Question about Samsung Washing Machines
Power On/Off button not working. Washer XQB50-L65
  • fixer444 May 11, 2010
    Check whether there is power in your wall socket with another gadget; then check to see your washer's plug, fuse.......
  • 46 Answers
I have seen where the connecxtion to the switch is off. Try opening up the washer and looking at the connection to the switch. Otherwise defective switch or circuit board problem. Best of luck.C
Posted on Mar 01, 2009
Hello, i have an old L65 Husqvarna chain saw, i have been lookin for a piston kit, but with no luck, i was told that old style 48mm piston out of Husqvarna model 61 will work in a l65 . Can any one co
I have a homelite piston running in my Husqvarna edger . Most pistons for engines are all the same if the cc's are the same . they only vary in the gudgeon pin size and the location of the pin in the piston. So take your piston to a small engine wreckers and any piston that measurers the same ,looks the same will do the job. then get a new piston for the make that it came out off and it will fit.
Mar 28, 2014 | 1993 Nissan Pathfinder
XQB50-167
Google it with brand and model number.
Helped? Click.
Apr 25, 2013 | Washing Machines
Sound not working
You need to set the the Default audio device to the speakers in the Control panel and make sure the sound is not "muted" (turned off)
Feb 18, 2013 | iTEKIRO Laptop AC Power Adapter Notebook...
I want the brochure of model xqb50
I'm so sorry but this forum does not, nor is in a position to, supply any type of manual (service or otherwise), parts list, installation instructions, electrical or schematic diagrams direct; it's just made up of ordinary guys and gals, probably at home and from all over the world, with experience of addressing problems and giving guidance for free on the web ;-0)
Also members on Fixya are not 'affiliated' to, or representative of, any manufacturer at all, just using their experience gained probably over many years
You will need to type into your search engine/web browser '(make model number) washer manual' and you should be presented with a number of sources from which you can either download for free or have to pay a nominal amount.
You could also try the manufacturer's web site direct ;-0)
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C.
Sep 15, 2011 | Washing Machines
Washer fluid pump not working, fuse is good but can't find relay
The relay is INSIDE the wiper motor, and not replaceable. Check if you have power to the Blue/White wire, if you have power (while pressing washer button) and the black wire has no power (ground) , then the pump is bad. If no power when pushing the wash button, ground the Gray/Brown wire at the wiper motor, if the washer works, then the washer button may be bad. The button grounds the relay using the Gray /Brown wire.
Nov 30, 2010 | 2008 Ford F 450 Super Duty
Lowrey L65 restoration
Try going to the
organforum.com
Feb 17, 2010 | Music
Is there a reset button on the LG front load washer
No button, but LG customer service says unplugging the unit for 1 hour and then holding the power button while turning it on will reset the computer.
In my experience this does work, but I don't think it resets absolutely everything.
Another time I had a problem LG customer service told me to unplug the unit, hold the power button for 60 seconds and then plug it back in. I can't confirm if this works or not, but it is worth a try first (60 seconds is a lot shorter than 60 minutes...).
Feb 25, 2009 | LG WM2688H Front Load Washer
Haier- xqb50-7288a
Washing machine says E2 what is problem will not spin
Feb 13, 2009 | Haier Washing Machines
Washing Machines Logo
74 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
