Question about Western Digital My Book Essential 1TB External USB 2.0 Hard Drive
WD 1TB working properly for some time
I have a WD 1TB it worked properly for some time but now when i am starting the system the external is also getting on & it is working properly for sometime. But after some time it is not showing up in mycomputer & computer management but it is showing up in device manager. so plz i need urgent assistance.
  • 3 more comments
  • sureshm20f Feb 27, 2009
    if i start the system again it will work for sometime but after some while the problem is again arising the EX HD is not showing up in mycomputer&computer management but it is showing in device manager, the light in external HD is also glowing but in mycomputer it is not showing up. can anyone tell me wht is the problem & solution.
  • sureshm20f Feb 28, 2009
    hi to everyone
    i have scanned my HDD using HiTune Pro then i found some damaged blocks. so now i want to know how can i repair the damaged blocks does anyone has suggestions.
    thnks in advance...
  • bassass May 11, 2010
    check to see if you have a reset on the hard drive..mine does should be on the back maybe try that
    try starting the computer with out the external drive hooked up..then hook it up
  • Anonymous Mar 31, 2014
    windows cant find the divice. not in disk management either. but it shows up in units an priter in the controlpanel- where it says it works fine... need the data on the disk so thanks for any help
  • 463 Answers
Make sure the power supply (power brick) for the mybook is working. (unplug both ends or the power cable and plug back end)
do the same for the USB cable. Still no luck? Plug the USB connector into a different port on the PC and see if that changes your luck.
Posted on Feb 27, 2009
  • Rob
    Rob Feb 28, 2009
    whilst it is "working", have you went into the disk manager (start, run, diskmgmt.msc, ) and assigned a different letter to the drive, such as "M:"? then, perhaps whatever conflict you are having may cease. May not, but just might. Try it...
Recommend me branded USB drives ?
Honestly, any USB brand will cut it for you. What you want to ensure is that you are purchasing the proper version (1.0, 2.0, or 3.0) for whatever device the key will be associated with. Also make sure you don't buy too little or too much memory. But if you know all this and you just want a reliable brand, I would go with SanDisk.
Aug 04, 2015 | Computers & Internet
I accidentally plugged in my 19v toshiba laptop adapter to my 16v 1tb external hard drive it started up but then i plugged it out soon is it possible that the hard drive will work or is it dead, if no
The electronics in the hard drive is damaged and cannot be repaired by us mortals.
There are companies that can recover data from damaged hard drives BUT it will cost you an arm and a leg for their services.
May 12, 2012 | Western Digital WD My Book Essential 1TB,...
When I plug in my WD 1TB drive it powers up and goes right back off. Any ideas or suggestions? It is 2 years old and has worked fine until now.
WD has had major issues with one of its chipsets (pitted IC due to thermals).
Have you tried the hhd on other machines and got the same issue?
Again, it is just a serious issue WD had with their "My Book" products.
Don't fret, the data is still on the hd and you can utilize it once you get the proper pcb for it.
Apr 13, 2011 | Western Digital My Book Essential 1TB...
WD Elements 1tb External HDD media files skipping
Try running Scan Disk and defrag. Otherwise use a program like SpinRite to do a low level scan of the disk.
Good luck
Feb 15, 2010 | Western Digital 250GB ELEMENTS EXTERNAL...
1tb WD external hardrive not mounting, can't access my info ?
First of all, restoring a hard drive rarely affects data stored on it. I usually just adjusts the supporting software that allows it to run properly. Definately check the manual prior to restoring it, though. Formatting it will absolutely erase everything (unless your the FBI). I'm about 99% sure that restoring it will leave your stored data completely unaffected.
You're better off performing the work using the newest OS available. BTW, your BF can plug into the internet and get upgraded to 10.4.11 as well for free and it doesn't take long.
Oct 06, 2009 | Western Digital My Book Essential 1TB...
WD mybook 1TB is gone from the network
Have you tried different cables or a different port on your router. Is there any way to get into the Hard Drive by connecting it directly to a PC and checking the network settings or anything..? If not, then you may have to connect it directly to a PC and share it to your other PC's.
Sep 15, 2009 | Western Digital My Book World Edition 1TB...
My Western digital 1tb wont work inspite of drivers being instal
Mybook does not require any additional driver to work on systems from Win XP onward, same for recents Linux and MAC OS.
If the drive is not detected on more of one computer, then it is usually because of a fault.
Try a replacement cable (mybook uses Mini USB to USB, available at computer and at camera shops). If still no luck contact WD, mybooks have one year warranty. If you want to recover data, the disk must be mounted on a different enclosure, that service can be asked when discussing repair.
Regards
Jul 12, 2009 | Western Digital My Book Essential 1TB...
Flashing blue light on external WD hard drive & not recognised
sounds like you are using the wrong power supply. Check the amp output on the power plug you plug into the wall make sure its the same as the amp input of your external harddrive
Jun 01, 2009 | Western Digital My Book Essential 1TB...
Western Digital My Book Essential 1TB External USB 2.0 Hard Drive Logo
325 people viewed this question
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Marcin
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
