Question about Panasonic KX-T7730 Corded Phone
Date and time do not change
I can program in the date and time, but once I do they do not change does anyone know how I can solve this problem. It is a Panasonic KX-T7730 phone.
  • sanltd Mar 03, 2009
    The phone is plugged into a KX-TA624 system. It is only just recently that this problem has occured.
  • Anonymous Mar 04, 2009
    I have the same problem he phone is out by 50 mins
  • Panasonic Master
  • 2,460 Answers
Did you press the STORE button?
If the time is changing by hours, it may be that CID is set for the wrong area. IIRC Caller ID resets by the first call after 3AM. If that's the case, please post your phone system model that the phones plug into. It may be a TA-624/824 or any one of the other 18 or so models that the phone will work with.
Carl
Posted on Mar 02, 2009
  • Carl Navarro
    Carl Navarro Mar 03, 2009
    Why did you rate the solution as TFT before it was resolved?
    In the FixYa scheme, a TFT is the same as a negative rating, so you give me a negative, THEN you reply to the question asked in the first solution?
    1. Is the clock frozen.
    2. Is it off by minutes or whole hours?
    3. Do you have a CID card in the system?
    4. When you change the clock is the new time stored on the display for a) minutes b)hours c) til 3AM?
Time and date lost when changing batteries, any suggestions
If you change the batteries within a few seconds then the Date and Time will not be lost.
Jan 03, 2013 | Sony Cyber-Shot DSC-P71 Digital Camera
Programing
ONCE YOU HAVE ENTERED THE RIGHT DATE THE NEXT STEP SHOULD BE THE TIME TIME SETTING THEN YOU WILL SEE THE SETTING TO SAVE THE BOTH THE TIME AND DATE USUALLY THE 3RD BUTTON ON THE FACE OF THE PHONE.
Jul 23, 2010 | Panasonic KX-TG1033S Cordless Phone
My office has the Prostar 816 phone and the manual is not detailed at all.. I needed to know how to change the time (due to time change) Our manual says #55 etc etc... Help me please!
To change the time on a prostar 816 you first need to be at a display set (doesn't matter what the extension number is).
with the handset down, enter #20 the screen should say MMC DISABLED
1) enter in 1 2 3 4 1 # (that enables programming2.gif)
2) enter in #55 the screen should say YYMMDDWHHMM
3) enter in the year, month, day, day of the week, hours and minutes(the day of the week values are 1= mon. 2= tues. etc.)
press # when finished.
Nov 12, 2009 | Samsung Prostar 824 Keyset Telephone
Norstar 7324 time change
Programming should be done from the M7310, M7324 or the T7316E set. Administration access code: Feature * * 266344 which also is Feature * * config.
If asked for a password enter 23646.
When in programming2.gif just press the next button(lower right arrow) until you see what you want to change. Then press show ( top right arrow) ,then change if you want to change it. If you pass it, just press back (lower left)
Example: To change the Time & Date Press next until you see Time & Date. Then show Then change Then change again, change it if you need to, Then next again until you see what you need to change. For example; only the hour needs to be changed for day light savings time. Just press next until you come to the Hour. Then Change it. Then press release RLs when your done.
Sep 21, 2009 | NorStar Meridian M7310 Phone
Need to change the time
You weren't precise if the change was due to Daylight Savings Time or just a general need to change the time so I'm giving you the complete set of instructions for changing the time
Setting the Time
Note: Use 24 hour and 60 minute format when setting the time.
For example: 2:00 pm = 14:00.
1. To make changes to your clock’s time setting, you must first put the clock into Program mode. See
section Accessing Program Mode to Update Calendar, Time and DST for instructions. When the
display flashes P1 dAtE, press the ◄ left button until P2 CL oc appears, then press the ● right
button.
2. Press the ◄ left button to choose 12-hour AM/PM display or 24-hour military time, then press the ●
right button.
3. Press the ◄ left button until the correct hour appears, then press the ● right button.
4. Press the ◄ left button until the correct minutes appear, then press the ● right button.
5. When the display flashes the correct time, press the ● right button.
6. The display flashes P2 CL oc again. To make changes to the DST start date or DST end date, press
the ◄ left button one time until P3 BDLE appears in the display and continue to How to Set the
Begin Date for DST. Otherwise, press the ◄ left button several times until END appears, and select
the ● right button to save your updated settings.
