Question about Epson Office Equipment & Supplies
Loading ink cartriges on epson rx560
Have loaded cartriges but it keeps saying noy recognised then asks for cd/dvd settingcan u helpplease
  • 27 Answers
Pull out the ink cartridge and look all around it you may have left the thin plastic tape like peice on it . peel that off and replace it in there and restart the printer you should be good to go.
Posted on Feb 27, 2009
I bought ink cartriges from staples, put them in but it says , cannot recognise them?
Hello, In Purchasing Epson's CX 5400, CX4600, & CX7400 and more, I found out that Epson does not like Generic Printer Cartridges. That sounds like your problem. Also in Purchasing the Brother's . Color that should be Yellow, will turn out Green, etc. All Generic Cartridges, will print lines thru the words, and also do a mix match with the colors. That's what the Companies do., so they can keep selling the ink cartridges. Some Printers, are able to use Generic, but you have to fill them up yourself and I heard, quite MESSY.
So I learned, thru trial and error, that you must use the ORIGINAL Genuine Cartridges for the PRINTERS.
Since you do not mention what type of ink cartridges you purchases, this is the only advice I can give you. If you find this helpful, pls rate me.
Thanks and Good Luck :0)
Dec 31, 2009 | Epson Stylus RX560 All-In-One InkJet Photo...
Red light on steady
If the ink light is on steady red, that means the black or color ink cartridge is nearly empty. Obtain a replacement black or color ink cartridge. To know which cartridge is out of ink, check the ink levels using EPSON Status Monitor 3 (Windows) or EPSON Status Monitor (Macintosh). If you just replaced the cartridges before you got the error light, that means that the replacement cartridge is not recognized by your printer. Please reseat cartridges. Then turn the printer on and off. The cartridges maybe bad also.
If the paper light is on steady red, try to reload 10-20 sheets of regular paper into your printer. When printing on CD/DVD, CD/DVD tray is not inserted in the printer. Insert the CD/DVD tray in the printer and press the paper button.Could also be that the printer has loaded more than one sheet of paper at a time. Load paper in the sheet feeder, and then press the paper button to resume printing. If the CD/DVD guide is open, close the CD/DVD guide, load paper and then press the paper button.
May 17, 2009 | Epson STYLUS R230 InkJet Photo Printer
Epson DX8400 does not recognise ink cartridge
on the ink cartridges there should be a little gold chip on them if they dont have that then your printer will not recognise the ink my best bet for you is to buy cheep and reliable placement epson ink or you can buy these ink cartriges which have tubes which feed ink into these replacement cartridges and i have got one of these my self and i would recomend these to anyone
Apr 15, 2009 | Epson Stylus DX8400 All-In-One InkJet...
Ink cartriges not being recognized by printer
It is not uncommon for an Epson printer to fail to recognise Epson cartridges. It is either due to failing to go through the proper cartridge replacement cycle properly, or more seriously, due to a communication problem between the cartridge and the main board. To fix the first, simply go through the cartridge replacement cycle again (see your manual how to do this before the cartridges are empty). Simply take your new cartridges out when told to, and put them back in again when told to insert the "new" cartridges. If it's the second problem you need specialist help, or simply sell your printer on e-bay for what you can get.
Dec 17, 2008 | Epson Stylus Photo 830 InkJet Printer
RX560 Ink pad reset
pls i want rx560 ink pad reset and rx610 ink pad reset
Jul 11, 2008 | Epson Stylus R265 InkJet Photo Printer
Epson RX560 ink cartidges not recognised
Report this to Epson Support.
Remove all cartridges and switch the printer off
Reinsert and retry.
Download the Epson utility www.ssclg.com
and use it to Reset counters.
Feb 11, 2008 | Epson Stylus RX560 All-In-One InkJet Photo...
Epsom Stylus Photo R300
Yes I had a similar problem and in fact returned my printer for a replacement. You need clearance as the CD tray emerges some 2.5 to 3 inches behind the printer. If the tray hits an obstacle it is unable to correctly line up for printing and the trat is rejected
Dec 24, 2007 | Epson Stylus Photo R300 InkJet Printer
Epson RX560 Waste Ink Full Service Required
i brought software today to fix my rx560 ink pad problems fixed software cost me £40.00 but am willing to pass it on at a cost of £5 software does not run on vista so will need a pc with xp or some thing like that to fix as i say i reset mine today thanks for your time and please contact me if you need this software
Dec 15, 2007 | Epson Printer
Compatible ink
yes i have a epson rx560 i brought a contiouous ink system the thing you must watch out for when buying copy ink is that they work with all modles or rx560 as some ink will only work befor printer made before 1 march 2007 and some will only work after made 2007
but the continuous ink system will work wit all models i can get cis for £45 plus postage and come with 6 x 100 ml ink contact me if your intreasted
Oct 11, 2007 | Epson Printer
88 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
