Question about Casio Cameras
INSTRUCTIONS I NEED INSTRUCTIONS ON HOW TO WORK MY CAMERA
  • 10,594 Answers
Click Casio Support to download instruction manual of EX-S10
Posted on Feb 27, 2009
Loaded new firmware for Kodak easyshare v1253 camera, it failed to upgrade the firmware , getting the message "file_extract_error" and now the camera will not work at all.
When it comes to firmware installations, if you don't follow every detail of the installation instructions, you can end up with a dead camera. You need to contact Kodak for further instructions.
Jun 15, 2011 | Cameras
Instruction manual needed
Dear Marie1954,
Can you please tell me the make and model of the camera that you need the instruction manual for? As soon as I have this I can get right to work and find the manual that you will need.
Hope to hear from you soon
Yours sincerely
Oz
Feb 28, 2011 | Cameras
I dont now how the camera works.
You need to get user/ instruction manual copy of camera to know about its features and operational details.
Click Sony Support link to download instruction manual free copy that has all details about Sony DCR-PC115E camera, it will help you operate camera.
Thanks.
Jan 06, 2011 | Sony Handycam DCR-PC115E Mini DV Digital...
Camera wont turn on
  1. Step one: Reset the camera
    1. If you have an optional memory card installed, remove it. (Although removing an optional memory card is not necessary for performing the reset, it eliminates the memory card as a possible cause of the problem.)
    2. Remove all power sources (batteries and AC power) from the camera for at least 5 seconds.
    3. Reinsert the batteries and close the Battery/Memory card door and/or reconnect the HP AC power adapter to the camera.
    4. After verifying that the camera works without an optional memory card, reinsert the card, if you have one.
    Try to turn the camera on. If it now works properly, the camera experienced a temporary electrical problem and should now work properly.
    • If the issue is resolved , you do not need to continue with the rest of the instructions in this document.
    • If the is not resolved , continue with the next step.
    Step two: Check for damage or corrosion on the batteries
    1. Open the Battery/Memory card door on the camera.
    2. Remove the batteries.
    3. If the batteries are damaged or show corrosion, replace the batteries.
    Step three: Recharge the batteries
    1. Recharge the batteries or replace the batteries if they are damaged or will not charge.
    2. Try turning the camera on after the batteries are fully charged or have been replaced.
    Step four: Ensure the batteries are installed correctly
    1. Re-insert the batteries correctly into the camera by referring to the image on the Battery/Memory card door for proper battery placement.
    2. Try turning the camera on.
    Step five: Turn on the camera without the memory card
    2. Remove the batteries and optional memory card from the camera.
    3. Wait 15 seconds.
    4. Re-insert the batteries into the camera, but not the memory card.
    5. Try turning the camera on.
      • If the issue is resolved , format the memory card in the camera and then you do not need to continue with the rest of the instructions in this document.
      WARNING: Formatting the memory card in the camera will erase any images stored on the memory card. To avoid losing the images on the memory card, first save the images to a computer or another disk.
    Step six: Connect the camera to the optional AC power supply
    1. Connect the camera to the optional AC power supply. Ensure that the AC power supply is connected to a working power outlet.
    Step seven: Service the camera If the camera still will not turn on, service the camera. Cause The following conditions can cause the camera to not turn on:
    • Improperly formatted memory card - memory cards should be formatted in the camera they are going to be used in
    • Corrupt images on the memory card
    • More than 300 pictures on a memory card
    • Damaged batteries
    • Dead batteries
    • Incorrectly installed batteries
    • Damaged camera
Jul 19, 2009 | Leica C-Lux 1 Digital Camera
Lost the instruction manual and need to replace it.
Hello
Here is a direct link to the .pdf for your manual. You can save it, view it once, or print it.
http://service.us.panasonic.com/OPERMANPDF/DMCTZ4.PDF
If that doesn't work click on the operating instructions link here:
http://www2.panasonic.com/consumer-electronics/support/Cameras-Camcorders/Digital-Cameras/Lumix-Digital-Cameras/Operating-Instructions/model.DMC-TZ4K.O#ts
Hope this helps
-Chris
May 01, 2009 | Cameras
Olympus Camedia digital camera D-535 ZOOM. When I turn the camera on, it turns itself off. Then when I turn the camera on again, the two buttons on the right side of the screen light up ~~ top one red and...
Although the batteries were new, they were not working. I changed the batteries and now the camera is working well. I still don't have instructions for the use of the camera. PLEASE SEND WRITTEN INSTRUCTIONS. Thank you.
Sep 12, 2008 | Olympus Cameras
IT Works 3045 driver...
no instructions 4 my i.t works 3045 camera
Apr 22, 2008 | IT Works 2040 Digital Camera
Easy Share
Take a look at the Kodak
support page for your camera >HERE< it should tell you everything you need to know, including a download of the manual.
Best wishes..
Mar 31, 2008 | Kodak EasyShare Z740 Digital Camera
Cameras Logo
60 people viewed this question
Top Casio Cameras Experts
Greg Cann
Greg Cann
Are you a Casio Camera Expert? Answer questions, earn points and help others
