Question about Microsoft Metrologic MS9520 Voyager Handheld Scanner Handheld Barcode Scanner
MY SCANNER IS WORKING MANUALLY NOT AUTOMATICALLY KINDLY TELL ME HOW TO CONFIGURE IT
  • zakir_hussai Mar 02, 2009
    I NEED MANUAL TO CONFIGURE IT AS YOUR POSTED HAD NOT WORKED IN MY PROBLEM.
  • 32 Answers
You should have options how to do this in the scannning window look under settings
actionman
Posted on Feb 27, 2009
Why doesn't it scan?
usually you need to configure the reader to tell it what kind of barcodes you want it to read and how to interpret & output the codes to your computer (whether you need prefix or suffixes to your codes( for automation))
the user manual for the reader has some bar codes to configure the settings for the scanner.
Jan 27, 2016 | Zebra Symbol LS4278, Bluetooth, Blood Bank...
Hello, Can you please tell me if you can configure the HHP Handhel Scanner to NOT beep on a unsuccessful scan? Currently our scanners do deep on a unsucessful scan. Can you also tell me if we need to...
Maybe there is a code configuration for this. Plese check the user's guide: http://www.geoti.co.kr/DATA/hhp/IT3800_3900%20Users%20Guide.pdf
Hope it helps!
Jan 16, 2011 | HHP IT3800 Handheld
No internet connection
Problems that can cause this problem are :
- gprs and wap configuration was not right or not activated. Some provider of SIM card require activation via message to send activation setting to your phone. After this activation, phone usually can connect to internet automatically.
Some of SIM card will configure this setting automatically after put in a phone, but other SIM card need manual configuration. Make sure you've configure internet connection in your phone properly.
- another problem is signal strenght or continuity. If you make a connection in closed building or other place with low signal, you may can't connect to the internet.
Hope this help and be kind to rate please, thank you
(^_^)
Jan 07, 2011 | Nokia 5230 Cell Phone
I HAVE LOST CD FOR INSTALLATION FOR SCANNER PLUSTEK OPTIC Pro U12B. kindly tell how to install scanner in my computer
1.First download the scanner driver- ->Plustek OpticPro U12B driver(Windows XP ver.)_ 2.Save it somewhere where you will remember after download . We recommend that you save it on your desktop , so it will be easy to find ..
3.Double- click the file you downloaded .
4. Follow the on-screen instructions.
5.When it's successfully installed , please restart your computer
6.After you have restarted the computer , plug the scanner into your computer and it will automatically recognize the new hardware.
Nov 26, 2010 | Plustek OpticPro U12B Flatbed Scanner
Looking for a Manual for an OLDER Schwinn Airdyne, cannot find any numbers. "Computer" has only 5 buttons plus 2 "select" buttons on Work/Speed, Time/Total. Buttons labelled left to right: Time/Reset,...
Send me your email address & I will send you a copy of the airdyne manual I scanned. It is a pdf copy which has description and instructions for your Airdyne computer. It has automatic (scans all features) and manual (stays on the 2 items you select in the display windows)and tells you how to change from manual to automatic and how to operate the computer. (terpcafe@yahoo.com)
Aug 11, 2010 | Schwinn Original Airdyne
Laptop doesn't recognize. but its red light is on and if i try to scan, it beeps, but no data is input into the computer
dear sir
if you are using some kind of converters or terminators please do replace it or try to connect the device directly to the computer
thank you
Sep 22, 2009 | HHP IT3800 Handheld
HHP Handheld IT3800lr-12 - i can't configure it to USB
If you have the manual, try to cofigure it to USB Keyboard and/or to LAPTOP DIRECT CONNECT. This last option is on page 1-7 in the manual I have with me. Please let me know if it works... Good luck!
Dec 15, 2008 | HHP Hand Held Products IT3800LR-12 Barcode...
Ms9535 bt not reading barcodes.
I'm using the same Barcode reader, the Metrologic MS9535 VoyagerBT.
The brief humming noize is called a "Rasbery tone" in the manual. It means that the barcode reader is not configured to read that kind of barcode, a barcode Code if you will.
There are many types of barcodes so you have to go to the Metrologic Website and get the Barcode Configuration tool to configure your barcode reader to read the type of codes you will be using.
Alternatively there is a book with configuration barcodes you can scan to configure your barcode reader manually.
Sep 28, 2008 | Metrologic Instruments MS9535 VoyagerBT...
Mfc 8440 scanner installation onto my computer
After I installed the print/fax/scanner drivers on my computer, Paint automatically configured itself to recognize the scanner. Other image programs I had to manually configure the TWAIN source before I could import from the scanner.
Apr 14, 2008 | Brother MFC-8440 All-In-One Laser Printer
Imageteam IT3800 scanner won't hold the config.
Does the scanner use a small battery to keep the stored information? If it does, this battery might be defective.
Feb 26, 2007 | HHP ImageTeam 3800LT (3800ltp-12) Handheld
Microsoft Metrologic MS9520 Voyager Handheld Scanner Handheld Barcode Scanner Logo
332 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
