 or more Video cards.<br /><br /><span style="font-weight: bold;">#3 Windows Installation Issues. DVD Drive Stops Reading during install.</span> I had this issue even after finding out my issue from tip #1. I found that some windows install discs mixed with some manufacturer's DVD drives don't get along well. It would start the installation OK, and get most of the way through it, then it would hang and throw up an error. It seems that during Installation, the SATA DVD drive decides that doesn't like the generic drivers anymore, and just stops working. I fixed this by pulling a PATA DVD drive out of an older PC to use until Windows was fully installed. Once Windows was installed, I pulled that drive back out, and Installed my SATA DVD drive, and Windows installed the drivers with no problems.<br /><br /><span style="font-weight: bold;">#4 RAID Performance. </span>I'm not too sure that I'm getting the best performance from this RAID-0 configuration. I'm running 2 WD Caviar Black 500GB HDDs. My Windows Experience score for the drives is still 5.9. Perhaps the RAID configuration would work better with some faster drives, like Samsung drives, or WD Velociraptors... But I'm unsure.<br />
on Apr 03, 2011 | ASUS M4A79T Deluxe ( M4A79T DLX MB PHENOM...
To raid, or not to raid,? that is the question............
Always a good question,
For #1
Always a good idea to mirror your OS drive for quick recovery. So yes I would use 40GB of the velociraptor for a mirror. However if your board supports it I would actually suggest you would be better served for your dollar to buy some 500GB+ WD greens or seagate 7200.12's(do NOT buy 7200.11) then set them up as raid5, frankly you'll get redundancy and speed, with more space. 4 Greens will perform as well as three VRs and cost less.
I currently run two Greens and 2 7200.12's on my home server and the 7 rating is 7.6 for my HDD and I've got 4.2TB of space for under $500.
I mentions some of the pro's and cons in detail on my blog last week Pro's and Cons.
Hope this helps,
Chris
Mar 07, 2010 | Computers & Internet
Dell inspiron 1721 hard drive not recognized for Vista reinstall
ok, theres a small issue with the raid controller. You have to install a 3rd party raid driver (its on the dell cd) to continue, OR, you can set that BIOS's hard drive controls to ATA or LEGACY (legacy would likely work best, but youd have no 'raid' functions, but who sets up raid drives on a notebook?). Your last option is use the dell discs to restore, and inssert the windws disc when prompted
Nov 04, 2009 | Dell Inspiron 1721 Notebook
I put 2 disks in raid 0 array on this controller
When you say "after merging the driver via a floppy at the txt setup" I think you are referring to pressing the F6 key to load the raid drivers. But I don't understand "restarting setup".
You will need the correct XP64bit drivers loaded on a floppy for this to work.
Maybe a good place to start is a temporary install of XP using 32bit drivers to prove all components are working.
Nov 01, 2009 | Adaptec 1220SA (2232100-R) Storage...
How to install raid controller for my PM 800 BMS motherboard pc
hi,
here's the document I used to configured my raid.
http://www.3ware.com/support/UserDocs/InstallGuide-9.2.1.1.pdf
see if it helps you.
good luck.
Mar 31, 2009 | Jetway PM800BMS Motherboard
Raid 0 on Intellistation 6221?
That particular work station comes with both IDE and SCSI drive interface controllers. The IDE drive should be used for your OS. The SCSI drives for your data storage. Now, the issue is to get the SCSI to work in RAID_0 as I understand.
You iwll need a RAID controller such as Adaptec AHA-3940AU WD SCSI Host Controller, which may be found on eBay (used) for a very affordable price. The driver software may be downloaded directly from Adaptec, so I suggest you do that in the iterim peroid, and store drivers on a USB thumb drive.
Hope this helps you.
Dec 21, 2008 | IBM IntelliStation Z Pro 6221 PC Desktop
I still cant figure it out....no sound...
Uninstall Previous Sound Drivers & Install new one. I am online now & can help you out with remote assistance.
Aug 06, 2008 | Computers & Internet
Biostar P4M800-M7A Motherboard SATA RaiD Mirror Array As C boot Disk
hi, you need not have to upgrade the BIOS,, set the SATA HD on the IDE channel in the BIOS, or what options r avilable for SATA controller, if it is set to RAID, you will need a raid utility to format the SATA, or it wont shoe in windows, let ,e know
Dec 17, 2007 | Biostar P4M800-M7A Motherboard
M7NCD ULTRA raid drivers
If the SATA drive is operating in 3.0 Gbps mode and your motherboard can only support 1.5 Gbps mode, the drive will not be detected in BIOS or XP. Try jumpering the drive to SATA 1.5 Gbps mode. The label on your hard drive should indicate which pins should be shorted to achieve this setting; if not, look up your particular model on WD's website to find the manual.
Nov 05, 2007 | Biostar M7NCD ULTRA Motherboard
Western Digital Raptor  X WD1500AHFD 150 GB SATA Hard Drive (Retail Version) Logo
115 people viewed this question
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Marcin
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
