Question about Zanussi 24 in. DE6844ALU Free-standing Dishwasher
Zanuzzi. works all the way with cold water only.
    Problem Solver:
  • 6 Answers
Either the heater but most likely is the printed circuit board (faulty heater triac)...needs a pcb replacement
Posted on Jul 15, 2009
Water leaking under zanuzzi frost free larder freezer
. There is a condensate pan under the freezer side. When the defrost cycle completes it can get quite full. Usually the water dries up with time. If your water filter is down in the toe kick grille, it may be lealing into this pan.
Oct 30, 2017 | Frost Refrigerators
Cold water cycle does not work. Can get only hot water when cold water cycle is run
Swap the hoses around on the Hot & Cold water Taps to prove that the Cold water Solenoid is not working.
Could be electrical from program timer or
The Needle or Diaphragm inside the Valve section of the Solenoid.
Take apart the solenoid & clean it.
Jul 08, 2015 | Washing Machines
TUMBLE DRIER STOPPED HEATING
Gas dryer?
If so, probably bad gas solenoid valves. They can safely be replaced without fear of releasing gas. Two phillips screws, two pull off wire plugs. That's it. Cost about $30 bucks depending on where you buy them. They are a universal part and will fit 99.9% of machines.
www.repairclinic.com
Best of luck...
May 18, 2015 | Dryers
Zanuzzi Jetsystem XC6 not draining fault E20 coming up on screen
This particular code is used when the machine detects a pump problem or water draining problem (failure to properly pump all the water off in the designated time). It turns out to be a blocked filter, accessible from the bottom front of the machine.Get the filter and drain pump checked.Any of the one is checked to be faulty.But if both checks out ok then its faulty control panel board.There is a short and this is causing the problem. You can get required parts from www.repairclinic.com
Thanks. Keepupdated for any more query. You can rate this solution and show yourappreciation.
Aug 30, 2010 | Zanussi Washing Machines
GE washing machine wont turn on
my 2year old zanuzzie washing machine just went dead after a wash. went to do another wash but lights dont come on when at any programme
Jan 09, 2010 | GE Washing Machines
Error code E20 on Zanuzzi washing machine. Not draining/washing.
Simple in most cases its just the filter outlet has becopme full of day to day junk, debris and slime.
Slowly release the water by turning the handle to release the water. Ensure power is off.
Once water has been drained into a shallow tray you will be able to open the door.
Once the drum is empty, unscrew the handle completely to remove filter housing an clean out thoroughly.
replace and tighten up.
Turn on power and reset all programmes.
this should work, total cost about 15 minutes of your time.
If it doesnt work it may then be your pump, time to think about and engineer
Nov 29, 2009 | Washing Machines
Automatic warm/cold water temperature setting does
The temperature control board is bad . Pt # 388246
Aug 17, 2009 | Kenmore 22422 Top Load Washer
Help with zanussi it wont fill with water
you need to know the error, but could be low insulation heaters....you need to find error message which zanuzzi engineer will find
Jul 15, 2009 | Washing Machines
Does Not Rinse
Check each temperature during initial wash fill. Set to hot water, is hot water coming out? Set to cold water, is cold water coming out? The rinse cycle is cold only. If cold water is not working machine will just stop at rinse.
If cold water not working:
Disconnect cold water hose from machine. Inspect the filter screen on the cold water connection. DO NOT REMOVE SCREEN. If full of debris, use a spray bottle with a hard spray to remove debris. If unable to remove or cold is still not working, replace valve.
Jun 14, 2008 | Whirlpool LSR6332K Top Load Washer
Zanussi 24 in. DE6844ALU Free-standing Dishwasher Logo
91 people viewed this question
Top Zanussi Dishwashers Experts
Owen Barnes
Paul Carew
Are you a Zanussi Dishwasher Expert? Answer questions, earn points and help others