How to Disable DST
To disable Daylight Saving Time, set the DST beginning date equal to the ending date (i.e., DST begin
date = 08-03-09; DST end date = 08-03-09).
See next for details regarding setting the DST begin date and end date. Typically, clocks operating in
Arizona, Hawaii and Puerto Rico do not observe DST, and disabling the DST function typically applies to
those areas only.
By default, and unless otherwise modified, DST takes effect on the first Sunday in April and ends on the
last Sunday in October (this was the United States standard through 2006).
How to Set the Begin Date for DST
Note that in 2007 the standard for DST changes to a different start date and end date. The steps below
correct the change in the new start date for DST. The new start date and end date need only be changed
once, since the clock’s rolling calendar function auto-calculates the start date and end date for DST every
year thereafter.
Note that if the begin date for DST has passed, in addition to modifying the begin date (and end date),
you will also need to modify the time.
1. When the display flashes P1 dAtE (see earlier section Accessing Program Mode to Update
Calendar, Time and DST for instruction), press the ◄ left button until P3 bdLt appears, then press
the ● right button.
2. Press the ◄ left button until the correct year appears, then press the ● right button.
3. Press the ◄ left button until the correct month appears, then press the ● right button.
4. Press the ◄ left button until the correct date appears, then press the ● right button.
5. When the display flashes the correct year, month and date, press the ● right button.
6. When the display flashes P3 bdLt, press the ◄ left button once to select next menu option, P4
EdLt, which provides a way to set the end date of the Daylight Saving period.
Setting Daylight Savings Time for model PIX-10/15/21
Page 4 of 4
How to Set the End Date for DST
correct the change in the new end date for DST. The new start date and end date need only be changed
year thereafter.
1. When the display flashes P4 EdLt (see conclusion of previous section How to Set the Begin Date
for DST for instruction), press the ● right button.
6. The display flashes P4 EdLt again. Press the ◄ left button several times until END appears, and
select the ● right button to save your updated settings.
Note: To disable the Daylight Saving Setting, set the beginning and ending date to the same date.
Apr 16, 2009 | Office Equipment & Supplies
Panasonic KXT7453
To set date and time on your phone system you must first enter user programming mode.
Using a display phone with the receiver hung up.
Press PROGRAM
Dial ** 1234 (SYS PROG NO)
Dial 000 (DATE AND TIME)
Press SP-PHONE key once (display shows current date)
Normally this is correct if not dial the changes in with your keypad. Use the FWD\DND key to
move forward on the display and the CONF key to move backwards.
Press AUTO DIAL STORE (Confirmation tone)
Press SP-PHONE key once (display shows current time flashing on hour)
Dial new hour (Two digits) Use the FWD\DND key to move forward on the display and the
CONF key to move backwards. Dial in any changes and when your done:
Press HOLD (SYS PROG NO)
Press PROGRAM
Your phone should be back to normal.
Nov 03, 2008 | Panasonic KX-T7453 Corded Phone
Date Changing
you shud try change settings so that date and time will auto update. this is under settings, date & time, auto update....mite work!
Jan 10, 2008 | LG Prada KE850 Cellular Phone
Time & Date Stamp
The date and time (and a lot more) are stored with every image. Any photo printing program should have an option for printing the date and time on the picture (or in the margin or even on the back if the printer is two-sided).
Jul 07, 2007 | Olympus Camedia C-3030 Zoom Digital Camera
Managing the Time and Date
I have found the answer to the date problem. The date is hidden and will not show up unless you insert it during printing. When printing in ACDsee select print image, then click on the CAPTION tab, and de-select the box the says "insert date at lower RH corner" or somthing like that. Once it is de-selected it will stay off untill you select it again. By the way you can look into the camera with Microsoft explorer, or any program to copy or open the picture. In my case it is "drive G". I opened Photoshop and drilled down into the camera through drive G, and was able to open the photo without any special dedicated program.
Sep 13, 2005 | Pentax Optio S4 Digital Camera
Panasonic KX-T7730 Corded Phone Logo
207 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
