Question about ATI RADEON HD 2400 PRO Graphic Card
Ginko how to remove on board ram in dell inspiron 1000 laptop
Ginko
    New Friend:
My dell inspiron have a bios password
Posted on Dec 19, 2012
Locate the ram on the motherboard. Use a steel ruler and a very sharp craft knife cut the pins to release the RAM. Make sure the remaining pins are not touching eachother. Install a larger module in the additional ram slot. Worked for me on several laptops but no guarantee.... Currently your laptop is faulty...a reflow gun is exppensive and needs skill to use correctly.... you've nothing to loose really
Posted on Jul 14, 2009
  • 19,396 Answers
If you are refferring to the 256 MB Ram soldered onboard, then you have to do a precision desoldering and soldering job.
Roughly is the same job that the guy in the movie below is doing to remove the onboard ram done on a playstation.
Removing RAM
On your laptop the Ram chips are located underneath the empty slot for the additional memory stick.
A faster and better way to remove the memory chips without risking to damage the motherboard is using an hot air desoldering kit, but the desoldering station costs about $200, see below:
Hot air desoldering
Wellersoldering.com Desoldering Hot Air and Rework Stations
Posted on Feb 27, 2009
  • elroacho Feb 14, 2011
    An alternative is to limit the amount of RAM the operating system can "see" using the /maxmem=### switch in boot.ini (where ### is the mem limit in megabytes).
    The optional dimm slot loads first and then the onboard ram, so set /MAXMEM to the exact size of the 3rd party chip in the optional dimm slot.
    If you add a 512MB chip then use: /MAXMEM=512
    http://support.microsoft.com/kb/108393
    The notebook will have 768MB total, but the OS will only "see" 512MB.
    Install windows with the additional memory installed to reduce the corruption during setup (with just the bad onboard 256MB, it will throw lots of errors). Once in windows, set the /MAXMEM switch and reboot. The bad 256MB should now be invisible to the OS. Do a Start -> Run -> sfc /scannow to fix any files that were corrupted during install.
System and administrator password for dell inspiron laptop 1200 model PP10S
  • DELL INSPIRON 1200 Master Password, Unlock Dell Laptop www.novatecdirect.com/.../1200-dell-inspiron-1200-master-password.html ... Mar 31 2015, Dell inspiron 1200 Master Password, 1200, dell, ... and System Disabled Security on Dell Laptop: ... dell inspiron 1200 laptop, reset dell ...
  • Dell PP10S ' eBay z www.ebay.com/bhp/dell-pp10s DELL Inspiron 2200 PP10S Laptop Computer 1 ... The Administrator Password needs to be reset. ... Part Numbers:8 CELL Battery for Dell Inspiron 1000 1200 ...
  • Inspiron Laptop - factory reset no admin password - Dell en.community.dell.com > ... > Laptop > General Hardware my problem is with dell inspiron 1200. Just bought this system. During POST it prompts for an administrative password which I dont have. Displays massage like "this ...
  • Administrator Password for Dell Inspiron 1200 Bios & Hard ... dellpasswords.com/administrator-password/index-of-remove-dell... Remove Dell Inspiron System Disabled Password: Now we have a picture on the right that shows a dell inspiron 1200 laptop with the system disabled password
  • May 08, 2016 | Dell Inspiron Computers & Internet
    My Dell Inspiron E1705 PC Notebook two light just blinks and doesnot boot
    make sure the ram is properly installed just remove ram and check it give the beeps if it gives the beep that means board is ok clean the ram with pencil eraser and fix it again.
    Have a nice day and do not forget to rate please...!
    Dec 27, 2010 | Dell Inspiron E1705 Notebook
    PC will not bootup. HD light stays on even with Battery and HD removed. Fan comes on and then stops. Cannot access BIOS config screen either.
    it may be the RAM Issue or M/B probem..remove the ram & see the light condition if it is same then it is ram prolem otherwise M?B.
    sudipta2k21@gmail.com
    dell support team
    Dec 01, 2009 | Dell Inspiron 1000 Notebook
    How to open the Dell Inspiron 1000 Notebook to replace the AC connector?
    The AC connector is part of the mainboard. It is soldered onto the board and not readily replaceable by itself. You must replace the whole mainboard. Dell boards are usually available on ebay for a reasonable price.
    The screws to open the laptop are the all the ones on the bottom.
    Aug 15, 2009 | Dell Inspiron 1000 Notebook
    Dell Inspiron 1000 Disassembly
    i took apart a few laptops recently to swap a few things and there was some double sided tape holding the motherboard to the bottom casing. maybe thats it
    May 19, 2009 | Dell Inspiron 1000 Notebook
    1gb upgade
    Reinstall the RAM board. Adding RAM should not affect your programs, unless you put the wrong type of board or size in.
    Jan 31, 2009 | Dell Inspiron 1000 Notebook
    Best virus software for low ram computer
    try AVG
    Avira
    this antivirus softwares are free to use and they dont make your systems slow
    Dec 25, 2008 | Dell Inspiron 1000 Notebook
    Dell Inspiron 1000 will not boot up.
    Greetings,
    The symptoms you described are normally common motherboard failure signs.
    Try removing the ram and hard drive from the computer and then try booting the computer.
    Oct 28, 2008 | Dell Inspiron 1000 Notebook
    Replacing a motherboard in a dell Inspiron 1000 laptop, and the screen not working
    u need to reset the bios to factory defaults..this would fix your problem
    Feb 06, 2008 | Dell Inspiron 1000 Notebook
    ATI RADEON HD 2400 PRO Graphic Card Logo
    411 people viewed this question
    Top ATI Computers & Internet Experts
    David
    David
    Computer Links
    Alun Cox
    Are you an ATI Computer and Internet Expert? Answer questions, earn points and help others
