Question about Alesis iO/14 Portable Firewire Audio Interface Sound Card
The sound is coming out very quiet and quite distorted. i recently travelled with the alesis, but im not aware of any heavy knocks it took?
Pls help how solve my problem about sound card, no out put
Posted on Feb 27, 2009
Only distortion..
Check your power adapter. This unit REQUIRES a 9 volt AC adapter, NOT a DC one... It MAY appear to operate on DC BUT it can't generate the +/- voltages internally for sound generation with a DC adapter. This is a common problem as people try to run these on a DC adapter.
Here is a link:
Apr 10, 2011 | Alesis Sr 16 Stereo Drum Machine
I have a situation were my altima starts but when I put in gear it just stalls and shakes and turns off almost immediately..the mechanic put the computer to the car and it reads knock sensor is messed...
well it sounds like your car is starting out in 4th gear which is overdrive,thats quite the load on the engine.knock sensor is what it says its a is designed to sense knock on heavy is suppose to ****** your timing to stop knock. your mechanic is on the right track to say it is poss. the transmission.
Jan 02, 2011 | 1996 Nissan Altima
Knocking noise from under hood
ok the lifters are making noise, make sure you are using the right oil for your temp zone. also add some lucas oil to your engine oil, it will quiet down the engine.
Jun 05, 2009 | 2000 Kia Sephia
Audio Distortion after System Crash
sorry for the late reply. im using windows. im quite sure that there's no virus involved with the distortion of my sound. this is what happened.
1. im surfing the net while listening to music(full volume)
2.)then suddenly the sound gets a bit distorted(jumps,skips)
3.)then everything hangs up which forced me to reboot
4.)the windows loading screen became too long(like 5mins) before it takes me to the main desktop(start up programs loads like 48 years also).
5.)when i play music ,the sound is very much(like alien,"rrrrrrr")
i tried reinstalling the drivers but nothing was fixed. i've even tried Regcure.
i just formatted my notebook and voila its back to normal.
i dunno but i think playing loud music using laptop, or in my case notebook speakers would cause this problem. im using external speakers now and i've got no problems. i just hope that there would be a fix to this problem so that i wont have to reformat if the problem occurs again
Apr 20, 2009 | Acer Aspire One PC Notebook
Alesis M1 MKII bass ports
if desiring loud bass, keep port open. It is designed to be that way. If subs are in a corner, face the wall to change the wavelength and port noise wont be as evident.
Dec 23, 2008 | Alesis M1-Active MkII Main / Stereo...
Alesis SR-16 distorted sounds
The distorted and low volume output plus noise is usually caused by using the wrong power supply adapter. The Alesis SR-16 takes a 9V "A/C" supply not "DC". The A/C supply provides a negative voltage swing which wouldn't exist with a DC supply. So check and make sure you have 9V A/C output supply not DC.
Nov 18, 2008 | Alesis Sr 16 Stereo Drum Machine
Help my truck is knocked up
Hi shwangod, you said it was a "heavy knock" and it began climbing a hill, could you give me a little more info, mileage, overall condition,2 or 4x4 am assuming this is a small block 350 cid, obviously there are different "knocks" for different problems, lifters do not knock they will click or rattle and are easy to adjust, a timing knock is the resultant effect of incorrect timing usually on the low side and is also easy to determine.A wrist pin knock associated with the piston boss pin can sound like a main bearing knock and is worse when the engine is cold and will subside as the engine warms up, the main bearing knock is the heavy knocking that doesnt quit and can lower oil pressure (operating) you can plastguage the mains to determine the amount of wear and if you are lucky you can roll in a set of bearings, when you drain the oil look for metallics, specifically brass, personally I am not a fan of upper or lower engine rebuilds but prefer to "Rebuild" the entire engine. I hope this helps you,good and let me know how you make out.
Oct 23, 2008 | 1992 Chevrolet C/K 2500
Would not start
Even if a laptop suffers quite a heavy knock, it doesn't always show up immediately. I'm guessing the blow it took has done it some harm but I have come across cases where a laptop that suffered a knock did work for a short time afterwards.
Without admitting liability unless there is obvious case damage, I'd submit a hardware failure ticket to your manufacturer if the machine is still under warranty. If it's not, then you may have to decide if it's worth paying for a repair. Either way since it worked right away, the problem obviously isn't the hard drive, so whatever you decide to do you will be able to take the laptop to a shop and have any important data copied off the hard drive prior to either repairing or scrapping it. Be aware most places DO charge for this, when I last checked the going rate was around $70
May 26, 2008 | Toshiba Satellite A135-S4527 Notebook
Distortion in one channel
your right output component (transistor or integrated circuit needs to be replaced)
Nov 11, 2007 | Alesis RA-150 Amplifier
Computers & Internet Logo
133 people viewed this question
Top Alesis Computers & Internet Experts
John Bolton
Raghavendra Nagaraj
Raghavendra Nagaraj
Are you an Alesis Computer and Internet Expert? Answer questions, earn points and help others
