Question about Tools & Hardware - Others
Ryobi rs-45 sander will not run
Power outlet good. Need to disassemble to check switch, etc. Cannot get case halves to separate after removing the case screws. What to do next?
  • 32 Answers
If you can not separate the case you missed a screw somewhere, happened to me many times, look closer there is another one, they have a way to hide one on you
Posted on Jul 18, 2009
I have removed all the screws but cannot separate the two halves. What else must I do to disassemble this?
make sure all screws are out first. the 2 halves are held together with clips. they will be hard to pull apart. try and make a small opening with a knife between the 2 halves and work around untill you come across a clip, push down on the clip to release it . there will be a few holding them together and you might find if you unclip one and move on it will clip back into place so a few thin instruments will be needed all the way around
May 01, 2015 | Tools & Hardware - Others
Ryobi problems
This is not that bad of a problem we should be able to resolve this-
bring a lamp or radio which ever one you have used and know it works plug it into the wall outlet if your lamp or radio work then we know its the plug, now plug in yr Ryobi random orbital sander it should work to do not involve an extension cord while we are trouble shooting if neither have worked on the same plug you must have a 3 way light switch on the wall that needs to be turned on, try and slightly spread the the metal blades on yr Ryobi outward for a better contact between cord blades and wall plug make sure you have firmly pressed in the the on off switch.
Ryobi tests all of its factory reconditioned power tools before they are sent back to be sold in stores to the public...
Aug 10, 2014 | Ryobi Factory Reconditioned ZRRS290 2.6...
My Porter Cable 4x24 VS belt sander has clogged up and I cannot get it unclogged. I've tried to disassemble it to get at the sanding dust channels but have had no luck at separating the two halves of the...
did you remove the screws that are under the handle halves, and before I completely disassemble the tool do you have a shop vacuum and if so remove the dust bag and put the hose on that outlet and run the tool and see if it pulls anything out. I would only split the halves as a last resort. Let me know if you need more assistance.
Feb 19, 2011 | Porter Cable Cable 363 4" x 24" 1500 SPFM...
Palm sander 6016... i have to replace the
you dont need a puller for the fan, remove the lower pad assembly and the torx screw holding the bearing in place. use a screwdriver to gently lift the fan. the bottom of tool has to be disassembled to open the halves. Go to Milwaukeetools.com and type in your model number under the download section for a parts/tool explosion. Let me know if you need more assistance
Aug 25, 2010 | Milwaukee Tool Milwaukee 1/4 Sheet Orbital...
My wife and I just moved into our house and cannot get anything on the dishwasher to activate. We have checked fuses, lightswitches that might be wired to DW power -- nothing has worked. Is there a...
Sounds like a power supply issue. Take off the lower panels below the door and look to the right side of the opening, you will see a little square steel cover. This cover is where your power comes into the dishwasher. Follow the line coming into the dishwasher, it will either be a power cord that leads to an outlet, or a regular power line coming in. IF it leads to an outlet, try plugging something into the outlet. If the outlet is under the sink, try switching the plug from the top outlet to the bottom one (or vice~versa). Sometimes the outlets under sinks are set up so that a garbage disposer can be plugged into one of the outlets that is controlled by a wall switch.
If you get no power to the outlet, and all of your breakers are on, look for a GFI outlet that may have been tripped. These outlets have the little "test" and "reset" buttons on them and often are wired in parallel so that multiple outlets are powered (and protected) by one GFI.
Lastly if you have determined that there is power to the outlet, remove the cover under the dishwasher and inspect the wire connections. I have found many machines that had poor connections causing the wire nuts to burn right off the cord connections.
Now if everything else checks out power wise, you may have a blown fuse located on the control board housing inside the console of the machine. Get the part before you disassemble the door. To access it you will have to remove all the screws around the inner door liner and separate the two halves of the door. The control board is in the top right corner of the door and is usually under a plastic cover. The fuse is a small white thing that clips to the control board housing.
Good luck! Hope this helps you out!
Jun 27, 2010 | Whirlpool DU930PWS Built-in Dishwasher
How do I replace the power cord for a makita palm sander? Specifically once all the visible screws are removed how does one separate the two body havles?
without knowing what the model number is you also have to remove the pad assembly and usually you will find some there if all removed you can GENTLY pry the cover halves apart. Go to Makitatools.com with you model number and you can download a breakdown for this tool.
Mar 14, 2010 | Makita Tools & Hardware - Others
How does one open the case of a braun multimix 220w - i removed the screw in the front, but something else is holding it together
You need to remove the base plate by carefully prying it open at the opposite end of where the electric cord is fitted. Then release the two halves working along the edges with a thin blunt object. Also carefully remove the sliding cover for the center power mixer outlet before separating the halves.
Jan 01, 2010 | Braun M880 MultiMix Hand Mixer
I have a ryobi belt sander EBS81321K Serial no 048911. The switch has developed a fault. Could you please advise where I can get a replacement & what would the cost be
Is that a BE321VS belt sander? I'm not getting any hits on that number you listed, and Ryobi is a little picky about what model number you use to search their parts database...
If it is, try this link to see a page where you can access a parts list. http://www.ryobitools.com/support/parts_batteries
Click on the button to go to the Power Tools Parts Store, then click Repair Parts Catalog, then agree to terms and enter the catalog page. Select the Model tab, type 321 in the box and press Search...
That brings you to a page listing the BE321VS sander.
Select Illustrated parts list and click on belt sander. This will open the parts view. From there you can scroll down to see if that is in fact your sander, and if so, scroll down to part 23, and select the switch (#760390001) and add it to your cart. Now close the window with the part view, and navigate back to the page titled "Ryobi Electronic Parts Catalog" (a tab on your browser), click on shopping cart at top, and when that opens click on the button to proceed to checkout and enter your info and pay, etc.
The cost of the switch is $4.44 USD. This web site will only ship to a street address in the US, so let me know if you reside elsewhere....
Mar 27, 2009 | Ryobi Tools & Hardware - Others
Cannot disassemble Milwaukee 6016 to replace brushes
exactly what screws did you remove. you have to remove the bottom platen first (pad) then remove the housing screws. you need to remove the fan also and then might need to apply some pressure to split the housing halves.
Mar 03, 2009 | Milwaukee Tool Milwaukee 1/4 Sheet Orbital...
Tools & Hardware - Others Logo
150 people viewed this question
Top Tools & Hardware - Others Experts
J.D. Browning
J.D. Browning
Are you a Tool and Hardware - Other Expert? Answer questions, earn points and help others
