Question about Acer Aspire 5570-2758 Notebook
Won't scroll to top of page. Stuck at the bottom! Fixed momentarily by pressing scroll lock key or F7 key, but goes back to the bottom seconds later. (I also have issues with the F7 key, and the touchpad not working). My son uses the computer for games sometime, in case that helps. Thank you!
  • 1 more comment
  • mooretn3 Mar 03, 2009
    It is not acting bad today, but I will try your solution later.
    Thanks for trying to help me.
    Thanks, Tim, but there's no ! in device manager. Actually, the computer is working ok now. (This is a frequent, random problem).
  • Seabee Tim May 11, 2010
    In your Start menu search type Device Manager. Open Device Manager, and is there anything in there showing up with a ? I'm thinking you may have a driver conflict with your touchpad.
    Scholar:
  • 150 Answers
It sounds like your scroll lock key is stuck on. Press the Function key and the scroll lock key at the same time and this sound turn off the permanent scroll lock.
Posted on Feb 27, 2009
The screen is really dark
Locate the Fn (Function) key on your keyboard. It may be on the bottom left side with dark blue letters. Locate the two "brightness" keys near the top of the keyboard. These will be in the "F" keys, possibly if F6 and F7. They should have little sun pictures or something similar to indicate brightness. Hold down the Fn key while pressing F7, or whichever "F" key your laptop uses to increase brightness. Tap F7 repeatedly until you reach the desired brightness. Fn must be held down as you continue to tap. Hope this helps.
Dec 07, 2012 | Intel EasyNote E4 715 Notebook
My mouse and think pad do not work
There are 2 possible answers to this common issue, the first is that the aspire has a mouse lock. check your keyboard on the function buttons for a picture of a mouse with a line though it, hit function and at the same time press the mouse with the line through it and if its locked off this will turn if back on. The second answer is driver issues, if the first suggestion dont work I would go to the Acer website click on downloads and drivers and enter your model number. Then download and install your think-pad and mouse pad drivers and install.
Sep 04, 2011 | Acer Aspire 5500 5570-2609 Laptop
My touchpad is locked how do i unlock it ?
Hi
can you please try pressing the FNkey plus the F7 key both a the same time
or hold down the FN key and press the F7 key and leave for a few seconds to work
occasionaly the touchpad lock is a different key than F7 so please have a look at the top row of keys and look for a picture of a hand pointing and use that key along with the FN
hope this has helped you
many thanks
Aug 11, 2011 | HEWLETT-PACKARD Elitebook 8460P
On my toshiba mini laptop the cursor gets stuck in a page up and down mode - just goes up and down but won't move right or left. I may have hit some key, but how do I get out of it?
You have Scroll Lock on.
Look at the top of the keyboard for a key which says "Scr Lock" on it and press that key.
the Scroll lock will then be removed allowing you to use the mouse cursor properly.
Regards.
Jul 04, 2010 | Toshiba Computers & Internet
THE KEYS ARE ALL SWITCH TO DIFFERENT CHARATERS WHEN I PRESS M GIVES ME 0
ok here from left to right top row esc f1 f2 f3 f4 f5 f6 f7 f8 f9 f10 f11 f12 prtscrn scrolllock pause second row ~ 1 2 3 4 5 6 7 8 9 0 - = bkspc insert home page up num lock / * - third row tab q w e r t y u i o p [ ] \ del end pgdn 789+ fourth row caps lock a s d f g h j k l ; ' enter 4 5 6 fifth row shift z x c v b n m , . / shift up 1 2 3 enter bottom row ctrl windows key alt spacebar alt windows right click ctrl 0. hope that helped
Oct 11, 2009 | Compaq Keyboard
I have a DL2700 lock that several invalid codes were entered. The lock went into an antitamper protection mode and never recovered or reactivted. I put new batteries in and still nothing, where do I go...
Dennis, remove the battery pack and hold down any number key for 10 seconds to bleed of any capacitor charges. Reconnect the battery and within 3 seconds, press and hold the A key until a series of beeps is heard, then release the A key. This erases all programing and restores factory default settings. www.alarmlock.com is a great place to get this type information. At the top of the home page click on "support" then on that page scroll down to "technical library" at the bottom of the page, then look for your lock under "programming instructions". I hope this helps!
Aug 04, 2009 | Trilogy Alarm Lock T2 TRILOGY® Digital...
DL 2700 Alarm lock malfunction with constant alarm
I have had this happen on a 3500 and I had to replace the keypad assy. But, you may want to try to restore factory settings just to see if it resets. Disconnect the battery pack and hold down any number key for 10 seconds (this bleeds off any charge that may be in the capacitors). Reconnect the battery and within 3 seconds, press and hold the "A" key. After hearing 6 beeps, release the "A" key and wait for 5 seconds for the lock to re-lock (listen for 1 beep and red LED).
If successful, this will reset factory settings, which means the master code is now 1 2 3 4 5. If you need a programming manual, go to www.alarmlock.com At the top of the home page click on "support". Scroll to the bottom of the support page and click on Technical Library. Scroll down that page and find "trilogy DL programming manuals" and under that click on "download DL2700 enhanced instructions". I hope this is some help!
Feb 22, 2009 | Trilogy Alarm Lock T2 TRILOGY® Digital...
How to get rid of numberlock in ibm thinkpad t30
Hi Ritadeng,
On the Thinkpad T30, the number lock key can be turned on or off by pressing the shift-key and the scroll-lock key. The scroll lock button is found at the top of the keyboard between the PrtSc button and the Pause button.
You should see the light with the arrow and the number 1 inside (just above the F7 key) turn on and off when you press this.
Hope this helps!
David
Nov 18, 2008 | IBM ThinkPad T30 2366 Notebook
Arrow keys
The scroll lock is probably ON.
Download the user guide from
http://PCsupport.toshiba.com
to find out what keys to press.
Its usually FN-F11 or something
Dec 27, 2007 | Toshiba Satellite A100-S8111TD Notebook
When on the cingular mall trying to download ringtones it jumps to the top of the page.
My mall connection wont work i dont know why i have texting and i can call and everything but how can i fix this problem it says connection unseccsuccfull try again later
Oct 31, 2006 | Motorola Mobility RAZR V3
Acer Aspire 5570-2758 Notebook Logo
222 people viewed this question
Brian Sullivan
Brian Sullivan
Mohammed Ebrahim M
Mohammed Ebrahim M
