Question about Euro-Pro F1066 Deep Fryer
Won't reach temperature
My fryer will not get above 250 degrees. Anyone have a similar issue. I purchased a new element and control panel. Used not more than 6 times and now having this issue. I'll never buy another Euro product.
  • 68 Answers
If everything electrically is ok, there might be a reason outside of fryer:
- power voltage is lower then required for nominal power (borrow voltmeter and check)
- the fryer is positioned at drafty place so it get's cooled up by air.
Posted on Feb 27, 2009
My Frigidaire dual fuel oven wont get hot. Both heat elements and temperature sensor have been replaced and it still only gets warm. No error codes are displayed.
Thank you for your post, Chrissie!
I understand that your Frigidaire duel fuel oven is not heating properly. I see that you have replaced your temperature sensor and heating elements and your oven is still not working. This could be a possible issue with your control panel or wiring harness. Since it could be anyone of these underlying issues I would recommend having a professional technician out. This will help you avoid any unnecessary part purchases. Hopefully this is helpful information. -Matt
Jun 01, 2015 | Frigidaire Ovens
My Pitco fryer heats up and operate normally at 250 degrees when I set to 300 degrees, it heats up and when it reached 300 degrees, it shuts down bunner as well as the pilot light
CHECK THE SMALL SOLINOID THAT FEED THE PILOT IF THAT OPENES EVERYTIME THE FRYER STARTES THERES YOUR PROBLEM REPLACE IT AND ALL SHOULD BE WELL
Feb 09, 2014 | Pitco Frialator Kitchen Appliances -...
Hotpoint oven won't heat above 250 degrees broiler works fine as well as the stove top
either its the oven sensor rod located at the top of the ovens cavity,or your bake element could be getting a hot spot which is when it gets a discolored spot in the element and can no longer pass sufficient current to heat the oven past 250 degrees
Jul 28, 2012 | Hotpoint Ovens
What is the reason for the reset button keep poping out on the dean sm35gm
Hi there!
Reset button of hi-limit switch will only pop-out when its sensing bulb sensed temperature higher tha 450F (trip temperature of hi-limit). Theramostat may be bad allowing oil to reach temp above 450F causing hi-limit to trip-off or hi-limit itself is bad tripping-off at temperature lower than 450F.
Check also the position of the sensing bulb of the hi-limit, it may be positioned touching the heat tube (for gas fryer) or heating element (for electric fryer) that's why it prematurely trips-off.
Regards.
May 11, 2012 | Dean SM20G2 Deep Fryer
Fryer overflows often, turned thermostat down from 350 to approx 340 but food does not cook then. could the thermostat be bad? 10 degrees should not make that much difference.
Does the fryer have a" temperature reached light"? If so switch the fryer on and with the thermostat dial starting at its lowest setting increase the temperature setting in small increments. When the light indicates temperature reached, increase the thermostat dial temperature. Continue until maximum temperature reached.
If (starting from cold) the temerature reached light only shows when high up on the thermostats temperature scale, then unfortunately the thermostat needs replacing.
Hope this helps.
Mar 04, 2011 | Dean D50G-C Deep Fryer
Flame goes off when temp. reaches 250 degrees, use to stay on 350 degrees without problems an them started acting up and won't reach that temp any more, disconnect the pilot automaticly
Hi limit device trips prematurely (should only trip when oil temp reaches 450F). Check if the hi limit sensing bulb (located inside the fryer tank, between fire tubes) is not touching the fire tube because if it does, it will sense the heat from burner flame which is much higher than oil temp.
Feb 21, 2011 | Pitco Frialator 45C Deep Fryer
Oven is not reaching proper temperatures
You most likely have either a faulty thermistor or heating element that will need to be replaced.
Nov 10, 2009 | Magic Chef Kitchen Ranges
High limit kicks out fryer and pilot light can
Since you've mention the pilot light goes out at 400 degree F, then we are talking a gas Deep Fryer. The deepfryer usually use at 350 degree F for chips or else. Because the oil will start breaking down its quantity of frying very quickly over that temperature. Most people set at 350 degree F. Now we comes back to your problem, First you should have a deep fryer thermometer they espcially made for deep fryer, (You only mention 400 or better ) that make me think you're only guessing. Knowing the temperature is very important, most Hi limit is set at 420 degree F.
To me it seen the Hi Ltd control is working and that is why it cutting out the pilot when it reach its limit but we don't know what temperature that when the hi limit cutting out at.
When you have a thermometer, put it in the cold oil and turn the temperature to 100 degree F to see what the temperature control cutting out at. slowly increase your setting until it cutting out at 350 degree F . If you set at 250 degree F and the thermometer already reaching 350 degreen F then don't go any further , your temperature control is defective and need to be change a new one.
This is only the first step, you still have to check out the Hi ltd control to see how good its condition is,so far your information say it cutting out at 400 or better. But you've to be sure, because it is a safety control. Hope that will help you , God Bless.
Jul 05, 2009 | Pitco Frialator SG14 Deep Fryer
Fryer will only go to 250 degrees
Need to calibrate the thermostate,or replace it
Mar 12, 2009 | Imperial IFS40 Deep Fryer
Oven does not maintain temperature. Part 2
sometimes when they get hot that is when they fail
Sep 18, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
Euro-Pro F1066 Deep Fryer Logo
186 people viewed this question
Top Euro-Pro Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Gerry Harvey
Gerry Harvey
Clarice Bornschein
Level 1 Expert
Are you an Euro-Pro Kitchen Appliances - Other Expert? Answer questions, earn points and help others
