Question about HP Pavilion dv2500t Notebook
When i power on,screen is blank, memory n processor are good too.
The processor is AMD, the power and wireless light are on. even if i try to turn off it's not turning off even all the lights are on but the screen is blank.
  • 4 Answers
Try connecting an external monitor to the laptop and powering it on. If the external monitor allows you to view the windows screen the display may be bad. Also try removing all the power sources, battery and power adapter, then reconnect and try booting the computer. While you are at it, check the contrast and brightness function key to see if the screen can be adjusted in.
Posted on Feb 27, 2009
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 94 Answers
You need to check your RAM, if in case, remove it, then you need to clean the terminals (the gold ones found in the bottom, then clean it with a pencil eraser, then put it back. do not use any cleaning liquids as this may destroy the RAM
Why is my screen blank when I turn on my computer?
Before starting your laptop up... try to remove and clean the connector surface of the memory card/s with pencil eraser,soft cloth or tissue paper. Then insert the memory card/s back properly. check the unit if it is booting up nicely.
Aug 18, 2014 | ASUS Laptop AMD E1 1200 Processor X501U...
I have a emachines amd athlon 64/ 512mb memory / 160gb hadr drive dessk top. when i turn it on the monitor displays no signal and goes off. ihear the prossessor motor running constantly which normally goes...
Please check the cable that connects the monitor to the video card. Reseat the cable, the issue might be a loose connection. You can also try a known good monitor to isolate if it's the video card or monitor that is causing the problem. Something is preventing the monitor from receiving signals from the video card, hence the "no signal" message.
May 19, 2011 | eMachines Desktop / AMD Athlon Processor /...
Sir , i found my mother board is good . but , my processor failed to boot mine is AMD ANTHLON 64 3500+ . I dont have even a small damage to the pins in the processor , everything is good. my processor...
Processors do not fail unless they are mishandled or installed incorrectly. This system is very old and uses memory that is no longer available. Try starting your system with no memory, does it start to beep repeatedly? The memory may be at fault. No beep, could be the motherboard has failed.
You will not find replacement parts, you will need a new system.
Feb 13, 2011 | AMD Athlon64 2800+, 1.8 GHz Athlon 64...
I just got my Biostar A780L and i put a amd phenom 2 2.8ghz 920 quad core in it and when i try to start it up it sounds like its working but the screen just stays blank, like the monitor doesent even turn...
No noise, no beeps whatsoever?
If no beeps, MBoard may be defective, or RAM might be bad, maybe one of the drives.
You need to d differential diagnosis.
Try removing everything but the CPU and see if it will POST.
If so, add 1 stick RAM, then 2nd stick, then Drive, then ,,,,,, until you find culprit.
If nothing works, would try another "known good" power supply
If that is no go, Mboard bad.
Feb 04, 2011 | Biostar A780L Motherboard w/ AMD Athlon X2...
Pc turns on but nothing come on the screen.tried several things such as,substituting parts like the power supply,processor,memory,hard dirve.I also cleaned it.the only thing left is to try a pci express...
if nothing was showing up on the screen I would have checked the Video card first as its one of the simplest things to check but you need to borrow someone elses.
The light would be on cause the BIOS is looking for a hard drive. If you connect speakers or headphones see if you can hear windows booting up if there is something installed on it. If you can hear windows starting up good! its probably your video card. If nothing then your motherboard might be the culprit.
Apr 05, 2010 | Everex GA3400 Refurbished AMD Desktop...
Acer veriton M460 will not boot up
The acer veriton m460 has three faulty capacitors. Check and see if you have bulgy capacitors. I have ten of these computers and all have three blown capacitors.
Jul 31, 2009 | Acer-Veriton-M410-US3800P AMD Desktop PC -...
Blank monitor upon turning on PC
Well.... The motherboard could be dead... or check the power supply unit. Check the memory chips, see if the capacitors around the processor looks blown up (then motherboard is kaput) or make sure the monitor is properly connected to the motherboard monitor port... It could be numerous reasons ... See if the processor cooler fan is running and check if the processor's cooling paste is OK which would cause the processor to run TOO HOT and would prevent the PC to start-up etc etc....
Jul 20, 2009 | AMD M863G (M863G15CV22ARV000) Motherboard
Loud fan blank screen andthe fan is lousd.
check your memory, processor, PSU (power supply) and your motherboard, any one of these components could be the problem, if its intel it will be the processor or motherboard, if its AMD its no doubt memory or PSU. quick way to sort the problem in most cases is to reset the cmos/bios, this is situated near the battery on the motherboard in the pc ( if you have it right the pc will not turn on when you press the power button ) put the plastic jumper back in the possition you found it and restart your pc. if that doesn't work then look into what i said above
good luck
PS use a torch to see where the cmos reset is
Nov 14, 2008 | Compaq Evo N1020V Notebook
LATE BOOTING OF PC
I would back up all my data and reload a fresh operating system if I were you. Also You could really use more memory. These days 2 gig is light.
Hope this was helpful,
George
Jul 15, 2008 | Intel Motherboard
Processor issue? bios/motherboard?
First, Pull the hard drive. If the hard drive shorts out it can cause all sorts of problems. Generally it detects Hdd before mouse and keyboard.
Apr 18, 2008 | Averatec 3200 Notebook
HP Pavilion dv2500t Notebook Logo
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
