Question about Sharp AR-5316 Advanced Digital Imager Copier
H4-00 The Sharp Copier AR5127 displays "call service H4-00" and won't go further than that
  • Sharp Master
  • 19,396 Answers
H4-00 on Sharp means that the temperature inside the printer is too low. That is usually the fuser lamp, and rarely the temp sensor.
When this happen you need to have the fuser unit replaced, if that does not fix the problem the technician will replace the temperature sensor.
Posted on Feb 27, 2009
  • Ginko
    Ginko Feb 27, 2009
    Hi , I tried to help you , explaining what your problem was, I will be grateful if you can tell me why you gave me a negative rating for giving you my technical advice.
    Thanks.
    Problem Solver:
  • 12 Answers
H4 Heat roller abnormally low temperature
Check blinking of the heater lamp
with SIM 5-2.
When the lamp blinks normally:
Check the thermistor and the
harness.
Check the MCU PWB thermistor
input circuit.
When the lamp does not light:
Check for heater lamp
disconnection or thermostat
disconnection.
Check the interlock switch.
Check the power supply PWB
and MCU PWB lamp control
circuit.
Clear the trouble with SIM 14.
Entering the simulation mode
Perform the following procedure to enter the simulation mode.
Clear key ® Interrupt key ® "0" key ® Interrupt key ® Main code ®
Start key ® Sub code ® Start key
Posted on Mar 01, 2009
What could be the cause of f2-02 in sharp copier ar5127
You need to first check the toner cartridge to make sure its ok (May be bad). The other problem can be the developer being depleted causing the sensor not to detect the proper density whcih is one cause of the errur code.
Printer Repair Service in Miami and Fort Lauderdale FL
May 20, 2016 | Sharp Office Equipment & Supplies
How do i fix c4 display by sharp sf-1025 copier?
It appears that the copier has a hardware error resolve it else repeated power-on will only damage it further
Jun 25, 2015 | Sharp Office Equipment & Supplies
How to remove code f2 from a Sharp AR-5316
What is the next after f2- or if f2-64 check development un or connect the connector chip.Replace development unit.
Jun 10, 2014 | Sharp AR-5316 Advanced Digital Imager...
Error L6-10 sharp AR5127 Problim i dont know I
You forget to connect the laser cable to main-board.
Jan 06, 2011 | Sharp AR-5316 Advanced Digital Imager...
Toner leaking model AR5127 how to fix it
Hello sir; It seem like the toner recover blade need to replace it located at drum cartridge.
Jan 18, 2010 | Sharp AR-5320 Black and White Copier
Ar-160 display says "check panel" no more codes or functionality
tis problem is some of panel button is short i mean it is lock please open your machine panel board and service it . then solve your problem
Aug 02, 2009 | Sharp AR 201 Copier
Sharp ar5127 copia eror slution
Check the scanner lock located under the scanner section on the left side. Change the position of it.
If it sitll locks the scanner could be jammed up by the cable. The scanner glass has to be removed to fix that.
Jun 13, 2008 | Sharp AR-5316 Advanced Digital Imager...
Request service manual for sharp AR-5316
http://www.retrevo.com/search/v2/jsp/downloadPage.jsp?doc=7b292ec58f421b3b3b442c1437984770&q=Sharp+AR-5316
Apr 19, 2008 | Sharp AR-5316 Advanced Digital Imager...
Sharp AR-5316 Advanced Digital Imager Copier Logo
344 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
